The tv have a problems known as a convergence problems,tv convergence board it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it is dead.Must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv picture convergence problems.The tv shop,will cost u like $300-350 for parts and labors.
Tv have a problems known as a convergence problems,it dead.Colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are dead,must be replaced on the tv convergence board to repair the convergence problems.The shop,will cost u $300,350 for parts and labors.
thats usually repaired by installing the repair kit called ITC222 and ITC222A convergence option missing . You can get the kit from www.tvrepairworld.com it comes with full instructions on CD.
Hi, This is a convergence problem and you can set it right by changing the STKs. It is a professional job and i have knowledge of people who ruined their tv by spoiling some miniature surface mounted components close by. You may need to look at pico fuses too. I would say seeek professional help if you not comfortable working with electronics. Check out at www.fixurtvs.com,
Chances are that the convergence amps are bad. If those are mounted on a separate board, replacing the board would be the easiest thing to do. Running the magic focus or touching up the convergence in the customer menu may be required.
Take the TV to a repair shop. It sounds like the convergence chips are bad. Be sure they change them as a pair or you'll wind up with the same problem again.
You have a convergence issue. First question in customer menu under setup do you have the convergence optioin? IF you DO NOT then chances are you have the fl231 problem. check under my profile in the tips and trick section. IF you do have the option try autoconvergence. if this fails(goes red screen then you might have a convergence power supply problem.
