Question about Dryers
Error code on my tumble drier - E60. It's an Electrolux 57160
  • Thomza Jan 05, 2009
    Same code, different machine, but probably identical error. E60. Manual does'nt mention it.
Oceti
  • 51 Answers
SOURCE: white knight 767 tumble drier
If the rug was very heavy you could have burnt up the motor. If it will restart after it cools off, replace the motor and clean out the vent system.
Good luck.
Posted on Dec 08, 2007
SOURCE: Whirlpool LER 5436 tumble drier- loud buzz
When start button is pushed there is a buzzing noise but dryer will not start.
Posted on Oct 21, 2009
  • 70 Answers
SOURCE: Simpson sirocco clothes drier tumbles ok, but heater not working
Bad heating coils, or bad ignitor if gas.
Posted on Jun 23, 2010
Ranglo
  • 1194 Answers
SOURCE: Drier does not tumble but it still heats.
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Good luck and have a nice day
Rating the solution is highly appreciated.
Posted on Jul 05, 2010
  • 3074 Answers
SOURCE: What is the meaning and
When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
Posted on May 08, 2011
What does error code E60 mean?
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Apr 21, 2016 | Electrolux Washing Machines
My electrolux front load washer had a bang and a spark on electrical display now showing E60 EWF 1087
Dado
Feb 21, 2015 | Electrolux Washing Machines
My washing machine electrolux typeEWF1421 show Error E60
Did you go thru the procedure to delete the code yet? Here is a general guide on troubleshooting with codes, but E50-E79 show as service calls only
http://www.electrolux.im/Files/international_english/QuickWins/TroubleShooter/Document/ReadCodeWasherWithDisplay.pdf
Nov 30, 2014 | Electrolux Vacuums
Hi I have an Electrolux dryer which has started showing the error message e60, when i hold the start button and the one next to ity I get error e62 showing can you help?
the "E60" error code will appear when there is an error with the door switch and sensor, An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
the "E62" error code will appear when the lint filter and tubing need to be cleaned or replaced. The dryer will start and run for 15 seconds before shutting off. It will restart when prompted and run for another 15-20 seconds before shutting off. These steps must be repeated until the dryer continues to run the full cycle. Tim
May 12, 2011 | Dryers
What is the meaning and fix for error code E60 on a John Lewis JLDV08 tumble dryer. The dryer stops mid-cycle, the door pops open, and code E60 appears on the display.
May 08, 2011 | Dryers
I am getting an error code on my EW1080F cam you advise what it means or where to go to find out? Error code is E60.
Try the Electrolux troubleshooter tool on their website: http://www.electrolux.co.uk/Support/Troubleshooter/
I put your model number in, followed the steps, and for E60 it just says the programme has been interrupted - allow the machine to cool down for 30 minutes before restarting.
Feb 05, 2011 | Electrolux Washing Machines
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Zanussi washer drier 1480W door lock
Zanussi's always keep clicking before starting.I don't know what E60 is about,but I take it the machine is working?
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Dryers Logo
111 people viewed this question
Top Dryers Experts
