Question about Samsung RS2534 Side by Side Refrigerator
Refrigerator temp erratic
A couple of days ago the digital temp read out started flashing. the next day everything in the fridge went bad. I unplugged it and plugged it back in and the temp readout stopped flashing, but keeps going up and down between 38 and 60 degrees. Any ideas?
  • 1 more comment
  • raventor Sep 17, 2008
    WHERE DO I FIND THE THERMOSTAT AND FAN?
    COULD SOMETHING BE SHORTED OUT? I RECENTLY HAD SOME MICE UNDER THE FRIDGE, COULD IT BE A CHEWED WIRE? IS THERE A WAY TO CHECK?
    I FIND YOUR COMMENTS TO BE USELESS
    Sergeant:
  • 399 Answers
Click this link for all types of help
http://fridgedoctor.com/fridge-doctor-book/fridge-doctor-book.html
just click to know how
Replacing the Defrost Thermostat < -- Free Sample
Posted on Sep 18, 2008
    Master:
  • 726 Answers
Thermostat is at the back of the freezer behind the panel and just pull your fridge out look behind and see if any of the wires are chewed though there is int many down low a mice can eat any way you will see if any wires are eating though
Posted on Sep 17, 2008
    Sergeant:
  • 300 Answers
I'd say Thermostat.
  • Steven Brown Sep 17, 2008
    Um thermostat is located under the fridge near the big compressor.
    And another could be located INside the freezer part.
    Getting to it is going to require some time and some tools.
    Genius:
  • 1,268 Answers
How long did you unplug the power? Try to unplug it for several hours like 2-3 hours for the reset to takes place. Now if the temp stil fluctuates, there might be some air leak. You can try to lower down the temp just to isolate the problem if its just the digital control problem or some internal problem.
  • 52 Answers
You can find the parts needed for that at repairclinic.com
    Scholar:
  • 148 Answers
A POSSIBLE LEAK OR YOUR REF IS OUT OF FREON.. IT'S BETTER TO CALL SOMEONE TO DO THE CHECKUP ON THE UNIT.
    Genius:
  • 1,847 Answers
There seems issue with the thermostat. Also check the fan are working properly.
    Guru:
  • 1,894 Answers
You will have to replace your thermostat of the fridge
you can find it near the light inside the unit
  • dewan nafees ahmed Sep 17, 2008
    and do you see any fault code flashing??
    if so please let us know
    if you give us proper feed backs we can help you better
    thank you
Fridge temperature too hot won't go down with temperature controls
This looks like there is a problem with thermstat in the fridge. We had a fridge that would not cool and we found it to be the thermastat problem. You have to replace the thermstat on the fridge. Not 100% sure but a high possibility.
Mar 23, 2014 | Frigidaire Refrigerators
Haier HSW02C runs ALL the time
Yes your thermostat is shorted. It's just not shutting the unit off ever. A thermostat is something you can touch as a user, so no it's not that hard to get to for replacement. Also have the unit unplugged while learning how to repair your appliance.
Apr 27, 2013 | Haier Refrigerators
I have a GE profile model # PFS22MBSAWW and about a year ago the digital display for the temperature reading would work intermittently. After some time I realized that when the condensor motor was on, the...
ou need to replace the main control board . in the back pt # wr55x10526 and you may also need the display pwb pt # wr55x10522 .. do the main board first and if diplay isn't working properly replace it also .. mm hope this helped .. feed back lps ..
Jul 10, 2011 | GE Profile Bottom-Freezer Refrigerator...
GE fridge has loud clicking noise; model freezer on bottom.
The problem is the main control board on back of refrig . Relay bad and clicking . Have to replace the complete board .
Jul 23, 2009 | GE GBS18KBM Bottom Freezer Refrigerator
Model 106.53632300 couple of days ago smelled something (burned electrical type smell). Now both fridge and freezer not cooling. Cooling fan in back on bottom is running.
you may have a fried start or run cap and hopefully not a spendy board like everything runs on these days....bad caps(capacitors) will cause compressor not to start and run but arent needed for fans to kick on ....
Jun 28, 2009 | Kenmore 53642 / 53644 Side by Side...
SubZero 650 - fridge 36 to 50 deg, vac condensor light flashing
Hi!! you have a seal system problem.A leak in the evaporator..
Dec 26, 2008 | Sub-Zero 650 / O Bottom Freezer...
GE Fridge/freezer not working properly!
hey ur thermister has worn out may be due to the power surge when the power came back at that time so change the thermistor then check it out.........
Sep 09, 2008 | Refrigerators
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Sub-Zero 650 / O Bottom Freezer...
Samsung RS2534 Side by Side Refrigerator Logo
218 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
