Question about InFocus LP290 1100 Lumen XGA LCD Projector Multimedia Projector
Infocus LP240 projector will not power up
The Infocus LP240 will not power up. WE had a power surge and that may have killed something. I have two of them with the same condition. In desparation, I switched lamps on each other and tried to power up without success. Can someone please help with a diagnostics guide and possible repair manual to figure oiut which component has blown and how to change it? Much regards, Lalit. I moved and hadn't started up the projector for awhile -- when I went to power it on, there was no response.  What could be possible causes for no light, no fan, no anything?  something bumped?  I'm at a loss.  Mine is actually the LP240
  • 1 more comment
  • ramanian Oct 16, 2008
    I do have the same problem, I am working on it. Any suggestions are extremely welcome
  • Lyle Nov 03, 2008
    I have the same problem with my LP240. Please email me at lylefc@gmail.com if anyone happens to find the solution. Thanks!
  • Anonymous Mar 02, 2009
    I have the same problem, also an lp240. Please email me at anicholson@co.lincoln.or.us
2 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: Infocus LP240 projector will not power up
if you don't even get an led, it's the power supply. it may just be the fuse on it. take the top off and see if the fuse is blown. but make sure to replace it with the exact size and type.
Posted on Aug 03, 2009
Infocus LP240 fan shuts off
If you want you can check the voltage at the power conector on de main board. but the problem are the fans, replace the fans, and check the routing cable, its very important.
Jun 25, 2010 | InFocus LP 240 Multimedia Projector
Lp240 projector
power supply is bad and needs to be replaced. unfortunately, there are no parts for this model. infocus no longer sells them, and they were made by another company that no longer makes power supplies. therefore, no schematics either. sorry.
Dec 21, 2009 | InFocus LP 240 Multimedia Projector
Projector LP240 has no power
replace the power supply. the caps go bad on it after a while. you could get the part from and infocus service center and do it yourself or send it in to them and let them repair it. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 11, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP240 Projector won't turn on.
there is a fuse on the power supply next to the plug (on the inside), but this model of projector has power supply issues. the biggest being that infocus no longer has parts, schematics, or component cross references for the lp240. the circuit boards were made by another company that made had their own components and now no longer makes circuit boards (they make fans and bearings), and they have no schematics either. so, i'm sorry to say that the machine is doa. there are no replacement parts available and almost no way to fix the old ones.
May 19, 2009 | InFocus LP 600 Multimedia Projector
Sound from an InFocus LP240 Projector
it's just a line level signal with a 1/8" stereo phono jack. there is an amp and speakers in the projector, but they're meant for presentations, so there's not much to them. but there is no audio out coming from the projector, so you'd need a separate amp and speakers coming from the ps2.
Dec 28, 2008 | InFocus LP 240 Multimedia Projector
Infocus LP240 Projector
The bulb won't do that. What you're describing sounds like a light tunnel failure.
Feb 05, 2008 | InFocus Lamp Projector Lamp for LP240 [...
Jun 16, 2007 | InFocus LP210 Multimedia Projector
169 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
