Ariston Washing Machine Model AF 883 T
Hope you can help. I am looking for a repain manual as i require the fitting insructions to replace the Door/ Drum Rubber Seal unit.
I have contacted Ariston they inform me that i should contact Indesit but i cannot find any reference to the AF 883 T washer.
Thanking you in anitipation.
Ken Campion
    President:
  • 1,462 Answers
This is general instruction for door boots - allo much the same
undo clamp that holds boot to cabinet and peel away clear of the cabinet.
take worktop off.
locate clamp that holds boot to tub. undo clamp (usually like a giant wire jubillee clip) and boot can be pulled off tub.
lubricate slot in boot that goes onto tub with washing up fluid
starting at top, push slot in boot onto lip of tub. working in both directions, continue forcing slot onto lip. this is a knack and it may take a few attempts.
when full fitted, refit clamp and tighten
refit door boot to cabinet (this is easy) and refit outer clamp.
test for leaks on rinse cycle as water level is higher. water will be foamy from washing up fluid till washed away.
turn of at mains while doing this job
Posted on Sep 17, 2008
Ariston AV-51 model washing machines User manual and parts list
Looking for Ariston AV51 washing machine manual
Jan 29, 2011 | Washing Machines
Replaced door seal now door is difficult to close.
Sometimes, it is hard to close door after fitting a new seal.
Make sure you have got it fitted correctly round the flange on the front of the cabinet, and that the retaining clamp is securely fastened.
Try smearing the door glass with washing up liquid, this can help to close the door more easily
Please rate my solution.
Thankyou.
Feb 13, 2010 | Ariston Technologies Washing Machines
Broken door handle on washing machine
You can purchase any of the parts individually for the door handle.
If you go on line and enter Ariston door handle in search box, you shuold be able to locate the part/s you require.
Good luck.
Jan 06, 2010 | Ariston Technologies AW125NA 13 lbs. Load...
My ariston washing machine door not locking
I recommend replacing the door latch. It is a fairly common problem. You can get one at repairclinic.com or partselect.com
Jan 02, 2010 | Ariston Technologies AWD121WH
How do I remove and then replace a new door seal on my hotpoint WD420 washer / dryer
First switch off electrics , Remove door interlock , leave wires on .remove soap dispenser,remove front panel with controls 3 screws top of machine 3 screws bottom remove front casing you can now see door boot. remove sring note how boot came off refit is oposit to this noting top / bottom of seal ..Hope this some help-
Oct 03, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
ARISTON WASHING MACHINE DOOR PROBLEM SO ON/OFF BUTTON DOESNT WORK
Well it depends on how old your machine is, if eveything else is fine then replace it. The cost will vary depending where you buy your part from. It could cost but worth it if machine is reliable. try
www.lpdlpd.co.uk
Aug 09, 2009 | Ariston Technologies AWD120 13 lb. Washer...
Ariston washing machine
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Nov 17, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston Margherita 2000 (Advantage) Model A1435UK
Ariston Washer Dryer Margharita 2000. I have inherrited this machine but there is no user manual, does anyone know where i can get one from??
Mar 25, 2008 | Washing Machines
Washing Machines Logo
284 people viewed this question
Top Washing Machines Experts
