Question about Baumatic 18 in. BDW45.1 Built-in Dishwasher
Baumatic bdw45 Dishwasher
Don't now why but my dishwasher has come up with an E4 sign and it is beeping and trying to empty even though there is nothing in it, can you sugest what i should do.
Thank you
Mark Boyce
Just had the same and fixed it with the advice above.
POWER OFF!
Pop the black panels off, stick a towel in, soak up water, quick test to check no E4 comes up, put the kettle on, take the credit off the wife, feet up.
The hardest part was putting the integrated kitchen back together.
Posted on Oct 06, 2008
    Problem Solver:
  • 10 Answers
REMOVE MAINS POWER COMPLETELY, then remove the plastic covers from base of machine and sponge out the bottom catch tray
Posted on Oct 04, 2008
  • daba2
    daba2 Oct 05, 2008
    I'll also add - I've just diagnosed on my machine that the polystyrene float that trips the microswitch to cause this error, can get stuck to the drip tray, rendering it useless. This will allow too much water to accumulate in the tray. Result - water level too great and spills into the shield stuck onto the bottom of the motor, and in my case seems to be the cause of the fuse-board tripping when the motor tries to start (I'll piost back if fitting new motor cures the problem). I now know where to get a new pump/motor at a fraction of the cost of the usual suppliers.....
    I have "fixed" this problem - don't allow the flat base of the styrene float to rest flat on the base of the drip tray, stick something, anything (no more than 2 mm thick) to the catch tray under the float.
  • daba2
    daba2 Oct 11, 2008
    Yes, the new pump/motor assembly has cured the board tripping, so the motor must have been damaged by water getting into it, although it doesn't appear to have signs of damage to the windings. Only time will tell but all is well now, and the cost of replacement justified giving it a go.
    If anyone wants to know where I got the new motor at a third of the cost of a "genuine" replacement, click on my dame and "Ask Me".
DISHWASHER- Model no: DW009
Hi i know you give the model number but what make is it i will find out what the fault code is for you then i can advise you on the best way of solving the problem tell me your make and model number and ill try my best to help you ok speak soon
Nov 29, 2007 | Dishwashers
Baumatic BDW45. Keeps tripping the electric out when on a wash cycle and leaves water in the bottom. If I put it on a rince only it works fine. Help
your tub is running out of balance could be due to your counter balance weight in the bottom or excessive load shift sometime you can try rocking the tub by hand to re center it or you may have to turn it on it's side to see if the retaining pins are locked on the tub or the balance weight is broken
Jan 14, 2010 | Baumatic 18 in. BDW45.1 Built-in...
Error 3 on dishwasher
E3 on BDW45.1 is a failure to reach correct temperature (or the diswasher is unable to dectect the water has reached the correct temperature). You may find the items are not being dried fully.
Feb 21, 2009 | Baumatic 18 in. BDW45.1 Built-in...
Error code e4
This might be a re-badged generic dishwasher - on my Baumatic E4 error caused by floatswitch in bottom catch tray. Some (supposedly small amount) water collects here and should evaporate naturally. If it accumulates, float rises and stops machine.
TURN OFF THE POWER
try to find a way into the machine base catch-tray to sponge it out - on the Baumatic there are two large black plastic plugs on the front of the machine base that can be forcibly flipped out.
failing that, take machine out and tip it up to get rid of water
Oct 09, 2008 | Maytag Dishwashers
Baumatic BDW13
e4 code means the machine is showing a fault code for overfill,tip the machinee to a 45 degree angle and get excess water out should run ok after that
Aug 13, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
E4 message
take of the btwo black panels at the bottom of the dishwasher and put in a towel to soak up thje excess water this works for me everytime
Jul 31, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
BDW45.1 Baumatic Dishwasher E4 alarm
Check and clean the filters on the inlet water line (both sides). Good luck!
Sep 03, 2007 | Baumatic 18 in. BHD45 Slim-Line Built-in...
I need to reset my dishwasher but don't know how!!
If it's any help then here is the link to the user manual (when you download it it applies to bdw13 as well even though it is labelled for the bdw14) http://www.baumatic.co.uk/products/discontinued-models/dishwashers/integrateddishwashers/BDW14 Best I could come up with is to try page 19 at the bottom of the "dishwasher doesn't run" section - there are two different types of reset which may do the job. Hope this helps :)
Mar 13, 2007 | Baumatic 23 in. BDW13 Built-in Dishwasher
Baumatic 18 in. BDW45.1 Built-in Dishwasher Logo
736 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
