Mains fuse blows immediatly on power up on trace elliot commando 100W bass amplifier
  • 31 Answers
Hi, The most common cause of this is blown output transistors, assuming this is not a valve amp.
At any rate, this is something you will want to have looked at by a tech.
Posted on Sep 20, 2008
Amp blow fuses immediately when power is switched on
There could be so many things wrong with it, but personally I find the most likely problem is the power supply.
Mar 15, 2015 | Peavey TNT 115 1x15"" 600W Bass Combo...
Why does fuse blow when unit is powered up
I rather suspect IC1 TDA7293 is the cause of your problem. If this is the case you will need to check the speaker/s
Nov 12, 2014 | Marshall Amplification Marshall MG250DFX...
Trying to connect peavey tour 700 to a trace elliot 1518 bass enclosure. Plug the enclosure to the back of the amp. Then plugged my bass into the high gain. Turned it on and nothing happens.
Check continuity on all cables, try a different cabinet with the head and a different head with the cabinet and the bass with a different rig to see which part of the chain isn't working, make sure the volume controls are turned up on both the amp and bass. Once the problem is narrowed down it will be easier to advise you.
Oct 12, 2014 | Music
My bass amplifier requires a ceramic fuse T10H250V. Where can I find one exactly like it?
hi,
Fuse breaks when it has succeeded in limiting further damage.
Check for other possible shorted electrical and electronic
components.
• Could be drive transistor , output transistor or both on the main amp.
But check for power supply and in the preamps also.
• Measure supply voltages,
• Check DC offset voltage
• Check idling current (main amp)
Isolate , and trace afterwards.
Aug 22, 2012 | Behringer Audio Players & Recorders
I have blown a fuse on my ashton BA4012 bass amplifier. i have taken front grill off and now taken out the middle, where the hell is the fuse i need to change???
if its a main fuse follow the input power lead wiring, it sould be near a power transformer or in the power supply, if not it maybe in the power switch itself, depending on what country you are from some fuses are in the actual mains plug that plugs into the wall
May 30, 2010 | Audio Players & Recorders
Powered subwoofer keeps blowing its fuse
The amp is blown. You need to get it in for service. No telling exactlly what is wrong untill it is opened. 215-736-8055
Jan 15, 2010 | Onkyo Bass Reflex Powered Subwoofer...
Blowing fuses....
you are getting a power surge somewhere try to use a toggle switch on the remote wire
Mar 30, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
I have a Trace Elliot bass amplifier (gp7sm 130) and it makes a buzzing soound. Any ideas?
First check all of the ground connections both at the amp and bass. If the amp makes the buzzing with no input at all, the problem is most likely a bad cap in the front end of the amp. These are not the easiest to work on. I would suggest that you bring the amp to a servicer for repair. Anything that you can describe that indicates when the buzzing is more evident would be helpful in tracking down the problem.
Dan
May 05, 2008 | Audio Players & Recorders
Ashdown Perfect 10 Bass Combo keep blowng 2 man fuses
What main fuses? Fuses in the car electrical system? If so, your amp is too powerful to run through the cars electrical system, you should get a heavy guage wore ran straight from the battery, with its own dedicated fuse placed in-line, ad close to the battery as possible. Wait, is this a bass guitar combo??? Open it up, if there's wax coming from the power supply, thats prolly the culprit. Check for any obviously blown resistors or any short circuits. But most likely, its not gonna be user-servicable.
Feb 28, 2008 | Ashdown Perfect 10 Bass Combo Amp Car...
266 people viewed this question
 Grubhead
Grubhead
