Networking problem I have two assmbled computer both have xp os,one computer consists two lan card another has only one inbuilt lan card with help of switch i make peer to peer networking my data sharin and application sharing is working properly even my all work run smoothly but at first computer with another lan card i connect my internet connection with sify broadband conection when i connect my internet my local networking fails to work it showas workgroup client but when i open client it shows you have not authority
Configure your local nw with static ip, might solve ur prob.
Posted on Sep 19, 2008
Five computers networked with Linksys WRT320N router. Operating systems: Win 7.0 on 3 computers (two hardwired)(one laptop - wireless), Snow Leopard 10.8 on 1 (wireless), and XP on one (wireless). Also...
Sometimes this problem occures when you install a later model wireless router.
Try installing the latest Wireless card driver on the XP computer and the LAN card drivers on the other computers except the MAC.
Dec 31, 2009 | HP LaserJet P2015n Printer
The internet providers technical person connected the cable and told me that your lan card is faulty so change it. my lan card is inbuilt on motherboard
Unplug your power cable; Take off your casing cover; make sure your hand is dry and clean, install your LAN Card to the right slot (Please refer to your Network Card Manual Book); Power On your PC, Press Delete at boot screen until u login the bios screen, go to the Advanced Tab on the top there, Select [Disable] for Onboard Lan; Then save & exit. You're done well! Congrat!
Dec 01, 2009 | ASUS M2A-VM Motherboard
Networking/Motherboard- does not recognize networking devices
Can't WinXP find appropriate driver for your lan card? If Asus did not provide a driver for its built-in lan, i think windows XP already has the driver built in its cache. try to install it using the wiz.
Regards
Jul 07, 2009 | ASUS P5GC-MX/1333 Motherboard
Can't connect to internet- wired network -2nd computer works fine - OS XP
I have installed intex 8139D RTL lan card drivers are installed.in divice manager it will showing the device is enabled. And it will showing lan is connected. but when i change from workgroup to Domain it will showing an error message. to communicate with domain.How to solve this problem.
Jul 05, 2009 | D-Link DFE-530TXP Network Adapter
INTEX LAN Card 8139D RTL problem
you need to download the driver for your lan card. If the LAN card came with your computer, go to the computer manufacturer website to get the driver
Jul 04, 2009 | Computers & Internet
How to share internet connection on Windows Vista OS. I want to share internet connection between two Laptops using Windows Vista Operating system and the other using Windows XP. The Host computer is...
All right let's call your Vista computer A and your Xp computer B. First you have to bring the two computers into LAN. If you already did this, please skip the next eight steps.
Step 1: In Vista, before doing this you should enable Sharing and Discovery. You can do that by going to Control Panel -> Network and Sharing Center. Under the section ‘Sharing and Discovery, enable Network discovery, File Sharing, Public folder sharing and others if you want to. (See picture below)
Step 2: If your LAN card that is connecting to another computer is installed, it will be shown under Control Panel -> Network Connections.
Step 3: Right click that local area connection and click properties.
Step 4: Under the tab ‘Networking’, click the properties Internet Protocol Version 4 (TCP/IPv4).
Step 5: Click the radio button to ‘Use the following IP’ and give an IP address (For example, IP address: 192.168.0.1 and Subnet Mask: 255.255.255.0)
Step 6: Don’t give any other information, Click Ok and close everything.
Step 7: In computer B, which is the XP, make sure you enable the LAN card which is used to connect to computer ‘A’. Here you need not give any IP information as Computer ‘A’ will assign an IP address dynamically. If it’s not working make sure there are no IP assigned and change the properties to ‘Obtain an IP address automatically’.
Step 8: Test the connection by pinging. (You can do this by typing ping 192.168.0.1 or whichever is Compter ‘A’s IP in the comand prompt)
NOW your computers are connected. Now to share the internet:
Right click LAN card which is connected to Internet under Control Panel -> Network Connections and click ‘Sharing’ tab and enable both the options to share Internet. (Note: Unless there is another enabled LAN setting you will not be able to see the shared tab under properties)
Click Ok and close. This option is given by the Windows OS known as ICS (Internet Connection Sharing).
Now you can use Internet from both Computer A and Computer B from a single connection.
So this is the setup you need on the Host computer as you requested, if you turn out to need help witht he XP one too, let me know:)
Feb 14, 2009 | Compaq Presario 700 470024-192 Notebook
Installing new Window xp and other devices didnt works
take the side of the computer off and look for the model number on your motherboard. you need to know if your using a network card or if its onboard Lan. if everything you need is onboard all you need to do is search your motherboard number on the internet and download the drivers. you need can select what you need, sound, lan etc. your goning to have to use a friends pc so you can download these files. when your Lan is installed go to the microsoft webpage and get the latest updates, that will solve the usb in your device manager
Sep 08, 2008 | Computers & Internet
Do i have a lan card installed on my system??
Just check it in the device manager ,, goto device manager by right clicking on my computer... if u have network adapters then u have LAN ... and if u have lan u don need drivers it will be inbuilt ...
Nov 30, 2007 | Compaq 2Mbps Wireless LAN PCI Card for...
Find and download a network adapter driver
well this is the link for you to download drivers for your compaq desktop
http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
just type your compaq desktop model no ...for eg.compaq presario v 6000..you need to know your model no in order to download drivers for your desktop pc...
for windows xp if you want networking between your computers attach your computers with cross cable and right click on my computer for system properites > there you will see computer name tab > there you will see network id button > click on it and run the installation on all the computers you want to be in network....
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
t
Thanks
dilipbagdi
Technical Associate
Sep 14, 2007 | HP 290563-B21 Network Adapter
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
