Question about Compaq Presario X1000 Notebook
Screen problem The problem with my laptop screen is that all of the content is shown in the top left quadrant of the screen while the top right quadrant and lower half of the screen are dark. Please advise.
I think try going to display setting under control panel. See if it allows you to change to full screen mode.
Posted on Oct 02, 2008
My TV has a severe flicker/jitter in the bottom left quadrant of the screen. How do I fix it?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 27, 2017 | Samsung LN-T5271F 52 in. LCD Television
How do you turn numlock on and off on the Dell 2110 netbook?
Dell Latitude 2110 does not have a numpad so it doesn't have a NumLock button,
Mar 07, 2011 | Dell Latitude 2110 Laptop Computer (Intel...
Why does Image on tv screen sags in top left
buy a new monitor its a problem with the photon beam
May 08, 2010 | Hitachi SuperScan Elite 802 21" CRT...
Multi-point convergence -- Lower left quadrant of screen distorted. Red ok. Blue arched up and then done to normal in Lower right quadrant; left-right adj moves vertical gridline but is s-shaped. Blue...
Look in users manual or internet you should find how to access service mode, this is different from regular setup CONVERGENCE, this involves getting into changing parameters to tweek convergence, even after amps are changed. These projection tv's are known for loosing convergence if bumped, moved and amps go bad in time.
Jan 03, 2010 | Pioneer PRO-520HD 53" Rear Projection...
Choose four digits, all different, and place them in a 2x2 grid so that the numbers across and down total 200. How do I do it?
A two by two grid forms four quadrants. In the upper left quadrant, place a 4. In the upper right quadrant place a 2. In the lower left quadrant, place an eight. In the lower right quadrant place a 5. Horizontally, the numbers 42 and 85 are formed. Vertically, you form the numbers 48 and 25. The sum total of these numbers is 200. 42 + 85 + 48 + 25 = 200.
Nov 11, 2009 | Mathsoft StudyWorks! Middle School Deluxe...
RRD
i unhook everything and cleaned the system and it worked fine
Oct 07, 2009 | Microsoft Xbox 360 Console
Infocus X2 projector, white vertical strip on right quadrant.
on the X2, the dmd chip is attached to the main board on the bottom of the machine. you need to take the top case off, as well as the 2 power supply boards. push the dmd chip (behind the lens assembly) back onto the board.
Jun 04, 2009 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Printer only prints in upper left quadrant of page!
how to refill the canon pixma iP1700 ink catritdges. how to use only black catritdges without colour catritdge in canon pixma printer
Apr 24, 2008 | Canon Pixma MP500 All-In-One InkJet...
Colors have seperated on top of screen
convergance ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Televison & Video
Compaq Presario X1000 Notebook Logo
64 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
