Question about Dishwashers
My Maytag Dishwasher MDBH750AWW will not turn on. Pressing the key pad on the top front does not activate the controls. I traced the wiring and found it is active in the door latch assembly, which I recently replaced. Question: 1) If I purchase a new Control Panel exterior white key pad, which is linked to the interior Control Board, should that solve the problem? Or,2) if I purchase a new exterior Control Panel finger touch pad, and an interior Control Board, will that solve the problem to activate the controls? Or, 3) Do you recommend another solution? Thanking you in advance for your advice, I am Don.
  • 1314 Answers
SOURCE: Maytag dishwasher MDB5601AWS won't turn on
ok under the bottom kick-plate you will find a tech sheet first id start with where my power comes in under the kick plate second remove the front panel and check the door switches third check the control for a fuse or burned wires resistors etc refer to the tech sheet but it sounds to me like a power problem
Posted on Jan 25, 2008
SOURCE: Frigidare Gallery Pro Dishwasher Control Panel Power
It can be the problem with the transformer. Try replacing it with another one.
Posted on Dec 15, 2008
  • 132 Answers
SOURCE: maytag dishwasher MDBH940AWW. ''Touch Panel'' is not working.
Hi There,
Try just replacing the Keypad. It is cheap and is usually the cause. Hope this helps and thank you for using FixYa!
Posted on Mar 30, 2009
  • 82 Answers
SOURCE: maytag quiet series 300 - model MDBH970AWW door
remove the inner door panel and control cover, switch will pop out after that
Posted on Jul 17, 2009
  • 3741 Answers
SOURCE: I have a Maytag MDB 5600AWW dishwasher. There are
If there are no lights on the control panel then initially check if connections to the panel are fine.If they look fine then you definitely need a new control panel. No need for a new touch panel.Its always that the control panel goes faulty,not the touch panel.
you can also check for competitive rates from local dealers and few sites and
Posted on Aug 28, 2009
Testimonial: "Thank you so much for the quick and informative answer. It is greatly appreciated. "
On kitchen aid dishwasher, control lock is blinking and preventing the use of any other execute buttons. Can't start a wash .
Which model KitchenAid dishwasher do you have? On some models, the Control Lock can be toggled on/off by holding the Energy Saver Dry touch pad for at least 4 seconds or until the Control Lock light turns on or off.
On another model, the touch pad to press and hold is the 4 Hour Delay button. (On that model, you press and hold for 3+ seconds.) There is often a very tiny label below or on the touchpad indicating which key controls the Control Lock.
If you haven't held the button for long enough, pressing the other touch pads will lead to the Control Lock light blinking 3 times if the Control Lock is active.
If the press and hold method still doesn't work after several attempts, then you may have a problem with the control panel. The dishwasher may need repair.
I hope this helps. Please add a comment with the model number so that I can check if a different touch pad key is the correct one for the Control Lock.
(the Control Lock feature keeps the dishwasher settings from being changed accidently or the unit started when it isn't needed. This can stop a child from resetting the dishwasher or the unit being started while you clean it.)
Oct 15, 2012 | Dishwashers
I have a Maytag MSD2351 side by side and just replace the water filter. When I attempted to reset the filter light, the control locked and I can not get it to unlock. I pressed the lock and water button...
If the Control Lock feature has been enabled, the Control Lock light will flash 3 times indicating that it is activated. To turn off Control Lock, press and hold the Options key that says "Control Lock Hold 3 Sec" under it for 3 seconds. If the dishwasher has a dedicated Control Lock button in the Options selections, press and hold CONTROL LOCK for 3 seconds.
NOTE: You may need to disable Sleep Mode by pressing either Start/Resume or Cancel, or by opening and closing the door before you are able to turn Control Lock off.
NOTE: If your model requires you to press and hold PROSCRUB UPPER, 4 HOUR DELAY or BOTTLE WASH to lock the controls, the Control Lock light will be on when Control Lock is active.
Nov 03, 2017 | Maytag Refrigerators
Need trouble shooting proceedure to enter self diagnostics for maytag neptune
From the service manual there is more to it but that was all I could put here.
Accessing Service/Diagnostic Mode:
Pressing down the damp dry and time (-) keys
for 5 seconds places the machine in the
diagnostic mode.
The following table lists the various tests
available while in the Service Mode, which
can be accessed by pressing the following
Press Keys Special Test/ Function
release Diagnostic Codes
temp(^ )
Sequences up the
help/diagnostic code list
dryer temp(v) Sequences down the
time (-) Displays Software Revision
very dry(< ) View current cycle
temperature (Co)
Start or pause cycle running
but remain in Diagnostic
Accessing Diagnostic Codes
After the machine is in the diagnostic mode,
a ‘d’ will display and let the technician know
they are in the diagnostic mode. Pressing the
wrinkle release key will access the diagnostic
codes.The diagnostic codes can be viewed by
using the temperature (^) & (v) keys.
The down arrow key will sequence down the
list one each time it is pushed with no wrap.
The first time the down arrow key is pushed
the display will sequence to the next code
logged. The last code being displayed being
the oldest code. The up arrow will sequence
up the list one code each time it is pushed
until it reaches the top code. If there are no
diagnostic codes available, ‘00‘ will be
displayed for the diagnostic code.
There will be no multiple occurrences of
either a diagnostic code or help code generated
in the same cycle reported on the list.
But if the same code occurs in repeated
cycles, it will be registered.
To clear the diagnostic code list press
wrinkle prevent and very dry (>) for 5
seconds while viewing the list.
System Check Mode
While in diagnostic mode, pressing the damp
and signal (+) keys for 2 seconds, will
put the dryer into the system check mode.
"SC" will display.
This mode will allow the various inputs and
outputs to be controlled and viewed by the
technician by pressing individual keys. If no
activity is seen for 5 minutes after a key is
depressed, the control will reset back to the
normal mode. If no further activity is seen
after an additional 5 minutes the washer will
turn off. The following table lists the various
functions based upon on keys being depressed.
Membrane Pad Check
While in system check mode, pressing the
damp dry and sensor dry keys for 5 seconds,
will start a membrane pad switch test.
The membrane check involves turning all the
embedded LED on the membrane pad on.
All the LED’s can be toggled off by pressing
the key associated with the LED. To exit the
test at any point, press the damp dry (>) &
sensor dry keys again for 5 seconds or press
the off key to exit diagnostic mode.
Key Pressed: Function Performed
sensor dry
Enable sensor dry circuit.
(sense dry LED) When short
circuit is detected across the
sensor bars the normal dry
LED will turn on.
start/ pause
Cycles the motor relay
on/off. When the motor is
running the start/pause LED
is on.
dry temp(^ )
If motor is running, cycles
the heater/gas valve on/off.
When the heater is regular
temp LED is on.
temperature (Co)
Mar 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Most of buttons on touch pad are not working.
This was posted in another maytag qs300 thread there are 2 ways to fix the front panels on these dishwashers. My advice fix it as cheaply as possible and save some cash to get a better dish washer because these newer maytags are just plain awfull.
Quick fix for dishwasher from hell.
What I found was to turn off the breaker to the dishwasher, unscrew the inside panel ( about 12 Torx screws ), remove the black cover on the computer ( 1 hex head screw ) remove the ribbon cable coming from the front panel by easing down the plastic locking tab, then take a soft clean cloth and gently wipe the end of the ribbon cable (both sides) and reinstall. This keeps our machine working for another couple of month, when I go thru the same exercise again. I think it is condensation that makes the ribbon cable connection bad or short across two of the lands.
Permanent fix for dishwasher from hell.
The flex cable shown in the pictures above was bad on my unit also. It looks to me like they are pulling too much current through this cable to run all the LED's on the front panel. Mine died the instant death so I removed the touch pad and traced out the wiring.
The start/cancel switch is a connection between pin 6 and pin 10 on the ribbon cable. There is a 10K resistor in series with the switch to limit the current.
I tried to order the part from my local parts house and was told it was a special order only and would take about 4 weeks to get. Later I found you could purchase it off the internet and not have to wait quite as long. Since the replacement part is the full plastic piece across the top of the door I decided to try a mod. The touch panel is just glued to the plastic piece so I removed it completely. That leaves some glue that will need to be cleaned up but I can do that later.
I found a C&K momentary push button switch that fit in a 1/4 inch hole. I drilled the front panel in the center to accept the switch. If you moved it to one side it might not conflict with the latch switches quite as much but I made it fit.
I then looked in my junk box and found two pieces of 18 gauge wire and one 10K resistor. I put the resistor on the normally open pin on the switch and then connected a wire to that. The other wire went to the common pin on the switch.
When you look at the control board the pins are labeled as 2 on one end and 18 on the other. You only see every other pin as there is another row that is buried. You need pins 6 and 10 so they are on the visible row. Use a small soldering iron and connect the two wires up to those pins. It does not matter which one goes where.
Put it all back together and push the button. You do not have all the flashing lights or options but I am now washing my first load of dishes in several weeks.
These are copied word for word from the other maytag thread found here
Mar 01, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
My maytag fav68000 is displaying 2 cycles at once; it won't change or shut off
This could be an issue with the control board. I assume you have recycled he machine 120VAC power to turn off machine. If that did not help I would check to see if the control board will let you get into Service Mode.
Try this close the lid and try to enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00” Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on do you hear it run? Stop the test with the off button or hit the Presoak key. If you can get into Service Mode report back and we can try getting into the machine diagnostics mode.
If your FAV6800AWW will not let you get into Service Mode I would next replace the Control Board. The Control Board is under warranty for 5 years. Call Maytag at 1-888-462-9824 to see what your next step may be, I got them to send me the control board.
Do you have surge protection on the outlet powering the machine? Have you had any storm activity in your area recently?
Jun 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Dishwasher locked key has been activated.
To turn on Lock:
Press and hold Heat Dry for at least 4 seconds. The Locked light
glows. If you press any pad while your dishwasher is locked, the
light flashes 3 times.
To turn off Lock:
Press and hold Heat Dry for at least 4 seconds. The Control Lock
light turns off.
Dec 18, 2008 | Whirlpool Dishwashers
Maytag quiet series 300 no power to touch controls
We have the same problem of not being able to select a wash cycle, or the 9 min rinse keeps flashing.
The handle is another problen, I have changed this 3 times.
Went out this weekend and bought a Bosch.
Feb 08, 2008 | Maytag 24 in. MDB5651A Built-in Dishwasher
Control buttons don't work, Help.
donnson, sounds more like the touch panel shorted or stuck keypads. You can remove the touch panel ribbon from the control board and try to clean it with an eraser. You will need to remove the torx screws and remove the inside panel. See if it comes back to life. Behind the toe-panel on the bottom, there should be a tech sheet showing how to check the key pad. The key pad and control board are warranteed for 5 years on this model, parts only. back.
Jan 07, 2007 | Maytag 24 in. MDB7600A Jetclean® II...
Dishwashers Logo
150 people viewed this question
Top Dishwashers Experts
