Question about Microsoft ChiMei CMV938D 19" Widescreen LCD Monitor
22" Hanns G can't config..driver issue? Some of the pages look ok but the resolution is maxed at 1680 x 1050 (per tec support) and although it real sharp everything is like 14 point.
  • 3 more comments
  • sickonicknam Sep 17, 2008
    Thanks for the idea but I would like to maintain a sharp resolution. I'm just wondering can you have that and not go the other way(600x800) to get a full screen. Every page now has 3" bars on each side and small type. The "Fixya" text above is like 12 point or something. The disc that came with the monitor had a Vista driver and I'm still trying to hang onto XP. Do I need to upgrade the OS for this d*mn monitor??? (will purchase seeing eye dog tomorrow)
    thanks!
    Ok, thanks for the efforts folks, seriously. Yep I've done everything "desktop" and I've got the Intel 946 GZ chipset. It's all respectable. Microsoft wants me to load Vista. HannsG says it's Intel's problem. BTW, you have a hellacious popup ad that sits right in the middle of the answer screen. Total hassle. Nuke it and it pops right back....Not sure I paid 10 bucks for that...whatever. It's all good I guess. thanks.
    Thank you libra_eng and others for trying to help. I would enjoy posting "problem solved"...wish I could.
    -I called the computer manufacturer and got all the specs (motherboard and chipset/excelerator etc. Nobody knows what to do. Drop the resolution and get fuzzy type...pretty much it. I'm going back to the guy who sold me the Hanns G and since he's a computer repair shop maybe he can help??
    I need an Advil.....
    Thank you. No kidding, a video card?? Ok, great. Can I just go to a shop and buy one or do I need to take the computer or what??
    Why didn't these guys mention the video card...weird. Sounds good.
    -thanks!!
    well, i don't know yet. but if the suggestion works it's great!! thanks
  • 2,071 Answers
Recent Hardware Changes. Corrupt drivers for any recently installed hardware can crash the system. To get rid of the corrupted drivers, do the following:
a. Uninstall all recently added hardware.
b. Try to restore the system to a previous restore point
c. Reboot the system and return to a previous stable configuration if possible
d. Remove all external peripherals (printer, cameras, scanners, etc) and connections until the computer returns to normal. 5. Bad video/graphics card. At this point, if your computer is still under warranty, its time to call for help. If not, you can get a computer geek to come to your house (it is cheaper to take your computer to their store) or try to fix the problem yourself.
a. Is AGP/PCI video card compatible with your operating system? If you are experienced with opening up the chassis and resetting cards, reseat the video card, and try again.
b. Check the pins on the cable connectors and see that they are not bent or broken.
c. Never attempt to open the monitor. Turn on the monitor and try to reboot the computer again. If this doesn’t work, go to Step 6.
6. BIOS – the Binary Operating System may be corrupted – Use of Safe Mode to boot system.
a. Try starting the computer in the safe mode. Restart the computer and see the point to which it boots up before you get the blank screen.
b. Press F8 as the computer starts to boot. (For HP and Compaq computers with VISTA, use F10, For HP Pavilions with XP or earlier version of OS, use F1). Use the arrow keys to select the safe mode and press Enter. Remember that NUM LOCK should be OFF for the arrow keys to function.
c. If Windows launches before you can choose the safe mode, restart computer and go to step a.
d. You can choose “Safe mode with command prompt” option if you know how to use MS-DOS
e. You can choose “Last known good configuration” to go back to the last known safe shutdown state.
f. If you have added any drivers or corrupted any files the last time you used the computer, the safe mode will help you get back to the state before the changes, when the computer was running smoothly.
Posted on Sep 18, 2008
    Sergeant:
  • 399 Answers
Its not a operating system problem so no need to upgrade the operating system.reloading the display driver once again should help.
for any further queries feel free to ask.
thanks.
Posted on Sep 17, 2008
  • 3,940 Answers
You can adjust the font size to a more readable size by doing the following:
Open Display Properties, click the settings tab, click the advanced button and change the DPI setting from Large (120 dpi) to Normal (96 dpi). , If desired, you can increase the font size further (144, 160 etc) till you reach a font size that is comfortable You always want to use the Optimal resolution on an LCD (1980 x 1050 in this case) You may want to run the Cleartype tuner too: http://www.microsoft.com/typography/ClearType/tuner/tune.aspx?
    Master:
  • 441 Answers
I think you need to get a better video card because the video card respond on the maximum resolution of your monitor.
    Genius:
  • 1,011 Answers
Dear,
check the proper driver installation and then resolate it accordingly.
regards,
dont rate it until satisfied
    Genius:
  • 1,268 Answers
What is the spec of your PC video card? You can try to adjust the resolution on your desktop's display settings.
For any other questions please contact Hanns.G Customer Service at
888-808-6789 Mon - Fri 7 am - 6 pm PST / PDT.
or email at
webservice_us@hannsg.com
    Guru:
  • 1,894 Answers
Change the resolutions by going into display properties in control panel
this will help you adjust the resolution of the screen.
  • dewan nafees ahmed Sep 17, 2008
    there is no problem with your driver and OS
    but we missing some settings
    just need to find that out
I have a 22" Hanns
Right click on the desktop, go to properties. Click on the settings tab, change your resolution settings, try a very high resolution and see if that fixes the problem. Your monitor may have an auto adjust button as well that you can try. If that is not the issue, then you may need to get the mechanical issue repaired.
Jun 11, 2011 | Hannspree 22" widescreen LCD Flat Panel HD...
Having changed the os from xp to xp pro i am unable to alter the screen resolution. Any help appreciated.
Go into control panel, click display, settings on the top right, set the color quality at max and the screen resolution also at max, click okay to save settings and monitor should adjust accordingly, if not set monitor to auto setup.
Mar 31, 2011 | Hanns.G Corporation HW191D 19" LCD Monitor
Resolution for samsung ppm42m5hbx/xaa
scroll to the bottom of this page for the user manual http://www.samsung.com/us/support/supportDownloadCenter.do?prd_ia_cd=N0000285&prd_mdl_cd=PPM42M5HBPXXAX&prd_mdl_name=PPM42M5HB
direct link here http://downloadcenter.samsung.com/content/UM/200605/20060508130919062_BN68-00848B-01Eng.pdf
Page 22 shows you how to see what resolution you TV thinks the PC is
Page 48 is a list of resolutions the TV supports Max - 1600 x 1200 BUT the recommend resolution for your TV model is 1280 x 1024 - if PC supported
Sep 28, 2010 | Televison & Video
How do we embed into a Windows report, commands for a Tec B472
Hi Gilles483,
If you want to use a printer in windows, create a Generic text printer in the correct port and send the commands.
Nov 19, 2009 | Toshiba TEC B-472 Thermal Label Printer
My samsung syncmaster 2233sw shows multiple displayes when i take it to its max res. i use win xp sp2 and have nvidia 8600gt gfx card. the monitor works well on lower res but only shows this problem when i...
Typically this is a driver issue on the host (PC) side. DVI or VGA connection? Update the video driver. Some video drivers (especially older laptops) can't correctly send that resolution.
Jun 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Dell OptiPlex GX260 video drivers don't work with Windows 7
In your original question you say your max is 1280x1024 and in your second you say it is 1680x1050. The video card drivers are what determine your maximum resolution, not your operating system. If Dell has no drivers that support higher resolutions you'll have to change the video card.
May 29, 2009 | Dell OptiPlex GX260T PC Desktop
Display on Internet expolrer 7
Use mozilla firefox.
Uninstall IE7, it sucks...
Feb 19, 2009 | Microsoft Internet Explorer 7
Slow Fax Transmissions with USR V92 External fax modem
Its possible you've set your faxes to send in FINE resolution (200 dpi), I am not sure about MS Fax, but in WinFax you can select both Standard Resolution and Fine resolution as the default for sending faxes.
Jan 14, 2009 | 3Com U.S. Robotics Faxmodem 56K
Storable images and file sizes ...
Stylus 300 Digital Memory Card Storage Capacity Quality Pixel Resolution 16MB xD-Picture Card 256MB xD-Picture Card SHQ, HQ 2048 x 1536 6, 20 shots 96, 326 shots SQ1 1600 x 1200 24 shots 399 shots SQ2 1280 x 960 38 shots 614 shots SQ2 1024 x 768 58 shots 940 shots SQ2 640 x 480 99 shots 1598 shots HQ Movie 320 x 240 15 fps 16 sec. max per movie 16 sec. max per movie SQ Movie 160 x 120 15 fps 70 sec. max per movie 70 sec. max per movie All capacity figures are approximate. Stylus 400 Digital Memory Card Storage Capacity Quality Pixel Resolution 16MB xD-Picture Card 256MB xD-Picture Card SHQ, HQ 2272 x 1704 5, 16 shots 90, 266 shots SQ1 2048 x 1536 20 shots 326 shots SQ2 1600 x 1200 24 shots 399 shots SQ2 1280 x 960 38 shots 614 shots SQ2 1024 x 768 58 shots 940 shots SQ2 640 x 480 99 shots 1598 shots HQ Movie 320 x 240 15 fps 16 sec. max per movie 16 sec. max per movie SQ Movie 160 x 120 15 fps 70 sec. max per movie 70 sec. max per movie
Sep 01, 2005 | Olympus Camedia Stylus 300 Digital Camera
XD-Picture Card
Quality Mode Pixel Resolution 16MB xD-Picture Card 512MB xD-Picture Card HQ 320 x 240 15 fps movie 15 sec. max per movie 480 sec. max per movie SQ 160 x 120 15 fps movie 60 sec. max per movie 1920 sec. max per movie
Aug 31, 2005 | Olympus Camedia D-395 Digital Camera
Computers & Internet Logo
158 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
