Question about Cameras
I have a conon SD600 which will not power up, battery seems to be OK.
  • 45 Answers
Try to see if the micro switch under the battery cover is not damage. usually this switch cause problem in power up the camera.
Posted on Nov 03, 2009
My cannon power shot sd600 viewer doesnt turn on
Sounds like you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD screen on and off to save batteries. You would then use the optical viewfinder in its place. Try pressing this button one more time to see if it turns back on.
Oct 13, 2009 | Canon PowerShot SD600 Digital Camera
Battery fully charged. but canon powershot sd600
Your problem may be due to worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Sep 26, 2009 | Canon PowerShot SD600 Digital Camera
SD600 stuck in Video Recording mode
This worked for me. Take out battery and card. Wait a few minutes. Set camera in Auto (stil pic) mode. Replace card and battery, turn on. Select function, tab through all options returning to auto. Press function. This seems to be working, Let me know how this works for you. I found nothing on the Canon site. A sad commentary on the company.
May 31, 2009 | Canon PowerShot SD600 Digital Camera
Battery pack or charger
Hi!
When you insert the battery , plug the power into the charger and the light turns ON (red or green) - the charger is OK. One indication that the battery is dead is when you charge it, after just a few minutes the full charge indicator will turn ON ( with Canon chargers the light for full charge is green). If that's the case, purchasing a new battery is the only option.
Have a nice day!
Oct 02, 2008 | Canon PowerShot SD600 Digital Camera
My powershot sd600 elph, won't power up. brand new battery, why?
smtimes new battery also may have problem of low power....
u should try it another camera and see it works or not....
if again same problem comes then definately get damaged....
if it runs good in nother camera then i think there is still havin sm problem in urs camera....
show it to ur dealer for more infomation....
Jun 08, 2008 | Canon PowerShot SD600 Digital Camera
POWERSHOT SD600 WOULDN'T SWITCH ON
Hi , try to remove memory remove battery from partment clean contacts and assemble again .
Mar 22, 2008 | Canon PowerShot SD600 Digital Camera
Canon sd600 lens error
Manually rotating sensor rotor inside camera and cleaning gear fixed the Canon "lens error" for me.
I placed instructions with photo's here: http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/
Aug 22, 2007 | Canon PowerShot SD600 Digital Camera
Cameras Logo
27 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
