Error on Elecrolux W355H washer
Machine starts in normal way, rinses powder from fist tray, starts cycle, but as soon as cycle 2 supposed to be started, machine stops with error 08E- "increase in water temperature is is below parameter set". Powder still remains in tray 2 dry .
What should I check first? PS: When selecting modes in manual, e.g. "pre-wash", "main wash", "rinse"- everything works OK. Water is heated up and so on. Error appears on the screen on automatic mode at the moment when program has to jump to another step of cycle. Seems to be program error?
SOURCE: Hotpoint Aquarius
I have a hotpoint aquarius washer/drier. I don't know if this will solve your problem but I know with mine, this almost always happens, the only way I can get it to start is by firmly pushing the door a few times around where the lock is, once I hear a little click inside it will start ok. I presume its because it wont start as it isn't registering that the door is closed, the only time it does not do this is if I literally slam the door really hard. Hope this helps you!
Posted on Sep 13, 2008
duby1990
  • 370 Answers
SOURCE: Is powder or liqued detergent better for front
They are trying to make money off you!!!!!!! LIQUID!!!! Dont ever!!! use powder soap in your front loader. Powder soap doesnt dissolve all the way and then gets into the bearings of the washer and eats them away! This caused about a 450 dollar repair for your repairman. Never use powder soap.
Posted on Feb 20, 2009
SOURCE: put washing powder in tray ,machine doing wash
Don't put the powder in the tray. Select you wash cycle, let the water run into the washing machine, then add the powder.The powder should dissolve before you put your clothes inside the machine. Let the washing machine fill up to almost half way and add clothes. This should stop the clothes from getting the residue powder on it.
Posted on Mar 23, 2009
SolutionGuy
  • 331 Answers
SOURCE: washing powder clogs up in drawer
There should be an adjustable "barrier" in the drawer. One for liquid and one for powder. Open the drawer and look at it carefully, you may need a flashlight. See where you pour the powder in? Well... you know what they say about pictures and a thousand words...
Since I don't have your model number, yours will probably look different than this pic,, but it should be close enough. All you have to do is set the barrier to the "Powder" setting.
SG
Posted on Mar 26, 2009
SOURCE: Washing machine doesn't comsume the washing powder.
use liquid detergent, less clothes, larger load size, or put the powder in first and let water fill up. u may want to mix up with your hand or like i do give a twist to the washing device to mix up better. but i did find this the problem when i used generic detergent for they go a little cheaper on the ingrediants try brand name like tide, or gain. cheaper not always better but i find these two work well for me and have a lasting scent.
Posted on Mar 29, 2009
No agitation on extra rinse cycle on Maytag Washing Machine MAV8557AWW
The manufacturer may have found there was little or no advantage to having agitation in the second rinse cycle so omitted it.
Jan 08, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
LE error on LG 2277HW
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Oct 15, 2012 | LG WM-2277HW Front Load Washer
Hi I own a Defy Automaid 600 and has never used fabric softener before. How do I go about
It's very easy- you pour it into the conditioner tray before you start the washer- like the detergent/powder- and (normally) the washer directs water into the softener tray on the (final) rinse.
A quick and easy way to find out which tray is which is to pull the detergent drawer out just so that you can see into it. Start a pre-wash (pre-wash detergent) and see where the water runs in, then advance to the main wash (main wash detergent) and observe. Finally start a rinse cycle and where the water goes in is where the conditioner/softener goes.
In a few cases I have come across, the pre-wash tray shares with the conditioner/softener part but the pre-wash powder goes in the front and the softener in the back.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 05, 2011 | General Washing Machines
Hey, in which dispenser number do you put washing powder and fabric softer 1 or 2? Thanks
1 is usually for pre-wash, 2 for washing powder and fabric softner goes into the section with the level indicator should be small square section with removable top.
Feb 28, 2011 | Hotpoint Ariston AW125 Front Load Washer
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
I have a Whirpool FL AWM285 800. Half way through any cycle it stops ( usually before it is supposed to pump out or rinse any water ) by turning the dial it it starts again but stops again when it has to...
CHECK TO MAKE SURE BOTH HOT AND COLD WATER ARE WORKING.IF IT TRIES TO FILL WITH COLD WATER LIKE FOR A RINSE CYCLE AND NO WATER COMES IN, IT WILL SHUT DOWN. THIS MAY ALSO EXPLAIN THE POWDER NOT DISPENSING.WHERE THE HOSES CONNECT TO THE BACK OF THE MACHINE THERE IS SCREENS YOU CAN CLEAN.GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 15, 2010 | Whirlpool AWM8143 Front Load Washer
There is baked on crud in the glasses after the cycle is over. I've cleaned the screen at the pump because it is clogged,and that fixes it, but it gets clogged again real soon. I also replaced the litle...
Run the washer on some empty cycles with the cleaning solution/powder/tablets you usually use. Also rinse the dishes etc before you put them in the washer
Nov 03, 2017 | Kenmore 16919 Built-in Dishwasher
The washer stops before the rinse cysle
That sounds like your lid switch. This switch is located on the top. Raise the lid, Looking down at the washing machine it is the little hole. If you push it down with your finger on mine it's grey in color. The problem is that the switch is not getting pushed down far enough. if you pull it down manually with your hand a little farther you should hear it click over and the machine might scare you as it starts up into the rinse cycle. You can purchase them pretty cheap online at any applince site.
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
