Question about Siemens Computers & Internet
Every time i log on to my computer it says the profile u will be loged onto is temporary due to a coruped file or lack of internet security right if the problem persist please contct your locals adminstartory however im the ownly one who uses my computer and i dont have a coupted file since ive don the virus scane sevaral times and there nuinthing i dont know how to log into my normal profile again this profile does not have any of my file ect and documents and does not store any new documents ect each time i researt my computer it will be fresh
I had the same problem and i found the easiest way to fix the problem was put in windows disk and reinstall using upgrade feature
Posted on Sep 17, 2008
My hp pavilion g series is loged on to a tempery profile so every time i log off everything is erased
Every time that you log on to a Windows Vista-based computer that is connected to a domain, a temporary user profile is created.
When you log off the computer, the user profile is deleted.
This behavior usually occurs because the account that you use to log on to the computer is a member of one or more of the following groups:
•Guests
•Domain Guests
If this is a school/work computer then this is most likely the way the NetAdmin has set it up.
If this is your home computer then a temporary user profile is issued each time an error condition prevents the user's profile from loading.
You may encounter profile issues if you log on with a user in the Guests group.
You need to remove the user in question from the local Guests or "Domain guests" group and that should do it.
1. Click Start
2. Right click Computer and Select Manage
3. Select Local Users and Groups > Groups
4. Double click Guests
5. Check if the user that is having the issue is a member of the Guests group
6. If so, remove the user from the Guests group
7. Log off the workstation and log back on
8. Verify the profile is now local
or
Try following these steps and check if it helps:
Important: This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly.
Therefore, make sure that you follow these steps carefully.
For added protection, back up the registry before you modify it.
Then, you can restore the registry if a problem occurs.
a. Log on to the system by using an administrative user account other than the user account that is experiencing the problem.
b. Back up all data in the current users profile folder if the profile folder still exists, and then delete the profile folder. By default, the profile resides in the following location:
%SystemDrive%\Users\UserName
c. ClickStart, typeregedit in the Start Search box, and then press ENTER.
Collapse this imageExpand this imageIf you are prompted for an administrator password or for confirmation, type your password, or click Continue.
d. Locate the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
e. Under the ProfileList subkey, delete the subkey that is named SID.bak.
Note SID is a placeholder for the security identifier (SID) of the user account that is experiencing the problem.
The SID.bak subkey should contain a ProfileImagePath registry entry that points to the original profile folder of the user account that is experiencing the problem.
f. Exit Registry Editor.
g. Log off the system.
h. Log on to the system again.
After you log on to the system, the profile folder is re-created
hope this helps
or
1. Use SFC / SCANNOW command to help you detect and fix any corrupted or missing system files.
1) Go to Start menu, expand "All Programs" - "Accessories" - "System Tools", right-click "Command Prompt" in the pop-up menu, select "Run as administrator", then input "SFC / SCANNOW" without quotation marks and press Enter.
2) When the "SFC / SCANNOW" command is running, this command will scan every corner of your system, and repair the missing or corrupted files.
2. Shift to another administrator user, if you don't have one, please create a new administrator account and log in.
3. Navigate to C:\Documents and Settings folder, backup the data of your original corrupted profile, then delete the corrupted profile and all the temp profiles.
4. Open Registry Editor (type "Regedit" without quotation mark in the start menu blank and open it), search for HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsNT\CurrentVersion\ProfileList, under the profileList subkey, delete the key named SID.bak.
5. Restart your computer; you will be able to log in the normal profile again.
hope this helps
Sep 23, 2012 | HP Pavilion G4 G6 G4-1000 Series...
Tip
CANNOT OPEN SECURED SITES ????
After you upgrade to Microsoft Internet Explorer 6.0 Service Pack 2 (SP2) in Microsoft Windows XP SP2, some SSL-secured (128-Bit) Web pages and Web sites may not work correctly. Frequently, this behavior is caused by security changes in Windows XP SP2. To determine why the pages do not display correctly, use the following methods in the order that they are presented.
Turn off the pop-up blocker
Internet Explorer SP2 includes the ability to block pop-up windows. This new feature may block some Web pages. To turn off the Pop-Up Blocker, follow these steps: 1. On the Tools menu in Internet Explorer, click Internet Options, and then click the General tab.
2. Click the Privacy tab.
3. In the Pop-Up Blocker section, click to clear the Block pop-ups check box.
4. Click Apply.
5. Click OK.
Delete the contents of the Temporary Internet Files folder
If a copy of the Web page is in the Temporary Internet Files folder, the page may not display as expected. To resolve this problem, you must delete the contents of this folder. To do this, follow these steps: 1. On the Tools menu in Internet Explorer, click Internet Options, and then click the General tab.
2. Click Delete Cookies, and then click OK.
3. Click Delete Files, and then click OK.
4. Click Clear History, and then click Yes.
5. Click OK. Configure security, content, and advanced settings in Internet Explorer
Configure the security settings for the Trusted sites zone in Internet Explorer
Note Only add those sites that you trust as a trusted site. If you are not sure about a Web site, do not add the Web site to the Trusted sites list. 1. On the Tools menu in Internet Explorer, click Internet Options, and then click the Security tab.
2. Click Trusted sites, and then click Default Level.
3. Add any SSL-secured (128-Bit) Web sites to the Trusted sites zone. To do this, follow these steps: a. Click Sites.
b. Type the URL of the site in the Add this Web site to the zone box.
c. Click Add, click OK, and then click Apply.
Reset the Security Zones to the default settings
2. Click Internet, and then click Default Level.
3. Click Local Intranet, and then click Default Level.
4. Click Trusted sites, and then click Default Level.
5. Click Restricted sites, and then click Default Level.
6. Click Apply.
7. On the Privacy tab, click Default, and then click Apply
Clear the Secure Sockets Layer (SSL) state and the AutoComplete history
2. Click the Content tab.
3. In the Certificates section, click Clear SSL State, and then click OK.
4. In the Personal information area, click AutoComplete.
5. In the Clear AutoComplete history area, click Clear Forms, and then click OK.
6. Click Clear Passwords, and then click OK three times.
Verify that Internet Explorer is configured to use SSL 2.0 and SSL 3.0
1. On the Tools menu in Internet Explorer, click Internet Options, and then click the Advanced tab.
2. Under Security, click to select the Use SSL 2.0 and Use SSL 3.0 check boxes if they are not already selected, and then click Apply.
3. Click Restore defaults.
4. Click Apply.
5. Click OK.
Use the System File Checker tool to scan all files that are protected by Windows File Protection
Use the System File Checker (Sfc.exe) tool together with the /scannow parameter to immediately scan and verify the versions of all the system files that Windows File Protection helps protect. If the Sfc.exe tool detects that such a file was overwritten, the Sfc.exe tool retrieves the correct version of the file from the Dllcache folder or from the Windows XP installation source files, and then replaces the incorrect file. The Sfc.exe tool also verifies and repopulates the cache folder. You must be logged on as an administrator or as a member of the Administrators group to run the Sfc.exe tool. To run the Sfc.exe tool together with the /scannow parameter, follow these steps: 1. Click Start, and then click Run.
2. In the Open box, type cmd, and then click OK.
3. At the command prompt, type sfc /scannow, and then press ENTER.
4. Type exit, and then press ENTER.
Third-party browser extensions
Some third-party browser extensions and add-ons may interfere with how Internet Explorer views certain Web pages. To turn off these extensions, follow these steps: 1. Click Start, right-click Internet Explorer, and then click Internet Properties.
2. Click the Advanced tab.
3. Click to clear the Enable third-party browser extensions (requires restart) check box.
4. Click Apply.
5. Click Ok.
6. Start Internet Explorer, and then try to reproduce the issue.
If the issue does not occur, you can try to determine which third-party browser extensions may be causing the problem. To revert to the original settings, follow these steps: 1. Click Start, right-click Internet Explorer, click Internet Properties.
3. Click to select the Enable third-party browser extensions (requires restart) check box.
4. Click Apply.
5. Click the Programs tab.
6. Click Manage Add-ons.
7. Click Add-ons that have been used by Internet Explorer.
8. Select all but the first of the add-on check boxes that are installed.
9. Click Disable.
10. Click OK.
11. Start Internet Explorer, and then try to reproduce the issue.
If the problem does not occur, select the next Add-on check box in the list, and then try to reproduce the problem. Select each check box in turn until you determine which add-on is causing the problem. When you have determined this add-on, contact the software manufacturer for information about updates for the add-on Create a new user profile
In certain situations, you may not be able to search Web sites if your Windows user profile is damaged. To troubleshoot this, log on to the computer as another user and try to connect to a Web site. If you can connect to SSL- secured (128-Bit) Web sites when you are logged on as a different user, your user profile may be corrupted. In this situation, back up the information and settings that you want from your profile (for example, the My Documents and Favorites folders), and then delete the damaged profile. To delete a user profile, follow these steps: 1. Log on to the computer as Administrator or as a member of the Administrators group.
2. Click Start, click Run, and then type sysdm.cpl.
3. Click the Advanced tab, and then under User Profiles, click Settings.
4. In the Profiles stored on this computer list, click the user profile that you want to delete, and then click Delete.
5. Click Yes when you are prompted to confirm the deletion.
6. Click OK two times.
7. Log off the computer as Administrator, and then log on as the user. Windows XP will then create a new profile for the user.
Note Alternatively, you may want to create a new user, and then copy the data from your old profile to the profile of the new user. For more information about how to copy your profile data, click the following article number to view the article in the Microsoft Knowledge Base:
on Feb 07, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Unable to log in to my e-mail account with yahoo......I am using my friends computer,,,,,every time I try to delete her ID to get mine her comes up,,,,we are sharing the computer,,,it worked last...
Try clearing your cookies and temporary internet files. If you are sharing a computer you can always create a new profile and log in as your profile. That way you can keep things separate even if you are sharing the one computer.
May 05, 2011 | Yahoo Mail
Desktop won't load. It goes to the login screen and I type in my password, and it'll say "Welcome" with the spinning circle for a long time, then it'll load me onto a temporary profile. How do I...
go into control panel and create a new user (dont make it the same name as your old profile) then restart the pc and log into that new profile. To retrieve all your settings favourites etc you will need to say what version of windows you are using
Feb 12, 2011 | Toshiba Computers & Internet
Roaming profile error when I log on with my hnah\3500018 id.
how to solve Windows cannot find the local profile and is logging you on with a temporary profile. Changes you make to this profile will be lost when you log off.
Apr 15, 2010 | Profile 200SX Car Audio Amplifier
Problems loging in to my accounts
I hve 2 prfile.but I used one profile..So today I loged my privious profile........so its locked
Jun 15, 2009 | Facebook Social Network
Cannot download adobe, (or any) files and get following message:
The problem lies in the Temporary Internet Files folder. Sometimes the index.dat file can become damaged.
If this occurs, you'll have to delete the index.dat file and restart your computer.
Then you'll be able to download files correctly again.
Follow the steps below to delete this file.
1) Open Internet Explorer.
2) Click on Tools, Click on Internet Options
3) On the General tab under Temporary Internet Files, click on Delete Files
4) Click Ok when it asks if you want to delete the files
5) Under the History section on the General tab, click Clear History, then click Ok
6) Close Internet Explorer
7) Log off the current user and Log onto another user account such as Administrator
8) Click on Start, Run
9) Type CMD and Press Enter to open a command prompt
10) Change directories to the Temporary Internet Files directory by typing the following command,
(substituting the correct drive letter and the word username with the correct userName).
cd drive:\Documents and Settings\username\Local Settings\Temporary Internet Files\Content.IE5
Example: cd c:\Documents and Settings\Mark\Local Settings\Temporary Internet Files\Content.IE5
11) type del index.dat and press Enter
12) Type Exit and press Enter to close the command prompt
13) Restart your computer
Once the computer has been restarted, open a web page with a link to a download.
Click on the link and download the file. It should now work.
Please take time to rate this fixya
May 11, 2009 | Internet Compaq Evo N600C Laptop
Once I'm logged in to Facebook, when I click on my profile page it won't load.
This might be due to a limitation on Active X or other components on your IE.
Go to Tools - Internet Options
Under Security, go to "Custom Level"
Under Active X controls and plug-ins - Enable all of the subsections.
Restart and try again.
If it does not work:
Try downloading Firefox and see if the problem persists. If it does not - I suggest uninstalling IE, deleting all temporary internet files and cookies, and reinstalling.
Also try downloading Adobe Flash.
Oct 21, 2008 | Computers & Internet
CANT SIGN ONTO MY WINDOWS PROFILE AND ACCESS MY FILES
you did'nt give me anymore info so tyr this
once logged in go to control panel and then to user accounts
you can delete user in there
let me know
Jul 11, 2008 | Toshiba Satellite A105-S4004 Notebook
Laptop doesn't normally start
This sounds like an operating system glitch. Enter safe mode at start up by pressing F8. Once in safe mode, log on as administrator and do a system restore to a point that you recall it allowing you to log onto your profile. This should cure it, if not, let me know and we'll try something else.
Jul 05, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
64 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
