I have an Emerson Strawberry Shortcake television set the settings are messed up...PLEASE HELP???
I have no idea what my daughter did to my television set? We have an Emerson strawberry Shortcake television set and a HarmonTec dvd player, well for some reason the dvd remote works somewhat on the television set! My daughter somehow messed up the settings from the dvd remote and i have no idea what the original settings are suppossed to be so i can change them back! For example page one of the settings say H-Phase and has a 15 beside it? I have a bunch more of setting names that i don't know what to do with? There is 11 pages of different settings i can not figure out which ones she changed....PLEASE HELP!!!Thanks Shanon
JMuskovitz
  • 135 Answers
SOURCE: Need Help Setting Up DVD player to an old Zenith Television
You can find the owner's manual for this set online at: http://www.zenithservice.com/gcsc/b2c/hpi/main?tc=owm.command.OwmCmd It says that the BOTTOM four connectors are: 1. S-Video IN 2. Video IN 3. Audio (Right) IN 4. Audio (Left) IN Above the Audio IN connectors are two audio OUT connectors, which you could hook to external speakers, your stereo, etc. But these are not needed for hooking up your DVD player. From your DVD player, you need to hook up either the S-Video or Video connection (Video is typically the Yellow wire), plus the Audio connections (Red and White). If your DVD player has an S-Video output, this will give you a better picture than the standard Video connection. S-Video cables have a different plug, with four or five wires in the connector, and are keyed so they only fit into the socket in one orientation. Be careful to line it up properly and not force it in the wrong way.
Posted on Feb 28, 2007
  • 105 Answers
SOURCE: restart ss-2250 strawberry shortcake dvd player after prog. scan snafu
You should be able to simply shut the unit off, & turn it back on after a few minutes. This will reboot the player & it should perform normally. If this fails, look for a tiny reset switch somewhere on the unit. It will be marked, but may be a tiny hole with very small lettering, that requires a pencil point to activate.
Posted on Jul 18, 2007
PERS_Malta
  • 45 Answers
SOURCE: Not Receiving Cable Signals
100% you have or a faulty tuner inside that has to be checked for dry joints or it has to changed completely. Patrick
Posted on Aug 27, 2007
TVtechmaniac
  • 140 Answers
SOURCE: FPA lock settings, No remote, can not power on TV
If you forget your password you can reset it. Make sure the TV is off. Simultaneously press and hold VOL< on the TV?s front panel and CLEAR on the remote for approximately 5 seconds. Enter a new password next time you access the PARENTAL CONTROL menu. Front Panel Lock 1. From the PARENTAL CONTROL menu, press the up or down arrow to highlight Lock Fr. Panel. 2. Press the right or left arrow to turn on (box has check mark) or off (box doesn?t have check mark) front panel lock. Of course if you don't have a remote that can bring up the menu I don't know how this can be done.
Posted on Sep 13, 2007
ebrus
  • 30 Answers
SOURCE: Emerson Spongbob tv broken remote...cant change input?
Then the only way to reach your tv is through coaxial antenna port. So you can buy an rf modulator ( very cheap) and connect your red yellow and white cables (rca cables from a dvd, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me.
Posted on Oct 15, 2008
Should you cut fresh strawberries to freeze or freeze them whole
I have found either way is fine. I leave them whole if I'm going to use them for a particular dessert and I think it would make a better presentation. If I'm going to make strawberry jam, jelly,syrup or even shortcake sauce I cut them in half or quarters.
Feb 23, 2014 | Cooking
Which flavor cake is best for party?
I think strawberry flavor is best for any birthday party.Most of people like strawberry flavor.You can arrange a strawberry flavor best cake.If you think its not good for your party then you can arrange different types food.I am suggesting you a link.Here have many treats idea for birthday party.You can try it
Treats
Feb 07, 2014 | Kidkraft Birthday Cake Set ~ Childs...
Daughter messed around with settings put in pin lock and then phone asked for pin which my daughter forgot and now phone is asking for puk code pls help
The pin code is for the SIM-card
Contact your service provider for PUK-code.
This is your solution! Please remember to vote!
May 10, 2010 | Cell Phones
Univseral Remote Code for SS213 TV
I don't think there is a Direct TV remote code for this type of television. (Strawberry Shortcake). I'm assuming the reason is because this is such a cheap, generic tv that Direct doesn't recognize it. "Strawberry Shortcake" isn't as big as "Hello Kitty" I guess.
. This is sad because even though the big, pink power button has popped off to where you have to press the little rubber nub, my daughter has been using hers for well over two years where many reviewers have given the tv model bad reviews of breaking down after only 6 months. Hers did not come with a DVD player, although it IS a SS213 model.
May 07, 2008 | Spectra SS213 TV
Strawberru shortcake tv turns on then right back off
Sounds like the power supply may be going out, or check and see if there is a circuit breaker button on the back. Otherwise there may e a blown fuse that is internal. Don't open the back unless you have training on what is safe to touch as the picture tube can maintain a HUGE electrical charge that can stop your heart if you accidently touch the wrong thing. Sounds like a weak power supply tho. Jay
Jan 15, 2008 | Spectra (SS213) 13 in. Portable Television
Parental password unknown
Cindy, the code is 8888. My kid found it by trial and error. Good luck. Jose
Jan 03, 2008 | Emerson SpongeBob SquarePants TV
Need tv code for a Spectra SS213 TV (Strawberry Shortcake) Just had Dish Network installed. I would like to turn the Strawberry Shortcake tv on and off
Codes are hard to come by for this brad as it more than likley is s a sub brand for a major mfg. however you can take your dish remoter and use a powerscan to find a correct code. do this by holding down the SAT button till all lights light up at the top, then enter the code 500 then press pound, Now press the SAT again till they light up then release, then press teh big red power buton once, then press teh blue up arrow onece every 2 seconds until you tv shuts off, ( dont go to fast or you will pass up code. as soon as your tv shuts off, press the pound key and your ready to go with power and volume.
Sep 20, 2007 | Televison & Video
Aug 26, 2007 | Spectra SS213 TV
Restart ss-2250 strawberry shortcake dvd player after prog. scan snafu
Jul 09, 2007 | Spectra Strawberry Shortcake DVD Player
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Electro Med Services...
