Question about Pioneer PureVision PDP-5030HD 50 in. HD-Ready Plasma Television
TV not coming on or shutting down after on a few minutes
Our TV is 5 years old and for the past few months it often will not come on at all, or after turning it on and off several times it will come on and often shut off after a few minutes. Best Buy told us to contact Advanced Video here in Maryland. We scheduled 2 appointments, stayed home and waited for them, and no one showed up either time. You should not use them as preferred service agents. We want our $10,000 TV fixed immediately. Can you help?
cell phone 410-236-2207
email: babybird5@verizon.net
    Master:
  • 479 Answers
Yes its the problem of the capacitors getting heated up on the main board aND SO THE TV GETS SHUT OFF AFTER IT GETS HEATED.ON THE MAIN BOARD OF THE TV CHECK OUT WITH THE HELP OF A MULTIMETER and replace the faulty capacitors and then it should work.
Posted on Dec 10, 2008
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
Le2412 power on problem
The power supply is failing.
Dec 20, 2013 | Apex Digital LD4088 LCD TV
Toshiba 52Hm85 shuts down after 40 minutes & goes on and off
Only a few things could make the picture freeze and shut down. I would recommend checking the DVI cable that goes between the Chassis and Optical Block to make sure it is secure and tight. If it is (and it probably is), most likely it is the Optical Block causing the problem.Because of the cost involved, I would have a Professional to come out and diagnose it to be sure.
I hope this helps,
Sky Assoc
Aug 25, 2009 | Toshiba 56HM66 56" Projection HDTV
TV turns off because of air flow
It is probably a bad temp sensor inside the TV. My 73" started shutting down before it was a year old. I moved it way out from the wall and it got a little better. A tech was just out to change the bulb under an extended warranty and he said there is a service bulletin about the temp sensor. If your TV is out of warranty you might call Mits and see if they will cover the sensor replacement. Tech said it takes about a 1/2 hour in the home to change it...
Apr 20, 2009 | Mitsubishi WD-62525 62" Rear Projection...
52 inch rear projection tv turns off after a minute
try turning off the auto shut off feature in you set up screens . you can find them through the menu button on your remote. scroll through till you find it and turn it off.
Jan 18, 2009 | JVC AV-56WP74 56" Rear Projection...
My Panansonic TV shuts down every few minutes and the LED blinks three times
I still have that problem. I calle Mfr and also spoke to repair shops recommended by them and they said they estimate a cost of 300-400$ or so approx. I am waiting to buy a new LCD which could be few 100 more but at least dont have to live with the old one and keep spending money...
regards
Oct 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
The power shuts off after a few minutes
There could be several factors. Are there any indication or failure lights/codes prior to the unit shutting down? You didn't mention where the unit is located. Does it initially start to read the disc then shut down or is there no activity at all? Please respond with some additional info & we'll go from there.
Feb 21, 2008 | Televison & Video
Flashing picture screen on Sony KP_53HS10
tap around on the circuit boards in the rear of the television. narrowed it down to the Comb Filter circuit board. It is the smallest upright circuit board behind where you plug in all your connectors. pulled it out cleaned it off, reinserted it
Nov 19, 2007 | Sony KP-53HS10 TV
Pioneer PureVision PDP-5030HD 50 in. HD-Ready Plasma Television Logo
114 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
