Question about Ovens
Temperature fault Hi,  I have a Delonghi ESM 460 electric multifunction oven and about a week or so ago my partner told me that the temperature knob fell off.  It went back on ok and the pin that the knob sits on appears not to be damaged however whenever I am cooking anything in the oven now it seems like it is going straight up to the top temperature all the time.  I have taken the know off again and tried to turn the pin with plyers but as I said previously it looks to be ok, ie when it goes back to 0 degrees it stops and goes no further than the top temperature. If the know falls off should it affect the temperature gauge? Regards David
Hi there, usually when those knobs fall off as long as you can guess where it would normally be, all functions work the same. In terms of falling off, they are made to come off for cleaning. Also, could I bother you, you dont have the manual for this oven do you? As we need a copy? Thanks a lot, Kerrie.
Posted on Jan 12, 2009
Preway oven doesn't come to temperature
I Also have a wall oven by preway in a 1955 spartan trailer, basic same problem, I am told the control assembly that you turn to set temperature needs to be replaced, if it is adjusted to far on some part behind the controll knob it will screw up the new one also, Spencers appliance in Portland Oregon worked on mine years ago and was able to get parts, Good Luck
Feb 04, 2012 | Ovens
The F5 error code?
Range/Stove Oven Fault Codes, Common Failure
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
Nov 03, 2007 | Whirlpool GBS307PR Electric Single Oven
Broiling and baking element in my electric oven are not heating.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in series on the circuit from electroning oven control to elements. The probe will control both baking and broiling element, opening the circuit when limit temperature is reached.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
on Mar 03, 2010 | Whirlpool RBS275PD Electric Single Oven
Temperature does not always reach set point of 425 F.
Oven will not hold correct temperature:------- This can be caused if temperature probe not working.Resistance across temperature probe leads at room temperature (70°F) should be approximately 1096 ohms.----------- Other possibility for this problem is :--- Temperature control not calling for heat.When heat is required, there should be continuity between terminals 6 and 7 on temperature control.-----------Inadequate or improper ventilation.Check ventilation hood. Verify draw and make up air adjustment.-----------If all this checked out ok then its calibration problem.For calibration follow this procedure:--
It can be problem with temperature controller. TEMPERATURE CONTROLLER (Standard-Control Models Only) The calibration of the temperature controller should not be changed until sufficient experience with cooking results has definitely proved that the temperature controller is not maintaining proper oven temperatures. Before any recalibration is attempted, the oven temperature should be checked by the following procedure: 1. Remove all trays and pans from the oven. 2. Place a thermocouple or a reliable mercury oven-type thermometer at the center of the middle rack. 3. Turn the oven ON and set the temperature control knob to 400°F. 4. The amber "heat on" light will go out when the oven temperature is reached. 5. Allow three cycles for the temperature to stabilize. 6. Read the thermocouple or thermometer immediately after the light goes out for the third time, and again immediately after it comes on the next time. 7. If the average of these readings varies by more than 10°F from the dial setting, recalibrate by the following procedure. Recalibration should be attempted only by a competent service technician. Use the following procedure to recalibrate the oven: 1. Loosen the two set screws that secure the temperature-control knob to the temperature-control shaft. 2. Remove the knob from the shaft, being careful not to rotate the knob or shaft. 3. Replace the knob on the shaft so that the indicator mark on the knob points directly at the temperature that was measured at the center of the oven. 4. Re-check the oven calibration. ----------- Part number for temperature probe is 1181996 and you can order if from the Southbend service center. -------- If you want the manual and wiring diagram for your oven.Please click the link directly:-- ----------- after you click the link,a page will open in that you fill the 5 letter number.And click the "download now " option.It will ask you to save or discard.Click the save option and download will start.It will take 2 mins to download.Then click the download file to open it.And go through the manual.------------This will help.Thanks.Helpmech.
Jan 28, 2011 | Southbend ES10SC Electric Single Oven
The symbols on the oven have faded. I don't know how to work the oven and I'm panicking because I'm cooking Christmas dinner in 2 weeks! It's an electric single oven
You should be able to get an oven thermometer at most appliance stores. You can stick it to the inside of your oven door to measure the temperature.
Put your oven on 'max' by rotating the temperature/power knob clockwise until it can go no further without 'clicking'. When your oven has reached the desired temperature on the internal thermometer, turn the knob back counter-clockwise until you hear a very slight 'click'. You can mark this point with a marker, and note the temperature next to it.
Dec 13, 2009 | Ovens
Delonghi oven grill broken, oven still works?
You will probably find it is the grill element that is faulty, a common fault on your brand of oven, to be certain, you need a meter to test it.
Please rate my solution.
Jul 15, 2009 | DeLonghi Ovens
Oven 150 degrees off
hi . i can help.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
  • Jun 23, 2009 | Ovens
    My oven runs about 100 degrees hotter than the dial says
    Check the temperature select knob. On the inside of the knob there should be an adjuster.
    The temperature probe may be the faulty component since this is an integrated machine.
    Jan 22, 2008 | Viking DEDO205 Stainless Steel Electric...
    Ovens Logo
    87 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    Are you an Oven Expert? Answer questions, earn points and help others
