Question about GE WSM2700W Unitized Spacemaker Washer and Dryer
GE Spacemaker stackable washer/dryer
My washer has quit agitating or spinning. How do I get to the inside and check the belt? Is there a trick? Do I go in through the back or the front? Please help. I don't have the extra money to call a repairman nor do I have the money to buy a new one. Please help me. Tired of going to laundromat. The Machine was working then there was clanging in the agitation cycle then the washer stopped. It drains but dosn't agitate or spin in any cycle. Is it the belt Model WSM2700WAWWW
  • vnemara Sep 17, 2008
    Thank you for your quick response. I will pass the info to the friend who is going to perform the work for me. Vanessa
The front cover come off by removing two philips screws on the bottom of the panel. That will expose all the operating parts of the washer.
Posted on Oct 11, 2008
    Scholar:
  • 147 Answers
The belt is most likely accessible from the bottom. Empty the machine, and lay it down on it's back, front, or side. The bottom will then be accessible.
Posted on Sep 17, 2008
  • David Friesen
    David Friesen Sep 17, 2008
    Don't forget to unplug it first! 240 is dangerous.
What does a blinking green light on a GE stackable washer/dryer mean
Can you provide more information on the year of your stackables and if you have the exact model or serial number, that would be helpful. Thanks.
Jun 02, 2016 | GE Spacemaker Washer and Dryer Electric...
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Ge washer wont spin or agitate
The motor is overheating, so the internal thermal protector cuts out. Did you check the start-run capacitor for open circuit? Or it may be breaking down at full voltage.
If in doubt, they are fairly cheap to replace. I suggest you try that.
Feb 02, 2018 | GE WSM2700W Unitized Spacemaker Washer and...
Install dryer belt any tricks to make it simple on a GE WSM2700W/WW/AA Top Load Stacked Washer / Dryer
Nothing on a stackable is easy to replace and no tricks so just take your time and you'll get it on.
Sep 27, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
GE Washer wont drain. Wont agitate, does nothing. Washer is part of a stackable unit about 4-5 yrs old. Checked circuit breakers and electrical and water supply. What should I check? Are there fuses inside...
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Here is a link to the part you need.
Jan 10, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
You should go in through the front. Use a flashlight and look between the front panel and the top panel. You should see some clips there. Stick a flathead screwdriver into the clips to pop the top up and then remove the front. The front may be held in by screws, but since I don't know which model you have, look inside once you pop the top and see if there are screws. Then you should be able to remove the front panel and see the belt.
Mar 26, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
621 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
