Question about Canon PowerShot S3 IS Digital Camera
Won't turn on
Brand new batteries, camera will not turn on at all. checked batteries and they are in correctly and absolutely no power.
  • 3 more comments
  • bmmorrison Sep 25, 2008
    I've tried 4 sets of new and/or recharged batteries - and no power - camera has been working great for the 2 years I've had it...
  • mebriget Dec 20, 2008
    Same problem here :-(
  • Anonymous Dec 21, 2008
    i have the same problem
  • Nitin D Mar 16, 2009
    Changed the discharged batteries with brand new batteries, camera will not turn on at all.
    Batteries are new and they are in correctly and still absolutely no power.
  • b_arif May 11, 2010
    Hi, the solution did work and Camera turned on but still it doesn't work with power on/off button. What is the solution?
Plug your camera into the USB port and conenct it to the computer. If your camera turns on, the problem is the Power On switch. The Power On button is very finicky (poor design). I found it best to use your thumbnail and fully depress the tiny black button and turn to to the left or right and hold for 1 second. Best if you do this with your hand over (above) the camera.
Posted on Dec 28, 2008
My batteries seem to need replaced quite often. Should I use a special brand
Check contacts of the batteries and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera.
Always charge the batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
Also check if the battery door is closed correct. Most cameras do have a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
Do not use alkaline batteries unless it is absolutely necessary. In most cases, alkaline batteries have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera. They can't deliver enough power.
Jan 03, 2015 | Kodak EasyShare C875 Digital Camera
Won't turn on
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Check contacts of the battery and in the battery compartment of your camera. Dirty or oxidised contacts can be cleaned with a dry cloth. Never use sharp tools to clean contacts or anything in or on your camera. Always charge the battery before using it for the first time, or if you have not used it for a long period. 3 months is a very long period.
If you have a multi meter, you can check your battery. After charging the voltage should be higher (few tenths of a volt) than the voltage printed on the battery.
If the voltage is slightly lower, you know thee will be not enough left when the battery needs to deliver some power.
Jan 10, 2014 | Canon PowerShot S2 IS Digital Camera
My camera wont turn on or work even after i put brand new batteries in it... whats wrong with it???
If your batteries did not leak at all, and corrode th points where the. Batteries make contact, then it could be something very serious on the main board, or something simple like the on/off switch. Really it's the sort of problem that needs to be seen by someone. I'd check the battery connections first, then make absolutely sure the batteries are going in the right way around. Flat end is - and pointed tip end is +. Good luck
Nov 24, 2013 | Jazz JDC27 Digital Camera
Kodak c340 won't turn on
Hello Carol, Are these batteries new and name brand ? It sure sounds like low battery power, Those cheap batteries found in some stores do not have the energy to boot a camera even when new out of the package. The camera has a very high demand to start up. I own several cameras that will not turn on with brand new cheap batteries.
Best Regards, Russell
Oct 28, 2012 | Kodak EasyShare C340 Digital Camera
I just changed the batteries in my camera and it wont turn on
Two things: Are you absolutely sure the new batteries have a charge? Have you double checked to make sure they're in the correct direction...
Sep 20, 2012 | FUJIFILM FinePix S2550 Digital Camera
I just put in a brand new battery and it won't start. Absolutely NOTHING! Any quick suggestions? Fuse?
It can be the fuse link from the battery which could have failed and so will not power the igntion circuit. Please use a multimeter to trace the +12 to the fuse box and from the Ignition circuit.
Make sure the GROUND connection is good from the battery to the chassis.
Jun 06, 2012 | Dodge Dakota Cars & Trucks
Casio Esilim EX-zs10
If it is brand new and any fault is excluded..than the batteries are the only one to blame ...Check again to be sure you inserted them well and in the right position ..and also if you do not use rechargeable ..use only high quality ones..cause some batteries on the market do not have the correct amperage and will not power the camera ..
Also pay attention cause some cameras have a double power source ..and can be powered from an adapter...so ..they have a button to switch mode...This can be the case for you too ..
Nov 15, 2011 | Casio Cameras
I have a canon camera and it wont turn on i bought brand new battries for it and still nothing!
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Sep 28, 2011 | Canon PowerShot SD780 IS / IXUS 100 IS...
Canon PowerShot S3 IS Digital Camera Logo
342 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
