Question about Sony Ericsson K770i Purple 3G Camera mobile+256mb Cellular Phone
KEY PAD FUNCTIONALITY PROBLEM
Suddenly some of keys stop functioning.(no response when pressed )
1 right side broser key
2 top right menu key
3 Right side shotcut key
4 # key
5 volume decrease key on top right side
camera key on right side
This problem was occured two months ago and I clame warranty now it happned again . I thin there is some loose connection.
I my self is an engineer an I have all tools to open it .
Do you think all the hard ware will ok there will be a loose connection.
This phone drop from my hand many times
Please help in this matter
Berst Regards
M Tahir
  • 1,800 Answers
Hi Mr.Tahir
Ur CP's Buttons Circuit Is faulty.
to solve this prob u need a hot air tool and the same circuit to replace it.
best regards.
Posted on Sep 17, 2008
HP Calibration Error
    For HP Officejet 6600 / 6700 printer models which suffer a calibration error, more than likely either the PRINTHEAD has connectivity issues (i.e. remove, clean all contact points, and reinstall), compatible/clone ink cartridge chips are causing the issue, the PRINTHEAD is approaching end of life, or not all ink nozzles are firing and therefore the printer is unable to calibration. Perform the following diagnostic checks to help make a determination:
    Tap 41 PRINTHEAD Health Diagnostics (NOTE: applies to touchscreen 6600/6700/8600/8700 printer models only):
      1.Press 'Return' button (lower left side) four (4) times until 'Support' menu is displayed.
      2.At 'Support' Menu, using the arrow key, navigate to the 'Service Menu', press Ok.
      3.Use arrow keys to advance to the 'Special Reports' Menu. Select OK.
      4.Use arrow keys to advance to the 'print mech button tap' menu. Select Ok.
      5.'code = 0' will be displayed. Use arrows keys to change value to '41' (i.e. press and hold right arrow key).
      6.When 'Code = 41', select 'OK'. The diagnostic test pattern will print.
      7.Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced. Re-seat PRINTHEAD and/or clean rear electrical contacts and repeat 'Tap 41' test to verify connectivity is not the issue.
      Nozzle test (use to determine if all ink cartridge nozzles/printhead is firing all colors properly)
      Press return arrow 4 times
      2.Press support menu
      3.Press right arrow 5 times to print diagnostic menu and press ok
      4.At nozzle test press ok
      Self test/printer status (use to print internal printer settings)
      3.Press right hand arrow 7 times to reports menu and press ok
      4.At self test report press ok
      Extended self test (use to evaluate color performance and obtain total page count)
      4.Press right hand arrow 1 time to extended self-test and press ok
      Print Quality Diagnostic Page (use to determine if printing alignment is correct)
      4.Press right hand arrow 2 times to Print Quality diagnostic report and press ok
      Print head recovery (runs 'intensive' printhead service cleaning routines, i.e. for a clogged printhead)
        1.Press home key twice
        2.Then return key
        3.Then home key twice
        4.Then return key
        5.Then home key twice...............this will gain access to the Engineering Menu
        6.Press the 'service menu'
        7.Press right arrow 4 times to 'service test' and press ok
        8.Press right arrow:
        a.16 times to 'print head rec level 1' (basic recovery)
        b.17 times to 'print head rec level 2' (medium recovery)
        c.18 times to 'print head rec level 3' (thorough recovery)....suggested for severe streaking
        9.Press 'ok' to activate either of the 3 selections above.
        Semi full reset (can be used to help address intermittent or incorrect printer behavior issues)
          1.Press return arrow 4 times
          3.Press right hand arrow 2 times to Resets menu and press ok
          4.Press right hand arrow 2 times to semi full reset and press ok (Note: this will return printer to factory default condition; regional setup will be required following this action)
          For more information on inkjet printer recovery tips, or solutions for a different printer model, please visit http://www.inkjet411.com
          -Thank you
Nov 22, 2013 | HP OfficeJet Office Equipment & Supplies
My number pad on my keyboard is not working, how can I reactivate it?
At the top, left corner of the number pad, there should be a key that says "Num Lock." This key toggles the functionality of the number pad keys between Numbers and Directions.
Press Num Lock once and the numbers should start working again.
Press it again, and the keys should go back to the Directions (up, down, left, right, Page Up, etc.)
Jan 11, 2011 | Gateway Computers & Internet
How to activate call waiting on samsung corby...
1)Go to menu from the touch pad [the icon in right corner] 2)Settings->Application settings->Calls->Voice Call->Call waiting 3)then activate it
Dec 13, 2010 | Cell Phones
The touchpad (and buttons) stopped working. No response at all. External mouse works fine, so it is not a software issue. Could this be a loose connection? or do these fail after a while? Are the...
Is there a button with a light on it near your touch pad, sometimes these buttons don't have lights? Usually this button is centered on the bottom or top of the touch pad. If there is a button like this, then try pressing it to see if it gives you functionality of the touch pad. If you do have a button like this and it doesn't resolve the problem then there is a possibility that the touch pad has malfunctioned or that the connector has come loose somehow. If you don't have this type of button then look at your keyboard to see if there is a function key for turning off\on the touch pad. Look for the FN key. What color is it? Then look at the keys that have icons in that color. If you find one that you believe is for the keyboard then try pressing that key and the FN key at the same time.
Jun 25, 2010 | Toshiba Satellite M55-S325 Notebook
Have a canon b95 faxphone machine. When receiving legal size documents, it receives and prints on 2 separate sheets. How do I correct so incoming only prints on 1 legal size paper
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
May 18, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
SAME PROBLEM THE ADVICE DIDN"T WORK
Manual say to -
1. Press the “Menu” key on the panel, “Menu” will appear on the screen.
2. Press [arrow left] or [arrow right] key, move the cursor to “image function”.
3. Press [↑↓] key; enter “Display model” function choice.
4. Press [↑] or [↓] key, move the cursor to “Image Revolve”.
5. Press [arrow left] or [arrow right] key to adjust “Image Revolve”.
6. Press [↑] to go back to the Menu.
7. Press “menu” key to exit the “menu” window
If your projector will not do this, the functionality may not be there.
Dec 18, 2009 | Televison & Video
Where is the wireless switch to a acer travelmate 2310...can't find it..thanks
its in the front below the 'mouse pad' there are 2 very thin buttons with orange lights the one on the right is for the wifi
Nov 15, 2009 | Acer TravelMate 2300 Notebook
I want to find out how to set up our Canon CFX0-L4000 fax Machine
CANON CFX-L4000 UNOFFICIAL MANUAL
RIGHT KEYPAD
FUNCTION
SET
01 DATA REGISTRATION
02 DELAYED TRANSMISSION
03 POLLING
04 MEMORY REFERENCE
09 REPORT
11 UP
13 +
14 LEFT
15 SPACE
16 RIGHT
18 CLEAR
19 DOWN
Keys 1-20 are speed dial keys. If speed dial is not set, message is displayed and manually entering the telephone number is prompted. Press STOP to clear.
Pressing FUNCTION accesses the menus associated with keys 1, 2, 3, and 4. After accessing a menu, the cursor keys, SET, and occasionally the telephone key pad are used for selecting options and setting values.
EG. Setting a speed dial number:
FUNCTION - DATA (01) - SET - SET - UP/DOWN to select speed dial number - SET - UP/DOWN to set number/name - SET - UP/DOWN/LEFT/RIGHT/PHONE KEYPAD to enter value - SET
EG. Setting unit telephone number
FUNCTION - DATA (01) - DOWN once - SET - DOWN once - SET - PHONE KEYPAD to enter number - SET
EG. Retransmit from memory (assumes memory light is on)
FUNCTION - MEM (04) - DOWN once - SET - UP/DOWN to select document number (LEFT/RIGHT to view associated telephone number) - SET
EG. Delayed transmission
place document into feed - FUNCTION - TX (02) - SET - PHONE KEYPAD to enter time to send - SET - PHONE KEYPAD to enter phone number - SET - SET - document is scanned and will be transmitted at set time
for full guide you will have to search and purchase one.
May 28, 2009 | Canon Office Equipment & Supplies
The box codes please virgin media in bristol may 09
try these codes
PURE (UK) NTL 54-01 May 7th 2009
key 00 = 5C 2C 26 36 CF 81 AB 66
key 01 = 2C 10 35 AC 06 57 BE 6F
To enter the codes
1 - Press menu
2 - Press 1570
3 - Make sure key emu is on
4 - Enter nagravision
5 - Make sure it says ntl at the top box, if not press right till it says ntl
6 - Key number should be on 00
7 - Go to key data and put this code in To enter the codes
1 - Press menu
2 - Press 1570
7 - Go to key data and put this code in *******************
8 - Go to key number and press right so its on 01
9 - Press down so you are on key data and enter this code ******************
10 - Press ok to save
11 - All done8 - Go to key number and press right so its on 01
11 - All done
May 22, 2009 | StarTech.com StarView SV211K 2-port KVM...
My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Aug 03, 2008 | Televison & Video
Sony Ericsson K770i Purple 3G Camera mobile+256mb Cellular Phone Logo
135 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
