Replace toner Issue.I install it more than 6 times,after fixing it than it can print only 20 copy than again show the same Error Replace toner .How can it fixed it permanently.Hellppp.!
There are a few potential reasons why your copier might be printing faint copies:
Low toner levels: If the toner in your copier is running low, the copies it produces may appear faint or light. To fix this issue, you will need to replace the toner cartridge.
Dirty or clogged nozzles: If the nozzles on your copier's print head are dirty or clogged, they may not be able to produce a full, even layer of toner on the page. To fix this issue, you can try cleaning the nozzles or running a nozzle check to see if any are clogged.
Wear and tear on the print head: If the print head on your copier is worn or damaged, it may not be able to produce copies with the same intensity as a new or well-maintained print head. In this case, you may need to replace the print head to fix the issue.
Incorrect print settings: If the print settings on your copier are set to a low quality or low density setting, the copies it produces may appear faint. To fix this issue, you will need to adjust the print settings to a higher quality or density setting.
If none of these steps resolve the issue, it is possible that there is a malfunction or defect with the copier that will need to be addressed by a professional. In this case, you may want to consider contacting the manufacturer or a customer service representative for further assistance.
Try cleaning the corona wire on each toner cartridge. This may help solve your solution. If this does not help try another thing. Try and replace the toner cartridge. Maybe your toner cartridge needs to be replaced. Usualy when printed images are light or pale a toner cartridge replacement is recommended. To see how to replace your toner cartridges check here
Ever time I have seen this error it is caused by the toner cartridge. Sometimes just removing and re-installing the toner will fix it. If all else fails just replace the toner cartridge.
Good Luck and Thank You for using Fixya.
WheatlandServices
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
There's no manual for "machine error 7C" in Bro IntelliFax 4100. To fix this issue. You will need to pull out the toner. Note: the toner and drum are connected.....At the left corner of the drum. You will see a blue tab......You will need to slide the blue tab back and forth for 20th times....And put the toner back in its place.....This is just a temp fix but you need to replace the drum to have it working its fullest......
