Question about Indesit Washing Machines
I have an Indesit WIL 103 washing machine, i have had the machine about 4 years and this is the first problem. I put it on programe 2, the machine filled with water and took the powder but didn't move of that setting, it stayed on that first stage of the wash for a few about an hour if not longer. I then switched it off it had not taken the conditioner. I then switched it over to a manual rinse and it worked. The next day i tried another wash with programe 3 thinking it might be program 2 and the same thing happened it stayed on the first stage of the wash and will not progress any further. please help.
    President:
  • 1,462 Answers
Take back bottom panel off and check continuity thro the heater
Posted on Sep 17, 2008
What Indesit WIL 145 Flashing LED red,#1,#2,#3,#4 and 9h. Error?
It looks like an error F15 what means drying heating element earth leakage or relay contact sticking.
Dado
Oct 16, 2014 | Indesit Washing Machines
Indesit WIL 153 Door Lock
Hi John, did you ever fix your washing machine door as I have exactly the same problemw ith mine
Feb 20, 2010 | Washing Machines
Indesit washer wil 103
Check your water inlet valves. Seems like the valves have went away. Also check the computer board and inline fuse to make sure everything is correct. Inlet valve are located behind the supply line hoses. Please rate. Thank you
Feb 14, 2009 | Indesit W 123 Front Load Washer
Indesit wil 103 door won't open...
Welcome to Fixya.
Try holding the Start/cancel button in for at least 2 seconds.
If there is another lamp flashing at the same time as the door lamp, then you will have to call an engineer.
Dec 18, 2008 | Indesit W 123 Front Load Washer
Washing machine fault
Usually indicates door is not closed properly.
If it is shut securely, and still does not work, then you could have a faulty door lock.
Another possibility is the control unit could be faulty.
Nov 29, 2008 | Indesit W 123 Front Load Washer
Indesit wil 103 filter
stale smell may be due to using liquid detergent - change to powder.
filter may be of two types. if in the front, unscrew cap and just pull. may be difficult is a foreign object like a bra wire is stuck inside.
other type of filter is in the large diameter pipe from bottom of machine to pump. take off small back bottom panel and undo this pipe at the machine end and filter is inside this pipe. pull out and clean
Sep 04, 2008 | Indesit W 123 Front Load Washer
Indesit wil 103 heater element
no need to take drum out. heater is held by one 10mm nut in the middle of the heater. when tightened, this nut compresses the rubber seal and holds heater in place. loosen the nut. the heater will probably be too tight to remove by hand so carefully use a screwdriver to lever it out
Jun 26, 2008 | Indesit W 123 Front Load Washer
Indesit WIL 153
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (maximum 7 inches). Snaking out your standpipe would be good too.
Feb 02, 2008 | Indesit WA 115 Front Load Washer
Indesit washing machine, wil103
from the looks of it, this is called an f12 lights 1&2, communication error
which seems to be quite common. I've got the same problem.
If there's nothing in your filter, it could be the pcb (apparently, according to the research I've done so far).
Quite expensive apparently (£200?), but these machines don't seem very reliable, lots of people on the web having problems.
Dec 19, 2007 | Washing Machines
Washing Machines Logo
226 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
