Question about Carrier EACA 1400 Air Purifier
Carrier infinity air purifier GAPA
I just replaced the power supply for this unit and installed it and it still does not work. I have checked all groundings. It did work when i bench tested but installed it does not stay on
Check your door switch
Posted on Oct 25, 2008
Where is the backup battery?
portable battery backup power supply for macbook pro and air
www.clubfidelis.com/news/index.php?q...battery-backup-power...air
PORTABLE BATTERY BACKUP POWER SUPPLY FOR MACBOOK PRO AND AIR: PORTABLE BATTERY BACKUP POWER SUPPLY ... HT201700 I need a portableback up battery for my MacBook Air 11 . ... air purifiers that controls mold.
Battery Powered Air Purifier - Wag.com
www.wag.com/html/sg/battery-powered-air-purifier.html
... 365-day return policy. Buy Battery Powered Air Purifier at Wag.com. ... MarinaBattery Operated Air Pump .... Penn-Plax Air-Pod Battery Back Up Air Pump.
Amazon.com - Mini Portable Battery Air Purifier Air Ionizer ...
amazon.com/exec/obidos/ASIN/.../amztowps-20
Amazon.com, Inc.Amazon.com - Mini Portable Battery Air Purifier Air Ionizer For Small Areas - BatteryOperated Air Purifier.
Jan 05, 2016 | Air Purifiers
My honeywell HFD-015C air purifier wont turn on
Hello, this is Ava with Think Crucial.
You may check to make sure that the power cord is correctly connected to the outlet. Test the outlet is functioning properly using another appliance or lamp. Also, check the fuse or circuit breaker. The outlet may be overloaded if other appliances are also in use. Establish and correct the cause of the overload. If none of these works, then there is something wrong with your purifier unit and contact the store where you purchase it or Honeywell for replacement. It is advised not attempt to repair the unit yourself.
You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
May 31, 2014 | Honeywell 17000 Air Purifier
Does not produce ozone, I have replaced the fuse, it has been cleaned and the amber light is not on.
it's possible that the ozone generator inside has gone bad. The only way to really know is to remove it from the unit and then test it with a power supply w/correct voltage of coarse. You will smell the ozone immediately if it works upon testing. (clean fresh smell) If it does need replaced, it's an easy fix for anyone with electronics knowledge. You will need to match up the numbers to get the correct replacement. Many are available on Ebay. Always disconnect the power to the unit before taking it apart. Hope this helps, Dave
Nov 18, 2013 | Ecoquest Living Air Classic Air Purifier
Carrier 58MVC100 furnace no power. Tree fell on main power line and after power restored noting going on with furnace/air handler. LED is not lit. 3amp fuse appears to be good and there is a sulphur smell...
Possible that when power got restored you furnace might have gotten surged. replace fuse any way to be sure. Check break box for trip circuit. Call a tech from there man.
Aug 08, 2013 | Carrier Infinity 58mvc080 Gas Furnace 80k...
Carrier Infinity air purifier makes constant zapping sound when operating with door in place.
It sounds like static electricity being generated through the filters. I suggest you change the filters and see what happens!
Jan 10, 2013 | Air Purifiers
My oreck air purifier xl won't turn on
With the Air 8 Models there is a number of issues from the motor to the power supply to the circuit boards. With these old units it is hard to find parts for them. as oreck no longer manufactures them. but if the parts were availible i would estimate around 100 to fix your power issue
Sep 15, 2011 | Oreck XL Professional Air Purifier
Won't even power on. Replaced fuse, no go. Any suggestions? Might Office Space it if not. Or how much estimating would it cost to send to Eco and have them fix it?
Check the micro swtch in the back, it activates power to the unit when you reinstall the filter. the switchwill make a clicking noise if the filter is installed properly.
Apr 09, 2010 | Ecoquest Fresh Air Air Purifier
I have an F50f electronic air cleaner. none of the
you need to change the power supply please contact your heating and cooling contractor for service on the unit.
Mar 03, 2010 | Honeywell (F50F1032) Air Purifier
Hi, I have a question about Honeywell F300E
You need to replace the power supply of the unit, Contact your heating and cooling contractor for service on the unit.
Oct 06, 2009 | Honeywell Enviracaire Elite F300E-1019 Air...
Install Plate Displayed
Call toll free 1-877-710-0057 and they will gladly help you.
Jun 03, 2009 | Ecoquest Fresh Air Air Purifier
Carrier EACA 1400 Air Purifier Logo
835 people viewed this question
Top Carrier Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Carrier Air Purifier Expert? Answer questions, earn points and help others
