Question about Zanussi Washing Machines
How do I access the motor of my Zanussi 1200?
  • bob66cat Sep 17, 2008
    There is no detachable back panel on these models. I need advice from somebody with genuine experience.
    These Diagrams are from a spares catalogue.I need dismantling instructions as it is clear that this is not a simple procedure.
    Genius:
  • 1,011 Answers
Dear,
check this link . scroll down and see the answer given to the question in details,
fixed4free.com/answers.php?id=25561
regards,
dont rate it until satisfied
Posted on Sep 17, 2008
    Scholar:
  • 148 Answers
YOU NEED A SCREW TO DO THIS, WASHER MOTOR IS LOCATED ON THE LOWER PART AT THE BACK. YOU NEED TO UNSCREW THE WASHER BACK COVER TO SEE THE LOCATION OF THE MOTOR..
KEEP US UPDATED HERE.
  • Zanussi Master
  • 19,396 Answers
The motor is at the back of the washig machine, down at the corner.
You will need to unscrew the back panel, and undo the belt routing to access to the motor.
    Guru:
  • 1,894 Answers
Open the back panel of the machine using a screw driver
and now you can view the motor easily
  • 6 more comments
  • dewan nafees ahmed Sep 17, 2008
    this diagram will help you understand that better
    thank you
    for more help
    please post back if you have further queries.
    thank you
    click here to see the source.
    on the left of page you can see the options of various other part diagrams
    this wil help you step by step to get to the motor with out any confusion
    make sure the washer is plugged off from wall power when you are doing these operations.
    thank you
    good luck
    have you looked at the part diagrams given by me??
    they belong to zansuui only
    and hence they must be helpful to you
    sorry about that
    see if this works
    this is one of the tips and tricks posted by one of our experts in fixya
    1. Unplug washing machine.
    2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
    a.
    If the console has removable end caps, the caps lift off by prying on
    the top from the back of the washer. The cap will pull off towards you
    as you are facing the unit from the front of the washer. There will be
    a screw under each end cap that you will need to remove.
    b. If
    the console does not have removable end caps, you will need to slide a
    putty knife under the front corner of each side and push in while
    lifting up. There is a retaining clip under each side that has to be
    released.
    3. Once the console has been released it will lift up
    and fold back over the back of the washer in its resting position. Use
    care not to stress the small plastic hinges that hold it on. They can
    break easily.
    4. Under the console will be two large brass
    colored clips. Take a large flat blade screwdriver and place it in the
    groove of the clip on the washer top. With the screwdriver firmly in
    the groove, push away from you towards the back of the washer. This
    will release the clips.
    5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
    6.
    Remove the washer casing. Open the lid of the washer. Using one hand,
    grip under the front rim of the washer opening. Do not grab the wash
    tub, just the casing. Tilt the washer case from the back first towards
    you, slide forward slightly, and then lift up. The entire case comes
    off exposing the wash tub and components.
    these photos wll give you step by step instructions on how to remove your unit.
    please let me know your feedbacks
    i am sure that the photos would have helped you
    please post me your feed back
Access motor belt zanussi aquacycle 1000
There is usually a hatch at the back of the washing machine.
Mar 17, 2014 | Washing Machines
Zanussi 1200 essential washing machine, cleaned out filter now will not fill with water
Go back into the machine and check for a disconnected wire cause by cleaning out the filter. Oh and did you remember to turn the water faucet back to the on position? It helps to plug the machine in to the A/C outlet, too. Keep an eye attuned to a safety switch on the access panel as well. It may have an alignment or broken plastic fastening/ mounting design.
Feb 08, 2014 | Zanussi F1045W Front Load Washer
Zanussi progress 1200 won't take softener into
Hi there
Now I am urprised. There must be three dispensers in your Zanussi as in my Candy.
One is for the main wash another for prewash and the third one for
the softner.
Look in the manual.
Kolbrun
Feb 26, 2012 | Zanussi Washing Machines
Need a free download user manual for a zanussi aquacycle 1200
You will need the model number to get an exact match, but there are 10 different aquacycle 1200 manuals you can download from here:
http://www.manualshark.org/s/zanussi+aquacycle+1200+washing+machine+instruction++manual/
Jun 28, 2011 | Zanussi Washing Machines
Have a Zanussi electrolux essential 1200 washing machine - when it reaches the fast spin cycle just as you expect it to start going very quickly it cuts out ? Many thanks
Sounds like the Tachometer on the motor is faulty, this is the built in revolution counter that controls the speed of the motor, unfortunately it means the motor needs replaced and they can be expensive, about half the price of the machine. But if you want to change it then it is quite simple, just 2 or 4 screws hold it in place and the plug an belt just pull off. Hope this helps.
Feb 28, 2011 | Zanussi FC1200W Front Load Washer
I have a Zanussi FLS1183W aquacycle 1050 washing machine. It has stopped spinning and I suspect the carbon brushes. How do I access the motor to examine/replace the brushes?
There is no solid base to this washing machine so if you simply lie the machine on its side you can access the motor from underneath.
Jun 01, 2010 | Zanussi Washing Machines
What is E 40 on Zanussi Turbodry 1200?
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board
Nov 24, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi Turbodry 1200 spin problem
if this washer is used alot then it will more then likely be the carbon brushes which u will need to take the lid off undue 4screws out where it joins front to the back screws at the back to the bottom and 1screw either side of the bottom where the panels join together behind a little cap which will have an hole in the middle of it to get it out u will then be able to get to the motor to replace the carbon brushes
Nov 22, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
Washing Machines Logo
294 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
