Fujitsu Plasmavision P42VCA30EH 42 in. Television Logo
Anonymous Posted on Sep 21, 2011
No sound coming from TV....recently relocated and ran TV from cable box, have lost remote to TV and now cannot get sound to work...picture good just cant get sound?
Anonymous
Level 2:
New Friend:
  • Expert 106 Answers
  • Posted on Sep 21, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
106
Questions
0
Helped
20834
Points
327
I think you are muting the the remote before you relocated...you need a remote to un-mute the sound of your TV...this cannot be done using the volume control in your TV unless you have the remote...if you loss the remote...buy a universal remote control
I was trying to set the cable box so the remote that came with the cable box would opert the tv and i lost the picture . the blue button comes on and off but no sound or picture the remote that come with...
Make sure you are on the correct input on the television and that the cable box is on. Do this manually. Hopefully you will get picture and sound again. If yes, then check the cable company website for the remote codes for your television manufacturer and the instructions for programming. Often times there are multiple codes for each brand so be patient.
My tv won't work after I shut it off using the remote throught the cable box
You need to turn on the cable box again. Make sure to select the right source again for your tv.
Philips pronto remote problems
Refer the user manual to your set-top box for details.
3helpful
2answers
OLEVIA 65 LCD 265TFHD TV. Has no sound
if your using a cable box and an HDMI cable there should be an option under settings for audio output format. you need to turn the audio on for the hdmi option.
1helpful
I cannot find picture controls for my tv? No sound controls button either!!
On most TVs, all the picture and sound adjustments are made through on-screen menus. To get to them, you need the original TV remote control (or a compatible replacement) with the proper MENU functions. On some sets there's one main menu to work through, while others have separate buttons for picture and sound control settings.
Some brands and models of TV have a front-panel menu button. Maybe yours does. Sadly, though, many sets now have just a power button and need the remote control for everything else. The biggest trouble I find is that people get used to using the remote that comes with a cable box, satellite receiver or similar device which will turn the TV on and off but that's all. The original remote mysteriously gets lost (I've actually run into people who threw the original control out because they didn't think they needed it), and then you find you can't get at any other TV settings. It's especially annoying if you can't switch to another input, say for a game console or DVD player.
Hopefully, you still have your control. Good luck, and thanks for using Fixya!
We do not have the remote,we do have a radio shack 8 in1 univeral remote.which worked good until, we lost sound and picture,can not get into the program.channels change on screen.and home theater shows up...
I removed coxail cable from the tv and connected 3 rca cables between tv and cablebox, now have picture and sound.The problem is still there ,something has blocked out my internal cable connection.
thanks Roy
Toshiba 36AFX61
Just Connect signal to tv and run autoprogram. Or use video input jacks from converter to tv ( yellow,white and red video in ) and select tv/video on tv pannel front ( don't need remote control) I hope this work for you.
How to set the telelvision to use a dvd,
when you ran the autoprogramming it scanned all the channels you are receiving.the dvd is probably plugged into a line or aux input on back of your tv.look for a input or source button on the remote. some tv's have more then 1 input source so be sure to scan thru all input choices.also if it is a dvd/vcr combo & if there is a coax out connection to your tv coax/rf input the tv and/or cable box should be on channel 3
hope this helps
w.g
3answers
X2Gen MV37R Flat Panel TV Sound & Universal Remote
check to see if another major brand produced the tv, like lg produces westinghouse stuff, and see if the other brand works
Top Fujitsu Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
