When the system boot up it say's error accured when loading,and it is asking for a logon. I have a gatewaysolo 5300 notebook. My other question is that it won'tread are play any CD,and there is no icon of a CD device displayed.
  • 61 Answers
Hi my name is samson so if i understand you during startup you get error occurred when loading if you are using windows try to run msconfig and disable the start up items to do that
follow this go to start click on run typer msconfig on the right top coner you would see start up and at the bottem of that windows you will see disable all click on it then apply and restart the system
for your second problem got to registry editor but typing regedit in run box and follow HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} to this path and delete upper filter and lower filter and restart the system and your drive will work
thnx regards
Posted on Sep 17, 2008
Error loading operating system
try pressing F8 at bootup, when the SAFE MODE window comes up, select boot in Safe mode desktop. When at next window, you are asked if you wish to go to desktop, or perform a System restore, choose system restore, when the next window comes up, like a calender, simply choose a time prior to the problem, follow instructions, and it will go through and reboot. This should get you back.
Mar 20, 2010 | Famous Brand Dell Optiplex GX280 Intel...
Acer aspire x3200 error reading "disk boot failure, insert system disk and press enter"
Check to make sure you don't have anything in your floppy drive. (3.5 drive or 5.25 if really old system).
If you can boot from bootable CD then probably your Hard Drive is not working and all other periferals are OK. If it is making clicking noises then the drive arm or the head is most likely shot and you need a new hard drive.
The one chance you do have is if your Hard Drive just needs to be made bootable again. Load up the XP cd as if you where to reinstall XP but instead goto the recovery console, type "fixmbr" at the command prompt once you have entered the XP logon, its very simple once you get there very well laid out.
Hope this helps. Best Regards,
Nov 09, 2009 | Acer Aspire X3200 PC Desktop
Blue Screen c000021a
Next step is remove hard drive and see if it is recognized in another computer. The Hard Drive could just be bad, but you need to rule out the motherboard drive controllers that could also be bad. Also try a known good drive in your system.
Char S.
May 27, 2009 | Dell Vostro 1510 Laptop Computer PC...
Cannot logon to system
Format and reinstall a fresh copy of windows xp.
You can try to use windows recovery console but it also asks administrator password.
Apr 26, 2009 | Computers & Internet
Error code 5300:0119
Can you start it in safe mode? If so, try to do a system restore.
Next do a start>run>sfc/scannow to see if there are any system files messed up.
Can't start in safe mode? Then try to boot from the system disk and at the first prompt to do a repair type "R". Then run chkdsk /r to see if this solves the problem. This will fix bad files.
Still out of luck? Then you are looking probably in the right direction when you suspect the video card.
Feb 17, 2009 | Dell Inspiron 531s Desktop Computer
Acer Aspire One Notebook - asking for password on logon
try clearing the cmos setup
your can do this by removing the cmos battery or you can try press "f" and "j" while starting the computer
Dec 26, 2008 | Computers & Internet
Boot sequence manual
When you hit the power button on your computer a whole lot of stuff happens. We call this the boot process. In the days when I first started using computers there was literally a "boot disk", a floppy (5.25" not a 3.5") disk that told the system where to go and what to do so that the operating system would start up. Since then the boot sequence has become somewhat more complicated. So let me take you thru the steps the computer takes to get started. For my example I'm going to use a Windows XP system.
  1. First is the POST, this stands for Power On Self Test, for the computer. This process tests memory as well as a number of other subsystems. You can usually monitor this as it runs each test. After that is complete the system will run POST for any device that has a BIOS (Basic Input-Output System). An AGP has its own BIOS, as do some network cards and various other devices.
  2. Once the POST is complete and the BIOS is sure that everything is working properly, the BIOS will then attempt to read the MBR (Master Boot Record). This is the first sector of the first hard drive (called the Master or HD0). When the MBR takes over it means that Windows is now in control.
  3. The MBR looks at the BOOT SECTOR (the first sector of the active partition). That is where NTLDR is located, NTLDR is the BOOT LOADER for Windows XP. NTLDR will allow memory addressing, initiate the file system, read the boot.ini and load the boot menu. NTLDR has to be in the root of the active partition as do NTDETECT.COM, BOOT.INI, BOOTSECT.DOS (for multi-OS booting) and NTBOOTDD.SYS (if you have SCSI adapters)
  4. Once XP is selected from the Boot Menu, NTLDR will run NTDETECT.COM, BOOT.INI and BOOTSECT.DOS to get the proper OS selected and loaded. The system starts in 16-bit real mode and then moves into 32-bit protected mode.
  5. NTLDR will then load NTOSKRNL.EXE and HAL.DLL. Effectively, these two files are windows XP. They must be located in %SystemRoot%System32.
  6. NTLDR reads the registry, chooses a hardware profile and authorizes device drivers, in that exact order.
  7. At this point NTOSKRNL.EXE takes over. It starts WINLOGON.EXE that in turn starts LSASS.EXE, this is the program that display the Logon screen so that you can logon.
Nov 05, 2008 | Computers & Internet
System passes the logon screen
Keep tapping the F8 key while you boot your machine, hopefully you will get a black screen with some white writting on it.
Using the up and down arrows select Boot Safe Mode without Networking.
Once you boot into safe mode go to programs>accessories>system tools>system restore and follow the wizard to restore your machine back to a time and date before you installed the modem software.
Aug 30, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
26 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
