Garden Logo
Arthur Wilson Posted on Sep 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is it 25/1 petrol and oil for a sthil blower bg85 thanks
Anonymous
Level 2:
  • Expert 252 Answers
  • Posted on Sep 21, 2011
Anonymous
Expert
Level 2:
Answers
252
Questions
Helped
173578
Points
510
Hi artwill3544
no
using sthil 2 stroke oil mix at the rate of 50:1 that is 20 mils of oil per 1.0 litre of petrol that you mix , or if you mix 5 litres you would pour in 100 mils of 2 stroke oil into a 5 litre petrol petrol can , then add 5 litres of petrol only and give good shake to mix , then fill your blower with that mix
cheers pauly46
Stilh bg55 spark plug setting
Hi
Stilh recommend 0.020 inch (20 thou), however I have found that 0.025 (25 thou) or 0.6 mm provides a better start and run arrangement.
Regards
Jacko from down under
Is a Victa Sunbeam 160 Special a 2 stroke or 4 stroke? Wondering what additive to use with fuel. Thanks so much for your help.
hi there tanyajames88
your victa is a 2 stroke vc160 these units sare stated to run 25:1 fuel / oil ratio
that is 40 mils of 2 stroke for every 1.0 litre of petrol that mix
so if mixing 2 litres - 1st put in 80 mils of good quality 2 stroke oil then put in 2 litres of petrol , give good shake and fill up your mower tank
2 stroke oil that you would use for sthil chainsaw would be ok its hi quality
you could use some fuel stabilizer additive to hekp stop mix from going stale too soon
if wish but most times just mix enoyugh mix to het job done , then mix more if need it
that way mix is always fresh
vheers pauly46
May 29, 2011 • Garden
2helpful
2answers
What is the fuel mixture?
hi there
pfrolander
the ratio of oil to petrol you should use is 50:1 ( that is 20 mils of hi quality 2 stroke oil per 1.0 litre of petrol you mix ) using hi quality sthil / husqvarna 2 stroke oil
1000 divided by 50 = 20 mils of oil per 1.0 litre of petrol
NOTE if you do not have any hi quality 2 stroke but some from your local garage ( that you may use in say a scooter for example use 40 mils of oil per litre it is richer
this will do the job
cheers hope it helps
1helpful
Need gas misture ratio for trimmer SRM2501
pauly46 here
the ratio you should use is 50:1
that is 20 mils of 2 stroke oil for every 1.0 litre of petrol that you mix
so if you want to make 2 litre mix use 40 mils of 2 stroke oil , then add 2 litres of petrol only and give good shake
note use good quality 2 stroke oil , such as sthil or husqvarna oil from your outdoor power shop
but if using general 2 stroke oil from a garage use 40 mils of oil for every 1 litre that you mix
this ratio is 25:1 this mix is on the richer side
cheers hope this helps
May 01, 2011 • Echo Garden
What is the fuel mix for 359
hi there troyandbec
pauly46 here
What type of oil does the poulan pro BVM 200 EL use and is the gas:oil ratio 40:1?
use - husqvarna , sthil brands high quality 2 stroke oil
as directed on bottle 50:1 that is 20 mils of oil for every 1.0 litre of petrol that you use
if you want 2 litres mix put in 40 mils of oil into petrol container
then put in 2 litres of petrol only and give good shake and fill the blower
cheers
Ryobi 30cc trimmer won't run. Difficult to start, hard to keep ru
chnge the plug for the best you can get then depending on the mix petrol oil mix u could cahnge that ie if its 50:1 go down to 40:1 or visa versa if that doesnt work bin it and get a sthil or an ehco
2helpful
I have a homelite f2020 series petrol trimmer i would like to know the petrol and oil ratio mixture please
I use 50:1 with Sthil 2-stroke oil in ALL my 2-stroke equipment. This ratio does not smoke at all, and does not foul plugs.
Never had a problem yet. At this mix ratio, you can also use it in 4-stroke engines, which means you only need 1 fuel can on site. Also eliminates the possibility of using the wrong can to fill the trimmer.
Top Garden Experts
Jay Finke
Jay Finke
john h
