Question about Dryers
Water light on saying full but water container is empty
  • Anonymous Dec 26, 2008
    Container full light comes on when container is not full
  • pinklady1802 Jan 07, 2009
    I have exactly the same problem and wonder if it had something to do with the little valus thing that is in the top of the container, mine looks a bit battered
  • 3 Answers
The problem is with the lower water tank float switch, it is stuck. Take off the right hand side panel (as you are facing the machine) at the bottom you will see a spring mechanism for the belt tension. Beside this there are 2 electrical connectors. Take them off and spray with wd40 or similar. Whilst off give the plastic box they fit 2 a light tap with a hammer to free the float switch. Reconnect and try. If this fails you can over-ride by leaving the left hand of the two plugs off. This will get your machine working but you will not have an indication as to when the water container needs emptying so you will need to remember.
Posted on Feb 14, 2009
Bosch WTL5200SN/04 condense Tumble Dryer
you have to open the cover to check it seem the water tube is dissconnected or there is an blockage in the tube.
Jul 07, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Dehumidifiers bucket empty but says full water leaking on floor
if says full and leaking on floor. it is full, you say empty, why make sure that it is empty, sensor in container to check level, so if it is empty, sensor fault, but leaking on floor, would indicate sensor ok, and container full
Aug 07, 2014 | Frigidaire 50 Pint Capacity Dehumidifier
My portable air conditioner is beeping and saying full, how do i get it to stop beeping
Portable air conditioners work much like a dehumidifier in that they remove moisture from the air. This condensation accumulates in a container that may need to be emptied. Check to see if there is a removable container full of water.
Nov 15, 2011 | Soleus KY-34 Portable Air Conditioner
Everstar MPA 08CR Portable AC unit. Water full
Your float switch is faulty, replace.
Jul 02, 2009 | Heating & Cooling
FULL LIGHT FLASHES
An automatic overflow switch and Container “Full” indicator light are provided to turn the
dehumidifier off before the container overflows. When the indicator light on the control panel
glows, the water container must be emptied. If the light remains on and the dehumidifier does
not begin to operate make sure the float is attached to the water container.
When the condensate water container is full, the indicator lights up.
1. Turn the power off before removing container. Wait 3 minutes for
any remaining water to drain into the condensate container.
2. Tilt the container forward then lift carefully by the handle.
3. Empty and gently re-insert the container.
Important:This water is not suitable for drinking.
Please rate and god bless:)
Apr 24, 2009 | Fedders A7DH45B2A Dehumidifier
Red descale light is on
I use distilled white vinegar, but you can use specialized coffee cleaners with this model:
Descaling
Descaling 11
Descale your Tassimo machine every three months to keep it
operating at full potential.
Descaling products are widely available from stores selling coffeemakers and espresso
machines. Only use a product intended for descaling. Mix the descaling product
directly in the water container, following the instructions provided on the descaling
packaging. Replace the water container on the machine.
2 Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down,
and close the brew mechanism. When the AUTO light illuminates, press and release
the start/stop button. The brew cycle will fill the machine with descaling solution. Empty
the cup and let the machine stand for 15 minutes.
3 Open the brew mechanism and close it again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and release the start/stop button. When the
machine stops running, empty the cup, and let the machine stand for 15 minutes.
Repeat this step two more times for maximum descaling effectiveness. Discard the
remaining descaling agent from the water container, rinse it thoroughly and refill
with fresh, cold water.
4 Open and close the brew mechanism again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and hold the start/stop button to flush water
through the machine. The MANUAL light will flash. When the cup is full, release the
start/stop button, empty the cup, and replace it on the cup stand.
5 Repeat step 4, flushing clean water through the machine in the same manner and
emptying the cup as it fills. To ensure that all the descaling solution is completely rinsed
away, flush two full water containers through the machine before using it again.
Mar 26, 2009 | Braun Tassimo Coffee Maker
Waste toner full/empty message
this messages referes to the waste toner being full or not installed.
Manufactures try to stop you from emptying the container by having a small "window" that the printer looks through, when you empty the toner there will still be some toner on this window, so the printer will still believe that it is full.
a way around this is to wash the container out with water (do not use hot water as this will melt the toner). i also wouldn't recommend pouring the water & toner down the sink as this could be breaking local laws.
Dec 18, 2008 | Samsung CLP-500N Laser Printer
Add Water
Turns out I finally called Keurig and explained the problem (says to add water when water container is already full...) and they told me that it was most likely an issue with the water container. They sent me a new water container about a month ago and it looks as though the problem has been solved!! Solution: Call Keurig and get a new water container!!!!
Dec 26, 2007 | Keurig B60 Coffee Maker
Dryers Logo
326 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
