Question about Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Burned out motor on QPL625 Shop Vac
Is it possible to replace the motor for my Shop Vac at a reasonable price? Is this something I can just replace myself?
  • Anonymous Mar 13, 2014
    motor is squeeking
    motor will not run
  • 120 Answers
Well if you can find the motor ( find a place that deals with the manufacturer directly so you get the right part ) and it isnt to expensive, most shop vacs are pretty easy, if you look under the top you should see about four screws, remove those and the top should come of giving you access to the motor, take note about the wires and what they hook up to. i doubt the motor is fastend down other than that.
Posted on Sep 18, 2008
The electronic plug in the lower half of the vacuum (can only be seen when you take the top half off) is burnt. I need to replace it and can't find the name of the part on a schematics.
Well in vac shop terms that cord is referred to as a 'pigtail'. I cant seem to find a replacement or a part number off the schematics but that isn't uncommon. The problem is that when a cord like that starts burning its a sign of the cord drawing to much energy, possibly from a motor getting ready to go out. My advice is to definitely take it to a vac shop.
Feb 14, 2016 | Bissell 5770 Healthy Home Bagless Upright...
Machine wont run what is the problem
take it to your local vac shop. Could be a bad plug, a bad switch, or possibly the motor is bad. Not as likely a motor if you didn't experience a burning smell or loud noises first.
Oct 26, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Shop vac stopped working
Motors have a thermal safety fuse in the field winding. If it overheats, it will blow and either can be replaced or the whole field winding will have to be replaced. It is wired and is not considered to be a user servicable item.
Apr 22, 2014 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
Where to by replacement motor
you can buy a replacement vacuum for the same price as the motor on its own. I would recommend getting a new unit altogether as they are not very expensive to but but a fortune to fix. I have been in the vac business for 20 years and have a bit of knowledge on shop vacs and a new one is your best bet.....good luck
Oct 06, 2010 | Shop Vac 952-02-62 Hang Up Pro Canister...
Power just 'clicks' doesn't turn on.
The motor could be burned out or you have a carbon brush in the motor that is stuck. The motor will need to be taken out and tested on its' own. A electric motor company can test it for you or a Vacuum Shop.
Dec 03, 2009 | Hoover Vacuums
My kirby legend II started spitting out sparks near the foot plug. How can I fix it please? Thanks Candy
Depends where the sparks are spitting from.Unplug from the wall and try to detach the cord from the vac itself, where it plugs in. If there is a small hole burned in the side you will need to detach the entire cord from the handle where it clamps on and buy a genuine new one from a vac repair shop or Kirby dealer. Cords do wear out. Ther is a slim possibility you could have a bad switch below but generally the switch just dies , no sparking.
If the sparks were shooting out from inside the motor housing, you will likeley need a motor rebuild which should be done by a professional at vac shop.
Oct 04, 2009 | Vacuums
Shop vac QPL625 on off switch stays on.
Contact Digi-Key 1-800-344-4539 or 218-681-6674 ask for part number EG1505-ND.
Cost is about $2.00 plus shipping.
See http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=EG1505-ND for part details.
You want a D.P.S.T (On/Off) mini-rocker switch.
Apr 16, 2008 | Vacuums
My 12 year old Rainbow SE suddenly began a burning odor
My 12 year old Rainbow SE suddenly began a burning...
I think the motor may have burned out. Is that something I can replace simply? Or could there be another cause for the sudden problem. It is possible someone may have used the vac w/o water, as it was sitting out when some workers were in the house doing some renovations.
Thanks, Pam Thornton
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can replace the motor your self if you are mechanically minded but there are wiring problems and a gasket replacement and to also replace the spider (looks like a small bowl with vents on the side of the bowl) underneath the vacuum. It you mark the wires with tapes on each wires it can be replace but the motor is a $300.00 or better if you do it right and include the motor, gasket and spider. This price may include labor in a vacuum shop. The $300.00 is just an estimate and you would need to contact the local vacuum cleaner dealer in your area to do the replacement, it’s a good vacuum and if you like it have the motor replaced. Always use water when using the vacuum, the workers may have used the vacuum to pickup sheetrock dust of which will get into the motor and reduce the life of the Rainbow motor and will destroy any vacuum on the market, it plugs the spores of the cloth, paper and dirt cup filters of which need replacing.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Loud Grinding Noise
Take out the brush block and see if it will power on, if not then probably your motor has gone bad.
Feb 04, 2008 | Hoover V1 SteamVac SpinScrub Vacuum
Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum Logo
1,011 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Jim Parker
Jim Parker
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
