Question about KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher
Kitchenaid Dishwasher thermal fuse keeps blowing
Our dishwasher quit working midstream. Before I knew about this site we called a repairman who charged us $184 to change the thermal fuse. After two weeks of low use the machine stopped again midstream. Although the repairman had a "30-day guarantee", we can't get him on the phone. (That is another tale.) We bought a thermal fuse kit and my husband changed it yesterday. Last night, during the first use, the dishwasher stopped midwash again. Obviously something is occurring that is causing the fuse to blow. Any suggestions?
Thanks!
  • treemader Sep 17, 2008
    Moving the dishwasher is not possible. It is a built-in and we can't just "move it to a new location". Also, the machine worked fine for almost 6 years. This is a recent problem.
  • Lee M Jan 05, 2013
    I have a KitchenAid dishwasher that ran 7 years and 11 months and it just blew internal fuse for the first time yesterday. Fuses blow because of a high current. I set up an amp clamp to read the current flowing into the dishwasher, bypassed the fuse (only for constantly supervised testing) and watched the current draw while the dishwasher started a wash cycle. My ampclamp wire seperator breaks the groundwire path. Putting my DVM between the dishwasher frame and the coldwater ground showed 50 volts while the dish washer ran. But with a 10 megohm impedence, 50 volts is only 5 microamperes and I saw 6 volts with the dishwasher off. Putting in the new fuse and running the dishwasher I note the unit stopped only at the end of the entire dish washing cycle which is when the heating element turns on to steam dry all the dishes. Heating element testing is my first target when I go back into this dishwasher.
  • 2,326 Answers
The reason the thermal fuse is blowing could be due to a loose contact in the wiring or the motor is requiring more power to operate causing the fuse to burnt again.
Posted on Sep 17, 2008
    Sergeant:
  • 399 Answers
It indicates the problem with power supply.
also check out for any short tracking which is causing this blowing of fuse again and again.
for any further queries feel free to ask.
thanks
    Genius:
  • 3,422 Answers
If your dishwasher doesn't work at all, check these:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
    Guru:
  • 1,894 Answers
If your fuse is blowing often i would suggest you to move your washer to a different place and try a different plug point.
there may be some fault with your power.
try to sort it out step by step.
thank you
  • dewan nafees ahmed Sep 17, 2008
    also check your circuit breaker panel for the fuse problems.
Kitchenaide dishwasher KUDS25SHBS1
I have listed COMMON problems / reasons why a dishwasher won't start..
The thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Dec 15, 2013 | KitchenAid Dishwashers
The start button on my KItchen Aid Built in Dishwasher KUDI01FLSS2 will not start, there is power and the control lock is not on. It just will not start
I had the same problem although my dishwasher quit working in mid cycle. Once it quit, there was no power to the unit. I replaced the thermal coupling fuse and that solved the problem.
Dec 27, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
My Kitchenaid dishwasher is not turning on. I hired a repair man who charged me $108 to replace the fuse. The dishwasher worked for a few minutes, but then failed before the cycle was over. He then said...
something is blowing the fuse==a direct short somewhere. I would never use that repair guy again, $288 later, dishwasher should work. just trying parts is not a repairman, its a parts seller. if you cannot find the short, not worth replacing parts. and obviously 288 almost buys a new dishwasher. good luck and call his boss and complain about the repair and ask for your money back
May 05, 2017 | KitchenAid 24 in. KUDS01DLSS Built-in...
BI METAL THERMAL CUT OFF SWITCH KEEPS BLOWING.
You might have debris clogging the drain/disposal. My wife just tried to wash labels off of some old jars, the paper is stuck in the drain and my TCO is blown.
Jun 04, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
Lights are on, but dishwasher will not start. Called a local repairman. He decided the control board failed. he ordered a new board and replaced it. Now he says the new board is defective. I think...
That model has an electronic thermal fuse that clips onto the control board housing. the dishwasher will not start if that fuse is blown. you can check it if you have a meter. If it has continuity through it, its good, if no continuity, replace it. They cost between $20-$30. If that is not the problem, I would be looking at that motor. Kitchenaid makes a great dishwasher, but I can't count how many motors I've had to replace in them. Hope this helps, good luck.
Oct 16, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
We have apartment size dishwasher which quit before finishing cycle and will not come back on.
It could be any number things that have gone wrong, anything from blown fuses, blown thermal cut-outs, sticky valves....etc.etc. you really need to call in a repair guy to check it.
Have you checked the outlet that the dishwasher is connected to... it may be a bad outlet. (that happens all too often)
Oct 06, 2009 | Frigidaire Dishwashers
Thermal fuse keeps blowing
Mr. Larry (guru?)
The thermal fuse is just that It doesn't protect the circuit from over current although it certainly can open in that case. It is there to protect the board from overheating , thus the term thermal. The dishwasher could be allowing the water to heat too hot or the water heater in the home is turned up too much. The heater could also be shorted to case thus allowing it to be on even though the control is not calling for it especially if the polarity is incorrect to the dishwasher or the relay on the board could be welded closed so that the heater can't turn off even though the thermostat is satisfied. The best thing is to get a person who can check these things. You don't necessarily need to change the board with a fuse. I have changed many fuses with no other problems and verified that the machine was still working years later. sometimes the fuse just blows!
Dec 02, 2008 | Dishwashers
KUDIO1ILBS2 KitchenAid Dishwasher, two years old, not heavy usage: control panel is dead, no other power problems in the apartment, the apartment's electical box shows all breakers ok.
These dishwasher have a thermal fuse near the contol panel protecting the heat sensitive computer. Do you use the Sanitize or Anti-bacteria cycles?? If so then these cycles get very hot and could have made the fuse blow. Kitchenaid also had some loose connection problems at the fuse making the fuse heat up due to the electicity and not actual temperature. The new fuse comes as a kit with connectors already attached to the fuse (dont mess with them) and a junction block to splice the wires.
Jan 18, 2008 | KitchenAid 24 in. KUDI01ILBS Stainless...
KitchenAid kuds24se dishwasher DOA
We had same problem - took dishwasher out from counter and found it to be unplugged way way in the back 1
Sep 21, 2007 | KitchenAid KUDS24SE Built-in Dishwasher
Kitchenaid dishwasher just quit mid cycle?
Check your thermal fuse. The fuse is located inside the control panel on or near the main control board. It will be a bullet shaped component mounted with a white plastic clip with two wires leading from it. The fuse should read a short if good. Now...keep in mind, if the fuse blew it is usually for a reason. Replacing it may or may not correct your problem. In some model dishwashers there was a thermal fuse kit that was required to be installed which involved cutting the wires and using a wire splice to connect the new fuse. It seems that there was a design flaw where the gauge wire used in manufacturing would cause the thermal fuse to blow prematurely due the wire overheating. I can't remember if this applies to KitchenAid, but I believe it does. You may inquire about this at your local parts store. I hope this helps you.
Aug 15, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
KitchenAid 24 in. KUDI01TJ - Multiple Color Built-in Dishwasher Logo
1,810 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
