Question about Philips 50PF9630A 50 in. Plasma Television
PHILIPS 50PF9630A/37 THIS TV HAS GOOD SOUND BUT NO PICTURE,THE SCREEN IS BLACK WHAT COULD BE THE PROBLEM
  • 5 more comments
  • ESTEBAN MERINO
    ESTEBAN MERINO Sep 17, 2008
    CAN ANYBODY TELL ME WHAT'S WRONG WITH TV,THE BACK LIGHT WORKS,SOUND IS GOOG BUT THE SCREEN IS BLACK.
  • ESTEBAN MERINO
    I GET SIGNAL FROM ALL INPUTS AND OUTPUTS,IT LOOKS LIKE THE SCREEN ITSELF IT IS NOT TURNING ON
  • ESTEBAN MERINO
    WHEN I MEAN SIGNAL I MEAN AUDIO OF COURSE NO VIDEO
  • ESTEBAN MERINO
    ESTEBAN MERINO Sep 18, 2008
    hello, i tried everything and i still don't get anything,
    i hope someone can help with this problem
  • ESTEBAN MERINO
    ESTEBAN MERINO Oct 09, 2008
    I SOLVED THIS PROBLEM ABOUT 3 WEEKS AGO IF YOU ENCOUNTER THE SAME PROBLEM JUST LOOK FOR LOOSE CONNECTION ON THE POWER SUPPLY
    CAYPIANAN@YAHOO.COM
  • tlehr Nov 26, 2008
    i was watching my TV and then heard a small click the screen went black, I still had audio but no screen.
  • chouston May 11, 2010
    How are you getting video and audio signaling in to the tv?
Quick test of the plasma screen itself:
1) Turn on the TV
2) Try to bring up an on screen setup menu using the remote or buttons on the tv.
3) Does the menu appear? If so, the screen itself is ok.
If it doesn't come up you make have an issue with the screen itself. I am not sure it would be possible to set contrast and brightness settings such that the picture would completely disappear, but I suspect you should be seeing something on the screen just from having turned it on.
We also need to know more about what you have connected to the television. HD televisions typically have several inputs on them including HDMI, digital cable, VGA and component. Let's say for example you have PS3 connected via HDMI. You can tell the PS3 to send audio across the HDMI cable as well as video. You also have the option of running separate connections for your audio signal. It is the existence of these options that make it necessary to understand where and how you have things connected, very specifically.
Posted on Sep 17, 2008
I have a magnavox 26MF231D/37 lcd tv. It has good sound but no screen, just black. Turn it on and off aqnd it doesn't flash no anything. thanks
Either your inverter board or video board is bad. If you can see picture while the TV is on then its your inverter board. If not, video board.
Nov 05, 2009 | Philips 26MF231D 26 in. LCD Television
37" Philips LCD sound but no picture
Check the inverter on the sides of the TV. This sounds like the inverter is going bad and that's the reason why you have sound but not picture.
Jun 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Screen Issues
Looks like the gas needs sorting.Did something hit the screen?It looks like ink splotches does it?Bring it back to where you bought it if its still under guarantee otherwise it will be very expensive to get it fixed
Mar 15, 2009 | Philips 50PFP5332D 50 in. Plasma...
Philips 30PF9946 D/37
You have sound but no picture. Green power light is on and NOT flashing. You get a screen flash or flicker on power-up or even a minute of screen before going all black. It is your inverter board. Common problem on LCDs (maybe more so on Phillips?). They are easy to replace (unplug-plug) and are available on the net.
Veritas
Feb 24, 2008 | Philips 30PF9946 30 in. HD-Ready Plasma...
Open Questions:
Philips 50PF9630A 50 in. Plasma Television Logo
681 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
