Question about Sharp Office Equipment & Supplies
U2 ERROR ON SHART 1622 PHOTO COPIER - Sharp Office Equipment & Supplies
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
U2-1 Eeprom problem U2-4 Memory line communication problem
Posted on Sep 17, 2008
Hi I have problem with my photocopaier. Sharp ARM236. It shows Code: U2-40
U2-04 EPROM error
U2-11 Main counter error
U2-12 EPROM error
As you can see there are many U2 error codes. Needless to say, find your code and the replace the bad part. The battery is on the main board. The EPROM is on the main board.
If you find your code, replace the part and error still remains -- replace main board.
Aug 07, 2011 | Sharp AR-M237 Copier
SHARP AL-1622 START BUTTON LIGHT OFF. NEW TONER.
Sounds like not coming to ready....Probably fuser issue. Themistor, lamp, thermofuse.
Apr 06, 2010 | Sharp AL 1631 Copier
Error code u-2 solution
U2 00 EPROM error 11 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication error
U2 04 EPROM error 11 Main counter error 12 EPROM error
U2 04 EEPROM serial communication error 11 counter check sum error 12 adjustment value check sum error(EEPROM) 40 CRUM communication errorYou need the service help. It is no a distans work Good luck)
Mar 14, 2010 | Sharp AR-5320 Black and White Copier
Copiadora sharp al1645cs aparecendo cod.u2
Press c photo c photo 16 press print key
Feb 10, 2010 | Sharp AL 1631 Copier
Error u2
Press #, Interrupt, C, Interrupt. Enter 16 print.
Dec 02, 2009 | Sharp AR-5320 Black and White Copier
ERROR CODE U2-40: SHARP AR 5127
ERROR CODE U2-4 COULD BE RELATED TO THE MEMORY BATTERY BEING DEAD ON TEH MAIN BOSRD IF IT IS AN OLD MACHINE SO YOU COULD CHECK THSI OR REPLACE AND TRY WITH NEW
Jun 12, 2009 | Sharp AR-5316 Advanced Digital Imager...
Error code U2 on a AR201 copier
Hello sir; This error code it can be reset folloe the instruction;
1, press "clear", "interupt", " 0 ", "interupt"
2, enter 16 then press start.
Jun 01, 2009 | Sharp AR 201 Copier
U2 PROBLEM blinking U2 and will not print
U2 RAM error
U2-00 EPROM error
U2-01 Counter error
U2-01 Memory back-up battery dead
U2-04 EPROM error
U2-12 EPROM error
Feb 03, 2009 | Sharp AR-5316 Advanced Digital Imager...
To find out the sub code for the U2 error hold down the Start key. Below is a list of the errors:
U2-04 EEPROM serial communication error
U2-11 Counter check sum error
U2-12 Adjustment value check sum error (EEPROM)
U2-40 CRUM communication error
To clear the U2-40 error try pulling out the toner cartridge and firmly reinstalling it. If that doesn't work you must install a new toner cartridge. There is a CRUM chip on the cartridge that keeps up with how many impressions have been made with that cardridge. You cannot "refill" these cartridges without replacing the CRUM. This problem occurs frequently with remanufactured cartridges.
To clear other U2 errors you must enter simulation mode.
Perform the following procedure to enter the simulation mode.
Clear key - Interrupt key - "0" key - Interrupt key - 16 - Start key - Start key. The unit should reset.
Nov 11, 2008 | Sharp AR 201 Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
