try changing batteries then shut system off turn back on then turn on PDA if still the same take off front top cover of aqualink make sure 4 pin red plug is connected and tight
To perform a hard reset: 1. Press and hold the power button on the front panel of the handheld. 2. While holding the power button, use the tip of an unfolded paper clip (or similar object without a sharp tip) to gently press and release the reset button. 3. Wait for the Palm Powered™ logo to appear; then release the power button. 4. When a message appears on the handheld screen, warning that you are about to erase all the data stored on your handheld, press any other button to perform a soft reset.
This might happens because the battery of the Handheld is not compatable with the Handheld. Kindly check the battery with the other Handheld if it is working fine then there might be an Hardware issue with your Handheld you need to walk into the service center.
Is KsDatebook compatible with Palm? Palm suggests only two programs to sync calender files with Microsoft Outlook and the one that comes with the TX CD.
That is strange. The only solution I've got (beside checking the status of the reset button), would be to disconnect the battery. Wait a few moments, and then put it back in. Getting the back of can be a bit tricky, here's some instructions.
