Duplexing problem on Konica Minolta Bizhub C650
I am trying to get my c650 to duplex print on pre-drilled, 3-hole punch paper. (We do not have the 3-hole punch add-on to the finisher.) It keeps flipping the pages the wrong way. It prints single-sided with the holes on the correct side, but double sided it flips the image the other way and the holes end up on the wrong side. I've tried selecting the binding edge and changing several other settings with no avail.
Also, if it's an uneven number of pages, the last page (which would be single-sided) prints opposite of the other pages. If they all printed on one side or the other, I could just turn the paper in the tray, but they don't.
  • ckleinholz Sep 17, 2008
    That helps limit where to look to fix it. Thanks. Unfortunately, running everything single sided isn't a viable option and we don't have the optional finisher with the punch. (However, I'm going to strongly suggest adding it to my management team).
  • ckleinholz Nov 03, 2008
    We found a solution that is a bit unorthodox. If you turn the three-hole paper in a landscape direction in one of the upper paper trays, but print your documents in a portrait orientation to that same tray, it works. When the software flips the paper to fit, it flips it correctly this way and, as far as I can tell, only this way.
    I'm sure it's a software glitch as Bubbabear64 stated. This fixes the issue, but you do have to sacrifice a paper tray that could be used for legal or tabloid sized paper. We don't run a lot of legal, however, so I'm just forcing people who do to use the bypass now.
    I which my company would pay the extra to have the finisher with the punch on it, but they won't. Until then, I guess we'll keep tricking the machine.
  • 2,794 Answers
This is a software thing.  Usually if you use the hole punch in the finisher this doesn't happen.
Try putting the paper in the other direction and see if that fixes it.
If it doesn't fix the problem you will have to run one side at a time.
Posted on Sep 17, 2008
Konica minolta c650 error code c-0105 clear
check the paper trays 3 and 4. jam paper behind the trays????
Jan 01, 2017 | Konica Minolta BizHub C650 Copier
C-0105 clear
Check the paper trays 3 and 4. jam paper behind the trays????
Bizhub c650 cyan toner chip error
Take the cyan image unit out, clean the contacts on the chip remove any oil from your and interfering with the electrical contacts. Is the toner cartridge Third party or OEM??? if third party get a OEM. Sure it does not say Cyan Image Unit not Toner Cartridge?
Aug 30, 2015 | Konica Minolta BizHub C650 Copier
Konica minota c650 Printing balck baground copies
replace the black image unit. and ensure modification lock is installed to ensure proper connection if you pull out the black image unit is there black developer piled up in the rear???????
Jun 20, 2015 | Konica Minolta BizHub C650 Copier
Konica minolta bizhub c650 tray one paper jam
Replace the rollers? sensors is/are bad. PAPER behind the draw?
other trays OK? using correct media?
Jul 10, 2014 | Konica Minolta Office Equipment & Supplies
I am trying to print a 2 sided booklet and it says my duplex is not installed. How can I install it?
Does your printer have an optional "duplexer" ?
It's an extra-cost hardware option to "flip" the paper over, and feed it back into the printer, to allow printing on the "back" of the sheet.
Buy the duplexing hardware, and connect it to your printer.
May 28, 2010 | Konica Minolta bizhub C351 All-In-One...
Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Jan 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
701 people viewed this question
