Unsupported video configuration detected - Computers & Internet
  • Anonymous Jan 20, 2009
    unsupported video configutaion detected
This error message occurs if you plug a monitor into the integrated video connector but your computer also has an add-in graphics card - the computer won't allow you to use the integrated video if you have an add-in card.
See How to fix: Unsupported Video Configuration Detected for more details and solutions.
Posted on Feb 08, 2011
Do you have an add-on video card installed in your computer?
It's possible your video connection is plugged into the built in video adapter in your computer. Try having it plugged to your video card instead.
Posted on Sep 17, 2008
2 Suggested Answers
SOURCE: Unsupported Video Configuration Detected
The video files on my usb doesnt play in my pensonic tv
As far as we know, codec support is likely to be limited to whatever Panasonic decided to support in their TV. Unfortunately the video's you play on the TV will need to be formatted in such a way that they are encoded using codecs supported by the TV. Panasonic may have the list of supported codecs in the manual of the TV hopefully otherwise you would need to ask them or play the game of encode and test until you find something that works.
If your Panasonic TV can't either read some video file like MP4, MKV, MOV etc or when it does the images are kind of distorted with poor audio, you may get some videos encoded beyond Panasonic TV's support. Something even worse, you will not be able to install codecs onto a TV like you would a PC unfortunately. An ultimate solution to get unsupported format detected by your Panasonic TV is to convert unsupported videos to a Panasonic TV more friendly format with Pavtube Video Converter
Read Guide:
Best Way to Play unsupported videos on Panasonic TV from USB
Sep 11, 2014 | Televison & Video
Whenever i download a video form the net it says unsupported codec
If you can't play videos once you've successfully installed the YouTube for Mobile app, one of the following issues may be causing the problem:
  • Your phone may not support streaming video. Check by trying to play a video at http://m.youtube.com
  • Your streaming video access point may need to be configured outside of YouTube for Mobile. Depending on your phone and mobile data provider, this access point may need to be the same or different from YouTube's. For more help with these settings, please see the "Access Settings" article.
  • If you've successfully played videos with YouTube for Mobile before, your network connection may not be strong enough at the moment. Please try again later.
  • Your carrier might block RTSP traffic which is required to transfer the video.
    hope this helps
Feb 29, 2012 | Samsung Corby 2 GT S3850
When i start devil may cry 4 in window 7 stater it says error erro6: unsupported pixel shdder version detected 2.0
Hello
This is a video device error usually beacause your video card or chipset is not current enough to run the game.
You can try running game on lowest video settings or update your video device drivers.
May 17, 2011 | Capcom Devil May Cry 4
Error Message: 104-Unsupported wireless network device detected. System Halted. Remove device and restart.
And when you did that, did the system then work? If it did you may have a faulty WiFi card or an incompatible driver.
Feb 23, 2011 | HP Compaq Presario V2000 Notebook
When i play the game error 6 shwn unsupported pixel shader detected 2.0
Your video card is the problem.Your video don't support pixel shader.Try Upgrading ur video card, i think 1gb video card is the best
Feb 23, 2011 | Capcom Devil May Cry 4
An unsupported memory module was detected a
Sounds like the Memory Ram that you tried to install went haywire. Take it out and make sure this ram is compatible.
Apr 10, 2010 | Dell Latitude C810 Notebook
Apparently you set a video resolution which your monitor isn't able to handle. Try booting in safe mode by holding the F8 key at boot, then change resolution to something safe such as 1024x768. Reboot in normal mode and set the resolution you're most comfortable with.
Oct 29, 2009 | Dell Dimension E510 Dual Core 2.8 Ghz...
104-unsupported wirless network device detected system halted.remove disk and restart. in my compaq laptop cq40-601
104-unsupported wirless network device detected system halted.remove disk and restart. in my compaq laptop cq40-717TU
Oct 05, 2009 | HP Pavilion dv1000 Notebook
"A video capture device was not detected"
It is unlikely that the 'latest' drivers will work with an unsupported OS like XP
Nov 05, 2017 | Sony Handycam DCR-TRV19 Mini DV Digital...
Computers & Internet Logo
1,765 people viewed this question
David Payne
David Payne
