Question about Maytag Washing Machines
Maytag front loader stackable error code od. - Maytag Washing Machines
I just got this today, too. i think it has to do with an overload.
Posted on Sep 23, 2008
What is E2 F4 error code mean on my Maytag front loader washer
Here's a good source for error codes for Maytag washers here:
Maytag Fault Codes
or here:
Washing Machine Fault Codes Tips Tricks Recipes
I hope this helps you :-)!
Apr 22, 2016 | Maytag Washing Machines
"nf" error code on Maytag front load stackable
I think your hunch is probably correct. "nf" is "no fill" or "slow fill" so if the machine is in a cold enough location it likely has frozen supply lines or inlet water valve. About all you can do is slowly warm the area around it with a space heater or wait until Spring. I wouldn't try to warm it in a day though. Frozen pipes that are thawed too quickly can break, leaving you with a real mess on your hands, possibly even structural damage to the property. All you need to do is get the temps above freezing, it doesn't need to be balmy. If you use an electric heater make sure it is well away from combustibles and the machine if possible. When water lines break they tend to spray where they want so keep that under consideration when placing the heater and make sure it's off the floor. If i started warming the room today i wouldn't even try to use the machine for a week. And i'd babysit it as much as humanly possible. Good luck.
Jan 24, 2013 | Maytag Washing Machines
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
My front loader washer is having the error code od and will not start. What does this mean and how can I fix this?
OD: Opened Door not sensed by machine control board. in this case the lid switch needs attention. or washer door. hope this helps ! 1.Make sure door is closed. Check for loose wire connections at switch and/ or machine control board. .Check for failed door monitor switch. good-day !
Nov 14, 2011 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune top loader model fav6800aww has an error code od
See if this post http://www.fixya.com/support/t4757262-i_have_a_letter_showing_and_it_say_o_d_w will get you started.
You have lost signaling from the Left Hand Lid Lock. If you want to DIY I will try to help........Rich
May 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
rlbishop720,
See this post Left Hand Lid Lock Troubleshooting . I discuss Left Hand Lid Lock troubleshooting for error codes OD,OP FL, FO all related to Left Hand Lid Lock issues. I also provide a link to purchase a replacement Left Hand Lid Lock if you don’t want to deal with a DIY fix.
Let me know if I can help…..Rich
Mar 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
"od" error code Maytag Neptune FAV6800Aww
At 12 years of age, your Maytag may be telling you it needs to be replaced.
Sep 23, 2017 | Maytag Neptune FAV9800AW Top Load Washer
Maytag stackable washer top loader
try replacing entire lid switch assy, come ith new fuse!
Oct 31, 2008 | LG WM2077CW Laundry XL Front Load...
Washing Machines Logo
223 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
