Kenmore 24 in. 16539 Built-in Dishwasher
Problem for Kenmore 24 in. 16539 Built-in Dishwasher
Top rack not cleaning
By b2egan on Sep 17, 2008
Hi ,
Help! I am so frustrated! This is a Kenmore Quiet Guard Deluxe/Ultra Wash built in that is 2 years old. For 6 months we have had a problem with the top rack being wet, but not at all clean. We have figured out the soap dispenser is not opening during the cycles, but we can manually open and close quite easily. model # 665 13722k600, type 575-0
Thanks so much for any insight!
Barb
Comments:
Sep 21, 2008
- Thanks for your feedback. Unfortunately, we have tried all those options. Nothing appears to be blocked. the "arm" from the top of the diswasher is moving freely etc. The top rack is getting the water, just not the soap at the correct time. That is why I am leaning towards the soap dispenser as the problem. Any other great suggestions of similar experiences?
Greatly appreciated!
So sick of using half the washer right now with the kids using a million cups etc a day!
Same Problem
May 20, 2009
-   Top rack is dirty after the wash and the soap dispenser looks like it doesn't work... grrr.... -   Guest
Nov 20, 2008
-   This is just what is going on with my dishwasher! The top of the door looks dirty after running a load and the items on the top rack are not clean. I ran cycles where I stopped it, positioned the arms and then ran it and checked the arms. Things are moving and there seems to be a least some water hitting the top rack, just not enough to get them clean.-   margalito
Sep 21, 2008
-   Follow-up on the same issue: I tried running a short program and opened the door a couple of times to check the orientation of the arms and the top ones do not turn. Taking the top rack out, the arm can spin freely. However, connecting a hose to the water intake for the top arm does not make it turn. Water comes out of the arm through all the holes but does not make the arm turn... The water pressure at the hose is 45psi which seems plenty to make it turn.
Any idea?-   annelaure
Sep 21, 2008
-   I have the same problem with the same model for over a month. Everything spins freely. Can not be the soap dispenser as the bottom is clean. However the top of the door is not. I am tired of re-washing !!! Please help.-   annelaure
Solution #1
posted on Sep 17, 2008
Somewhat Helpful)
ve3wtj
Rank: Wiz
Rating: 83%, 58 votes
Some dishwashers have a telescoping nozzle in the center on the bottom. If this is blocked by a large pot in the middle of the bottom tray, the nozzle will only extend up into the pot, and not be able to spray the entire top rack.
Also, some models have an arm mounted in the top. Check and see if it can spin freely, and if it's nozzles are clogged.
De-clog by soaking the part in vinegar.
Was this helpful?
Yes
No
Popular Solutions for Kenmore 24 in. 16539 Built-in
Questions and Unsolved Problems for Kenmore 24 in. 16539 Built-in
Do you recommend Kenmore 24 in. 16539 Built-in Dishwasher?
Answer
Answer
clip for folding rack gets knocked off by vent on the side
Answer
The sump seal started to "dissolve" and staining the washer black - it was about seven... (More)
Answer
our top rack is wet but not clean, so we figure the spinner isnt workin. how do you fix that?
Answer
Kenmore elite ultra wash...middle and top spinners not spinning. Water comes out of them, but they... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in , CA
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
