Question about Sharp AL 1631 Copier
Cpoier Flashing L # 1 is that low toner
  • Sharp Master
  • 2,794 Answers
Feeding is not completed within the specified time after starting feeding. (The scan head locking switch is locked)
Underneath the left side of the scanner is a locking mechanism for the scanner.  Turn it in the opposite direction and see if that works.
If that doesn't do the trick, there is binding on the ribbon cable underneath the scanner.  This can be fixed by removing the slack from it and taping the ribbon cable down with scotch tape.  make sure there is enough slack in the cable to move the scanner from one end of the glass to the other.
Posted on Sep 17, 2008
My CLP-315 is flashing red! what can I do?
A red FLASHING light means there is a minor problem with the unit.
According to the manual there are two options at this point; 1. read the error on the display and solve that problem or 2. The toner is almost empty and needs to be replaced. (you can see which toner is low according to the toner status symbols on the display and just try taking that cartridge out and GENTLY shifting it from side to side a little.) You can tell which toner cartridge it is becasue there will be an arrow in the display above it. Hope this helps.
Feb 08, 2011 | Samsung CLP 315 Laser Printer
Toner low and error is flashing
Your PC has detect low toner in your printer that led it show error flashing. Normally It can cause by 2 things : 1. You have a low toner ( need to replace toner) 2. You have a clogged up toner ( need to clean /service the printer)
Dec 03, 2010 | Dell 1700n Laser Printer
With toner low led flashing incoming fax goes to
kindly enter the Tech mode the clear the memory and update as a new cartridge.
Menu#1934
Feb 19, 2010 | Samsung SCX-4216F All-In-One Laser Printer
About Nashuatec Aficio SP 3200SF question
You could try going into the sp modes and check sp 5052-1 this is for independent toner check if the toner cartridge was checked by the copier as empty and you refilled it the machines check of the chip still senses it empty by turning this off it could reset it for you .. I have had some mixed results sometimes it works only occasional failure.. Hope it helps Good Luck A
Jul 03, 2009 | Ricoh Office Equipment & Supplies
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Tonner flashing HL-5140- will not print at all, drivers are good
If you have the user manual look on page 3-1 for Control Panel. The different patterns of on/off/blinking lights indicate what the problem is. If the toner is flashing and status is green, your toner is low and should be replaced....
If you don't have the user manual it is at this link:
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000071/HL5100_UG_ENG_3.pdf
see page 3-1 or page 81
Jan 18, 2009 | Brother HL 5140 Laser Printer
Toner low indication
Take out toner and shake up down . And put it again. may it will help you . Else let me know.
Feb 18, 2008 | Xerox Phaser 3124 Printer
Brother HL-1440/ flashing alarm light and flashing yellow data light
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Sharp AL 1631 Copier Logo
59 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
