Question about Jenn-Air JSD2789GEW Side by Side Refrigerator
Jenn-Air Side by side. The freezer compartment ices up and the refrig does not get cold.
I've tried defrosting in which the problem does not change.
  • 1 more comment
  • sieverts5 Dec 01, 2008
    the freezer ices up so much and then blocks the air flow to the refrigerator and the fridge side stops working. A tech came and defrosted the freezer, and said it would probably do the trick, but with in days we were back to a freezer frozen and a fridge barely working. In the solution section some one said it is a switch in the back of the freezer. What is this switch called and exactly were is it?
  • curtsrefrig Dec 10, 2008
    Can not locate the defrost control.
    Jen-airr JSD2989AEB
  • Debbie Feb 25, 2013
    Ours is doing the same thing, did yours get fixed? Thanks
No encuentro eu programa para manejar el celular desde el computador
Posted on Sep 17, 2008
The switch in the back of the ref. needs to be replaced it just happened to ours
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
Freezer working but no cold air to refrig.
check the damper vent door located behind a plastic cover between the freezer and refrige compartments,also make sure the evaporator fan is operating to blow cold air through this door,if the door isnt open,then either its frozen shut due to moisture or the motor that controls it is bad
May 13, 2011 | Jenn-Air Jenn Air Side-By-Side...
Fridge is out of gas in fridge compartment. Freezer compartment is in order
if the freezer is operating ok,then the refrige side isnt out of gas,its the damper vent door between the freezer and refrige thats not opening to let cold air into fridge from freezer,sometimes they stick shut due to ice from condensation on this door,remove grille cover on damper door and check this,if iced up defrost it with a hair dryer,then change temp selector and make sure door then moves with temp change
Mar 24, 2011 | Refrigerators
Freezer coils icing up, refrig not cooling 8 years old expensive where is thermostat control
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 17, 2010 | Jenn-Air JCD2389G Side by Side...
Older model fridge freezes on the refrig. side
check the damper door and see if its iced up this is between the refrige and freezer compartments and lets cold into refrige from freezer,if it ices up in the open condition the refrige control cant change the temp,defrost the door and then see if the control moves the door,if so also check the door seals to make sure they are sealing good so as not to let warm air in that can condense and freeze things like the damper door
Jan 16, 2010 | Refrigerators
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn Air freezer does not 'automatically defrost-side by side
Nov 29, 2009 | Jenn-Air JCD2295HES Side by Side...
I have a Jenn Air refrig JCD 2389GES....the frezzer is working fine, the the fridg is warm.....what should I do? I took the ice maker out and cleaned the slots behind it....the fridg side is still not...
Check the circulation fan in the freezer compartment that circulates the cold to the fresh food compartment. If its not running, and no ice is on it to bind uo the blades, replace the motor.
Aug 04, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn Air JCD2389 fridge not cold on fridge side
You have plugged the defrost drain line.This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Try it and let me know!
Sep 26, 2008 | Jenn-Air JCD2290HES Side by Side...
Jenn Air JCD2389GTW Refrigerator problem
change the adaptive defrost board located in the upper right corner of refrig under the panel. remove panel by pulling on panel towards you from the finger holes in the rear. remove two 1/4 inch screws and two phillips screws. defrost manually with hair dryer behind panel in freezer.
Jan 19, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JSD2789GEW Side by Side Refrigerator Logo
164 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
