Question about Canon PIXMA MP530 All-In-One InkJet Printer
Intermitent Ticking When power is on the printer has an intermitent ticking (approximately 16 ticks, then silence, then ticking, etc.) When ticking the Alarm light blinks. I recently had to disconnect the printer, computer, etc., due to a coming storm. The ticking problem did not exist prior to the disconnect. The printer copies and faxes as usual. Any possible answers are appreciated.
I determined that there was an incorrect connection from the printer to the main phone line jack. The DSL connection and the printer were reversed.
Posted on Sep 18, 2008
Seiki tv ticking
Please post once and wait.
Jul 13, 2017 | Seiki Televison & Video
My interior fuse panel is ticking
my 1998 jeep grand cherokee electrical system started shutting down while driving. i heard ticking sounds coming out from by the interor fuse box. after checking each fuse the fuse in the #16 slot (the fuse for the CTSY LPS 10A) is causing the ticking sound while putting the fuse in and out.whats next? please help.
Dec 21, 2011 | 1998 Jeep Grand Cherokee
My geo metro egine have a ticking sound
If you have adjusted your valves and the ticking persists then try changing your exhaust manifold gasket. A leaking exhaust manifold gasket will often make a loud ticking sound.
Sep 19, 2011 | 1997 Geo Metro
Ticking noise underneath the car approximately midway.
The sound you hear is the metal parts of your exhaust system and catalytic converter cooling down.Some cars are louder than others but the sound is perfectly normal.
Mar 01, 2010 | 2006 Toyota Camry
Ticking Noise at Startup
Possibly a leaking hydraulic lifter. They can leak down while engine isn't running and then make a ticking noise for a while on startup. If it takes 10-15 minutes to go away, it is more likely to be a loose tappet which needs adjusting.
Aug 02, 2009 | 1995 Buick Riviera
Hard disk
Generally a ticking sound indicates a faulty hard drive. If you can access your data, i suggest you back up your data as soon as possible.
there are several possibilities that cause the ticking such as:
1.) The clicking sound appears to only occur when the drive is idle. Forcing the drive to be busy silences the ticking while the drive is busy.
2.) repeated attempts to spin up the platters
3.) The ticking sound comes from the hard drive is caused by repeated attempts to find track 0.
if your noise occurs from solution 1, then I would'nt worry about the noise. However if its caused by problem 2 or 3, then I would backup data and purchase a new drive.
Hope this helps!
Brad Nelson
Mar 15, 2008 | HP Pavilion dv4000 Notebook
Won't turn on, ticking noise that continues when unplugged
Bad flyback transformer.....Emerson parts source ..Fox international or the partstore.com ...............T.
Jan 15, 2008 | Emerson EWF2703 27" TV
Actiontec Frequency
You can change the wireless frequency of the router, default is 9, check page 55 of your owner's manual (which is on your installation CD) Are you using the telephone portion of the router? There are NO settings in your wireless router or any consumer router to prevent what you are experiencing. BUT... Approximately 3 ticks a second equates to an 180hz signal. 180hz is a multiple of 60hz which is your powerline frequency. I'm suggesting that it is a noisy power feedback problem, since likely both the wireless router power transformer and the stereo power are on the same circuit. Touching the antenna changes the circuit output impedance which affects the signal. Your solution lies in one of the below, your choice: 1) Buy different speakers 2) Plug router into a different power outlet as far away from the stereo outlet as possible 3) Simply stretch the router as far away from the speakers as possible and live with the faint background ticking. 4) Buy a different router. ZT3000 "Beta tester of "0"s and "1's"
Aug 19, 2007 | Actiontec (GT704WG) Router
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
old marine
old marine
