Question about Maytag M7DH65B2A Dehumidifier
Dehumidifier collecting water in container
WE havent used our humidifier in the past year, and when we plug it in, the water is coming out of the back hose opening rather than collecting in the container.
Is there a way to program it?
  • Irene Albertson Feb 03, 2009
    We don't have the operating manual. How does one go about removing the hose drain tube?
If you have the hose drain tube connected, drainage will defer to it first. If you remove the hose drain tube, the place where it connects to the drain pan drips into the container instead.
Posted on Jan 08, 2009
My dehumidifier is collecting water but its not going i ,its going all over my floor?
Go for the simple fix first. Unplug unit and look inside once the cover is removed. It may be that dust and lint that collects on the coils have dropped down into the pan / tray and have blocked the little hole that would allow the water to go into the bucket. Only try this if you can safely remove and replace the cover.
Oct 20, 2014 | Dehumidifiers
Our Friedrich D50C humidifier is six years old. Worked great until a week ago it seems to turn on- then an unordinary noise occurs and moisture is not pulled out.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 04, 2011 | Friedrich D50C Dehumidifier
4-5 years old. Has work great all that time. In the past week it stop collecting water. It runs but never any water in it. It's not leaking out. The collection pail is dry as a bone.
heatman101
Aug 23, 2011 | Amana D530M Dehumidifier
Water is leaking from the bottom of my maytag dehumidifier. Noticed the problem over the past 2-3 weeks. I have a carpeted basement and the carpet under and around the unit is soaked. water is...
Robert, The water tubing that runs form the interior of the unit to the water bucket is clogged to solve this problem, turn the unit OFF & unplug it. Then do the following.
Remove the water collection bucket and look up inside the bucket holder cavity. You will see either a drain hole or small tubing that drains the water into the bucket. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
NOTE: Is you don't have access to a Zip Tie, you can use something similar that flexible, like a long pipe cleaner. But, NO wire coat hangers.
I hope this helps you and thanks for choosing FixYa.
Aug 22, 2011 | Maytag M3DH30B2A Dehumidifier
Our Haier dehumidifier, Model HD306 seems to be working okay except it is not gathering any water. Last year we had to empty the bucket every two days. The humidifier is in the same spot and under the...
heatman101
Jul 18, 2011 | Haier Dehumidifiers
25BSRO humidifier want collect water
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Jan 13, 2011 | Whirlpool AD25BSR Dehumidifier
Our dehumidifier wasn't working properly so I checked the filter, it was heavly covered, so I rinsed it off however the humidifier is still not working properly. It is blowing cold air only and not...
heatman101
Jan 03, 2011 | Danby DDR5009REE Dehumidifier
Dehumidifier runs but collects no water - coils are clean there is no obstruction the humidifier worked until a few weeks ago
heatman101
Jun 17, 2010 | Goldstar DH504EL Dehumidifier
I have a GE Dehumidifier Model AHW50LMG1. Am trying to find out how to clean the container that the water is collected into. After use the container contains residue from collected water that I am...
Vinegar is the proper way to clean all parts of a humidifier. It stops scale and kills bacteria and fungus. It can be processed through the heating element without any adverse effects.
Thank you,
James.
-------Please vote 4 thumbs up 4 me!!!----------
Apr 24, 2010 | GE Dehumidifiers
Humidifier runs but does not collect any water
hello. If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Sep 14, 2009 | Dehumidifiers
Maytag M7DH65B2A Dehumidifier Logo
218 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
