Question about Westinghouse Computers & Internet
Lcd monitor 20.1
My screen in completely white. I hooked it up to another computer and it still doesnt work. Connected a monitor to this computer and it works fine. But my Westinghouse Lcd Monitor 20.1 in monitor is displaying only a white screen. Help me!
  • meet0818 Sep 18, 2008
    thanks, we kinda figured that.
  • Westinghouse Master
  • 5,568 Answers
The white screen is caused by a total lack of control over all pixels. The opposite effect; all black, happens when a failure turns all pixels on, blocking all but a small amount of light.
This could have more than one source; one output of the power supply has failed so the logic section no longer is receiving supply voltage or an external source has damaged the video input of the monitor. The backlight responsible for the white screen is obviously working as this is a separate power supply output to an inverter that powers the backlight lamp.  I'm afraid this is not a DIY repair.
Posted on Sep 18, 2008
A friends laptop is only showing a white screen
Step 1:
Fix a White Screen on an LCD Monitor
b>When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance.
b> b> b> Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video. For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen. After I assembled everything back together and connected the original LCD, it's still white. CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced. b> b>
Feb 06, 2013 | Toshiba 16" Satellite A665S6095 Intel Core...
My pc desktop is showing a white screen when its on what should i do?
Is it an LCD monitor ?
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See Below for the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance. Hope this helps.
Dec 30, 2012 | Compaq Computers & Internet
My pc is showing a white screen when iys on
Montor blinks white
If this monitor is new return it to the place of purchase, the problem is in the LCD panel display, if out of warranty! cheaper to replace.
Mar 24, 2012 | E-Machines E202 20 inch LCD Monitor
Apple 20" display black screen
I've read that aftermarket DVI cable adapters don't work well with this set-up. You might try the Apple DVI to ADC adapter. It's expensive but I see them on eBay or craigslist from time to time at less than half the normal $99 cost.
Aug 26, 2008 | Apple 20" Flat-Panel TFT LCD Cinema...
White screen
this is the fault of your lcd screen
it could be your screen jack is loose or damage white screen is coming due to back light is glowing only.it is better to take to some technician or service center.
Jul 26, 2008 | Smart Modular PYXSCAPE SV1170 17" Flat...
Screen completely white
dont warry,u just replace your lcd.
Apr 27, 2008 | Dell Inspiron E1505 Notebook
One gets to open it up and find out where the signal from the computer is lay aside. Hunt up the model number on the inside of the monitor (the ODM part numbers) for the service manuals if you can use them. Otherwise you can call Gateway or look for a shop (sometimes even buy repair insurance coverage with the thing in that nonfunctional state.)
Mar 31, 2008 | Gateway FPD1760 17" LCD Monitor
White screen
This could be caused for a number of reasons. First thing to determine is if the computer is bad or just the screen. Hook up a external monitor to the laptop and turn it on and use the FN key to turn on the external monitor port. If the computer is running fine with the external monitor then you have a bad LCD or LCD inverter. which is replacable but expensive.. you would want to look at getting a new laptop or using it with the external monitor.
Jan 18, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
360 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
