Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whilpool washer #LLR6233ANO
Washer stops during the wash cycle.also if i move the timer knob to spin it also does nothing machine full of water.
  • 5,911 Answers
The symptoms you are describing are usually caused by a lid switch malfunction. A lid switch is a very simple and inexpensive fix. The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
In many cases a simple inspection of the lid switch is all it takes to fix it. It could be loose or not making proper contact. Check the mounting screws that hold the switch in place, first. If the screws are loose or missing, that may be all this required to get the switch to line up correctly with the lid strike. The lid strike is a small plastic piece that is physically mounted to the washer lid. The strike activates the switch through a slot as the lid closes. If the lid strike is broken or missing, this will also cause the same symptoms.
If the model number you have this listed under is correct, you can find replacement parts at searspartsdirect.com. Just type in the the model number and you can locate what you need under the "Top and Cabinet" heading. The lid switch is item number 9 (part #285671) and the lid strike is item number 20 (part #358684).
I hope you find this information helpful. The total cost of your repair is less than $50 if you follow the instructions in the link I provided and repair it yourself. Let me know if you require additional assistance.
Posted on Sep 17, 2008
Will not rinse or spin
I have had similar situation with my top load washer over the years. It has been the timer 3 times and the water pump 1 time.
How I came up with it being the timer. The knob which you set it on the type wash you want. Put it on a different cycle and see if it completes the wash cycle. example if my washer is not working when I put it on heavy wash cycle I might put it on the casual wash cycle. If you change the wash cycle and it goes through the complete cycle it is probably the timer which is part of the knob you change for different wash cycles with.
If it stops when it is time to empty the tub on all cycles it may be the water pump which empties the tub. The one time I had a problem with the water pump it was a small piece of coal had the pump locked up. I never figured how it got out of the tub and to the pump but I put it back together and it worked fine.
It should not go into the spin cycle if the tub is full of water.
Two of the timers I bought cost 40 - 60 dollars. One was 140 dollars I bought a new washer that time because the washer only cost 220 dollars.
Dec 03, 2017 | Estate Washing Machines
Timer stops intermittently during spin cycle
When it stops try wiggling the timer knob if you get it to start most likely have a timer problem not connecting inside the timer. Hope this helps
Jan 03, 2018 | Kenmore Whirlpool Washer Timer 3351811...
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
I filled my washing machine with clothes tonight and it got to the end of the short cold wash cycle and had stopped running so I pushed in the knob then pulled it back out and then pushed it back in and...
It sounds as if the machine doesn't spin during the spin cycle. Normally the agitator stops spinning, fairly quickly, if the lid is opened during the spin cycle.That safety circuit includes a switch mounted under the opening and is set by a tab on the lid that protrudes thru a small hole in the top of the washer. The most likely failure on most Kenmore models is that switch, broken or loose, the tab on the lid broken, or the two misaligned. I would need the model number of your washer, located on a tag on the bottom of the lid to be more specific
Jan 07, 2010 | Kenmore Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
My frigidaire top loader fills with water at the beginning of the wash...then nothing. it just sits there full of water.
Hi, could be your timer motor, timer or water level switch, first push timer knob in and manually advance to wash or spin cycle (program) then pull knob, see if machine operates, let me know, then i can tell you exactly what's problem.also advance timer, to spin cycle (program) machine should pump out water, or you can lower drain hose into bucket and empty machine, you should empty machine and try again, let me know what happened, we can solved this together. good luck.
Aug 12, 2009 | Frigidaire FWS933F Top Load Washer
My washer stops after the wash cycle. not draning or spinning
CHECK THE RUBBER DRIVE BELT FOR THE PUMP UNDER THE WASHING MACHINE
May 09, 2009 | Washing Machines
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
    236 people viewed this question
    Dan Webster
    Dan Webster
    Sal De
