Question about Western Digital (WDXB1200BBRNN) 120 GB Hard Drive
Cannot see WD 120 GB in my Computer
Hi
I have a 120GB Western Digital external drive. Till yesterday, it worked great. Then I plugged it in my wife's computer to get some files off there. It hung the explorer in that PC and I pulled the USB out of the port and then, when I tried to connect to my PC, it lit up and i heard some clicks and then nothing happened. I dont see a drive letter to access the drive anymore.
I have tried various PCs and it says found new hardware and goes through the process and says ready to use. BUT NO DRIVE LETTER in explorer to access the drive. Please HELP !!
PS: I can see the drive in the device manager whenever i plug it in.
I DON'T see the drive when i go Start - Control Panel - Administrative tools - computer management - Disk Management
  • sg1102 Sep 17, 2008
    Hmm .. I dont want to open the drive.. Is there no other way to fix it? I don't care for the data in there. I just want it to be working again.
    Scholar:
  • 147 Answers
Sounds like the USB interface is working, but the physical drive is not. Remove the drive from it's external case, and try a different hard drive. If that works, your drive is the problem. If it still doesn't work, the USB to IDE interface is the issue.
Try mounting the original IDE drive internally, and see if you can read it there. If not, you'll need to send it to a data recovery center.
Posted on Sep 17, 2008
  • David Friesen
    David Friesen Sep 17, 2008
    Visit the manufacturer's web page, and navigate to their support / downloads page. There is usually a diagnostic utility for free download there. Often, it needs to be copied to CD or floppy. Boot from that, and it should give you in depth answers to what might be wrong with the drive.
I bought the Western Digital Elements External hard drive-500GB and it worked fine with my computer. I took it to my brother's house to download some data and his computer DOES NOT RECOGNIZE it when it's...
HI, YOU MAY WANT TO TRY, REMOVE SECURITY FROM WITHIN THE SMARTWARE, THEN AND AS ALWAYS, MAKE SURE THAT THE DRIVE, WHEN BEING CONNECTED/DISCONNECTED, THAT THE PC IS COMPLETELY SHUTDOWN.............. I HOPE THIS HELPS.........JEFFXC
Jan 25, 2011 | Western Digital Elements powered by WD 320...
My husband has the 500G WD external hard drive which has worked perfectly until yesterday. Now when he plugs it in, the computer doesn't recognize that anything has been plugged into the USB and it's not...
Try it on another computer to see if it is working. Sometimes the USB cable can fail, too, so if you have another USB cable that fits, try it.
If it still does not work, perhaps the drive has failed.
Aug 31, 2010 | Western Digital My Book Essential 500GB...
My WD hdd was working properly till yesterday. But it was not detecting in any of the laptops around.
try change the external casing. Try with another casing(connection). try in few pc.
send to manufacturer if still under warranty.
Apr 26, 2010 | Western Digital Elements powered by WD 320...
Western digital 320g elements portable won't work
Hey,
try connecting it o another computer and check
if not yet, use only the WD USB transfer wire supplied in the box.
because WD External HDD only recongize its own USB and none other.
May 03, 2009 | Western Digital Elements powered by WD 320...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Jul 30, 2008 | Western Digital Caviar WD2500BB 250 GB...
WD 120 GB 2.5" hdd not listed in my computer
I HAVE MY PROPERIETRY SOFTWARE WHICH I USE TO FORMAT ANY DISK OF ANY TYPE... AND MAKE ANY TYPE OF PARTITIONS LIKE ALL IN ONE PARTITIONING AND DISK MANAGMENT.
I HAVE STILL NOT REGISTERED AND TRADE MARKED IT. BUT I AM SUCCESFUL IN MY PRACTICE ON VARIUOS HARD DISK DISCOVERIES AND RECOVERIES .EVEN I CAN DO A FULL ZERO LEVEL FORMAT TO ANY HD.
CATCH ME AND REQUEST FIXYA TO ALLOW YOU TO SEND YOUR HDD OR ANY TYPE OF STORAGE MEDIA FOR RECOVERY AND SOLUTIONS. +0+9+3+2+1+1+0+1+7+1+7
Apr 17, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
Western Digital WD 1200VE; 120 GB external hard drive unable to boot
good eve prapad dont worry for your data ,first if you have a boot cd ,owerrite the OS ,then select repair option,it is occures due to 90% OS currupt ,
regards prasanna
Mar 05, 2008 | Computers & Internet
Wd 120gb External no longer recognised by my PC
hi there
have you tried looking at the device manager?
you can also try transfering it to different usb ports.
hope this helps
Feb 04, 2008 | Western Digital Passport WDXML800UE...
WESTERN DIGITAL CRASH
Just remove the hdd from external and put in pc as secondary master and it will work fine if you have desktop pc
Jan 27, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
Western Digital Elements Drive Problem
check the drive on any other system.
may be last time you were using the drive and system carsh or improper shutdown this can cause the drive damage.
Also may be a virus format the disk and try it.
Jan 06, 2008 | Western Digital 250GB ELEMENTS EXTERNAL...
Western Digital (WDXB1200BBRNN) 120 GB Hard Drive Logo
431 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
