Question about Dishwashers
GE Adora Dishwasher Upper Rack Binding Issue
In April of 08 we bought all new GE Adora appliances. So far, everything has worked very well except for an issue with the upper rack of the dishwasher. When you pull the upper rack out to put dishes in, it pulls out effortlessly for the first ten inches. The last nine inches are a struggle. Same thing happens when you slide it back in. Typically, after pushing it back in, it is full of dishes including drinking glasses which always topple over because of their height, and the force required to overcome the friction of the binding roller glides. Evidently they used large plastic rollers that capture and guide the upper and lower part of the stainless steel slide assembly for the first ten inches and that part works well. The last nine inches or "extended" position utilize small rubber wheels that are captured inside the "C" channel and that is where the binding takes place. To prove it I used petrolium jelly on a Q-tip and lubricated the inside "C" of the glide and it worked perfectly for the first two or three washes until the soap action eventually did it's job and removed it. I consider this a "serious" issue as it is not user friendly.
Has anyone else experienced this? Is GE aware of it? Is there a fix?
Any information would be appriciated. budscarp at AOL dot com
  • 2 more comments
  • smu960 Nov 08, 2008
    I have a GE model GLD6760 and am also having problems withe the top rack not rolling out smoothly. It has the same problem with the 'C' channel and the rubber wheels inside binding. It occurs even without dishes in the rack so it does not appear to be an over load issue. Any help on this?
  • terrytroy Nov 29, 2008
    I have the same problem with a new GE Profile. The upper rack binds in both directions while travelling in the c channels. It is getting worse and worse.
  • Anonymous Mar 06, 2009
    I have the same problem with a GE Profile. The GE serviceman replaced the rack and it seemed better for a little bit but now it's worse than ever. He blamed in on our hard water. I'm glad to know that I'm not the only person with the problem but it would be nice if there was a solution.
  • dc9art Mar 12, 2009
    My upper rack binds in both directions. I'm wondering if there is a better set of rollers or glide mechanism that can replace this system. Seems to be an ongoing problem.
GE repairman came out and replaced the rollers. He replaced the rollers with the old style rollers. He said the new rollers that they were using were not working as well as the ones that they have been using for the past 15-20 years. Works good now problem solved.
Posted on Apr 08, 2009
I have a GE Profile model PDW7800.... and just replaced the rollers on one side since one of them had broken. There is a 'magical' way to reinstall the rack so the side guides ride inside the roller guides without touching. I suspect that the rack has not been reinstalled in the precise manner - which I am still trying to figure out. The new roller assembly which attach to the rack fit differently than the original ones. I found that you do have to remove the rollers screwed into the wall to get the glides out and that could also cause rough gliding. Part of the 'binding' is designed, I believe, to keep the racks from coming out too easily.
Door will not shut when upper silverware holder is in
Make sure you are installing that silverware holder properly. The little tabs of the silverware holder are supposd to go over and around the mating bars of the upper rack. Barring that, your upper rack may be pulled (bent) out, and you may have to push it (hard) to get it back in shape.
Oct 30, 2014 | General Electric Adora GHDA670N Built-in...
Top rack automatically slides out upon opening door
This is actually a feature to allow the user easy access of sliding out the top rack. A look at the parts diagram disclosed that there is no mechanism activating this and therefore could be assumed to be gravity driven. It would stop a few inches due to the action or rather inaction of the rollers which would require user intervention (pull).
The only modification I could think of is to change how the inner rails are attached by inclining it to prevent the sliding out. The idea would be to lean in the upper rack to prevent gravity from sliding it out. Am not sure if inclining the entire dishwasher would affect the overall performance but it is also a possibility.
I have taken the liberty of including the diagram of the upper track should you wish to reference it.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 28, 2008 | GE PDW8680NSS Built-in Dishwasher
KitchenAid Custom 21 Dishwasher. The arm for the upper rack does not rotate or spray when in use. Water just dribbles out, so dishes in upper rack do not get clean.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 22, 2011 | KitchenAid Dishwashers
How to replace the top rollers on a GE dishwasher model # gsm1800nww
Lower Rack
  • Remove all of the dishes from the lower dishwasher rack.
  • Pull the lower rack out of the dishwasher so that it rests on the dishwasher door.
  • Lift the lower rack up and out of the dishwasher.
  • Place the new lower dishwasher rack on the dishwasher door, then push it into the dishwasher.
  • Upper Rack
  • Extend the upper rack as far as it will go.
Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
Pull the upper dishwasher rack straight of out the arms to remove.
Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
. Align the end caps with the ends of the arms, then push the end caps into place.
Upper Rack
  • Remove the two plastic end caps, located on the end of each dishwasher arm. To remove, insert a flat-head screwdriver between the arm and the tab on the outside of the end cap, then lift the tap to remove the end cap.
  • Pull the upper dishwasher rack straight of out the arms to remove.
  • Insert the rollers on the bottom of the new upper dishwasher rack into the rack arms, then push the rack completely into the dishwasher.
  • Align the end caps with the ends of the arms, then push the end caps into place.
Feb 04, 2011 | Maytag Dishwasher
I have a GE profile dishwasher. The wheels on the lower rack have all come off and I can't seem to get it back on. On some, the piece that snaps to the rack is either broken or melted off somehow. Do I...
You just need the wheels. I have bought the upper rack wheels before, now I need the lowers. I have found a site selling them at 10.00 each. I am going to keep looking, I think I can do better, considering I need 4. I might just buy a new washer if I have to spend 40.00 plus shipping! I will post back if I find a better deal.
Jan 08, 2011 | GE Dishwasher Lower Rack Roller WD12X10262
Our dishwasher is not cleaning the glasses. The plastic rinsing mechanism seems to get clogged on the upper rack all them time.
Dishwasher
How to Buy
heatman101
Jan 08, 2011 | GE 24 in. GSD3960LSS Stainless Steel...
Ge adora dishwasher water won't fill
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 | Dishwashers
5 yr old GE Adora -- have it repaired or replace?
look in the back and make sure the drain hose is about 18 ins high if the hose falls it will not hold the water in the machine
Feb 10, 2010 | GE Adora GHDA656LSS Stainless Steel...
Top rack slider
All I can think of is that the runners on the rack are not in the runner slide on the machine properly or there is an obstuction (EG:loose screw)in the runner on the machine side
Jan 22, 2009 | GE Adora GHDA656LSS Stainless Steel...
GE Adora QuietPower II Replacement Rack Wheels?
Model number is on a sticker on the left wall of the dishwasher, just behind the door, about mid tub level. Post your full model number and I'll list your part number(s) for you.
Sep 06, 2008 | GE Adora GHDA656LSS Stainless Steel...
Dishwashers Logo
1,393 people viewed this question
Top Dishwashers Experts
