Question about Microsoft Xbox Console
Eject tray When turn on xbox and I push an eject button but xbox tray never comes out until I use a pint point push into a little hold. However, when a game disk already in xbox and it will comes out right away first time when I push an eject button...Please help.
  • tylerinterne Sep 18, 2008
    No, I did not drop it. Just a normal of use most of the time...Please help.
Have u done anything to it recently modded it dropped it anything that could have damaged the xbox
Posted on Sep 17, 2008
Open tray appears, game will not load.
Try and resset the xbox by pressing and holding the small button by the 2nd memory slot and the eject button together before turning the unit on, the xbox will turn on whilst still holding the the eject button release the other button then press it in again, the lights should stop flashing, now power off using the normal switch and then power back on again, and a game again. hope this and post back what happens. ty
Oct 03, 2010 | Microsoft Xbox 360 Console
My cd rom tray will not eject and the light is
have you manually tried to eject the disc tray? There's a little hole on there somewhere, stick an unbent paperclip or safety pin in it and push until the tray starts to come out, then pull the tray out with your fingers.
Once you've done that, push the button to allow the tray to automatically retract.
Jul 22, 2010 | Teac DW 28E CD-RW/DVD-ROM Burner
DVP 9000S, the tray does not come out and stick
This is a common problem, usually the eject drive motor, fails, or the circuitry, that drives it, or the brain, that tells, the drive to drive. There is no possible way to know, unless the unit is examined. You can sometimes get the tray open, by getting a straightened paper Clip, insert into a small hole at the front of the DVD tray, insert into hole, and push in, push, until a click, is heard/felt, and then push a little more past that point, and the tray should pop open, now you can at least get your DVD out. Now you either need to get this unit repaired or get a new one.
Apr 23, 2010 | Televison & Video
My xbox 360 tray wont stay close how do i fix it
Do you mean the CD tray won't stay closed? If so check the simple things first. The button that you push to open and close the tray is actually a lever that pushes a much smaller button below it. Make sure that your eject button is not stuck down for some reason. Check your cd tray and the bay to make sure nothing got inside that is preventing the cd tray from closing all the way. I believe if something gets in the way the tray will automatically re-open. You can also take some compressed air and blow out the cd tray to remove any debris that may be blocking the tray from closing.
If none of the above simple steps work I believe it boils down to 2 things. 1. An object inside the case or tray that is preventing it from closing all the way or... 2. The eject button is stuck down.
If your comfortable with it you can take apart your xbox case and remove your CD/DVD player and ensure the button works properly. You can do a search on this site or youtube for instructions on how to take the case apart if needed. Once the case is apart the CD/DVD player is easily removed. You will then notice that the switch you press on the outside of the Xbox to open and close the CD/DVD tray is actually a lever that presses a much smaller switch directly on the front of the CD/DVD unit. You can then test your eject switch directly by pressing the button directly with a ball point pen or a pin. If the bay does not open and close properly at this point it may be necessary to replace the CD/DVD player and I do not know if it can be replaced or not. Hope this helps.
Nov 15, 2009 | Microsoft Xbox 360 Console
The DVD tray will not eject. It cannot detect
Hello
Usually there is a little hole near the eject button. That hole this is there for this spesific reason. Unplug the device and push a small pin into the hole. The trey should now be ale to gently pull out. This is the way that any repair shop will do this, so why pay if you can do it yourself?
Just be very gentle throughout the whole process. Push the oin in all the way untill you feel resistance and hold it in while you pull out the trey. Really hope this can help you. Please rate this.
Best regards
Sep 26, 2009 | RCA RTD205 System
My xbox 360s disc drive will not open
there is a manual eject on the front of the 360 under the face plate, if you take the face plate off their are 3 different slots that the relase can be in, you would need a thin long thing like a needle, and does take a little push, took me a lil while, you can see where the holes are on this web site, obv doesnt fix the problem, but at least you can play games until you find a repair. http://support.microsoft.com/kb/906935
Jun 06, 2009 | Microsoft Xbox Console
Original Xbox disc tray not opening properly
I found this posted on cheapassgamer.com
Greetings, Ladies and Gentlemen.
Since I was able to solve my Xbox's tray problem completely (for now) due to this site, I felt it necessary to contribute to the forum, in order to (hopefully) help the next person with the same problem.
First, let me note that my Xbox has a Samsung drive. This method may only work if you have a Samsung or Hitachi drive, as they have the lever action emergency release.
Issue:
A) Xbox DVD tray will not eject when eject button is pressed, instead making a clunk / thump noise, as if being blocked from ejecting due to media inserted incorrectly – irregardless if media is present in the tray.
B) Tray will sometimes eject if button is pressed multiple times.
C) Tray will only eject if Xbox is thumped upon directly above the tray.
Solution:
A) First, go to http://www.xbox-mod.co.uk/index.php?...mergency-eject . Then, scrounge up a paper clip and proceed to manually eject your DVD tray.
B) Next, remove the Xbox logo front panel from the DVD tray. This is fairly easy to do, but you must be gentle, or you might break the tray or the front panel. The way to remove it is to take a pair of needle nose pliers and use them to gently pull the bottom clips away from the tray's underbelly before pushing the front panel up. You can also unclip one side, then the other if you are having difficulty.
C) Use the eject button to close the tray. Now open it again. If it still refuses to open (as did mine), use the paperclip and manually eject the tray.
D) Now, loop your finger through the open DVD laser slot in the tray, and gently pull the tray towards you – it will come out a wee bit more, and then stop. Do not force the tray to extend any farther than that.
E) WHILE THE DRIVE IS STILL OPEN, use your paperclip on the manual eject lever. It may take a moment to trigger it, as it is currently depressed, but if your Xbox and DVD Rom are like mine, it will actually draw the tray back in.
F) Poke the Eject button. It should pop open without any argument at this point. Try it a few times, just to be sure, if you'd like. Then, slide the front panel back onto the tray, and you should be good to go… until the next time the P.O.S. decides to slip a gear.
What's that? Slip a gear? Yep. As far as I can tell, that's exactly what is causing the trouble with the drives. Pushing them closed with your finger will force the motor to engage, yes? Well, eventually it seems the cheap DVD Rom's in the Xbox get fouled up, the motor kicks in a bit too late, closes the tray too far, and slips a gear. Then it will clunk / thump at you impotently until you fix it. What we have just done seems to reset the engagement point on the motor, and allows the eject button to work properly again. An easy solution to this problem is to always use the eject button to load and eject media, but you can't always ensure your guests are going to adhere to that policy (Or that the Xbox won't pull it shut too hard just to spite you, the foul tempered little…).
For Thompson and Phillips Drives, that use a gear to manually eject the tray, I would assume that pulling the tray forward, then advancing the gear manually until it refuses to do so, and then pushing the eject button might work. If anyone tries this and succeeds, reply to this message and let us know.
Thanks again for leading me to my solution (even if it may only be temporary), and I hope my suggestions have led you to yours."
Hope this helped please rate.
-Ryan
Feb 19, 2009 | Microsoft Xbox Console
Disk tray won't open
Call Customer Support: 1-800-4MY-XBOX
Dec 06, 2007 | Microsoft Xbox 360 Console
Xbox 360 drive doesn't always open
Can you hear any gears grinding when you try and eject it? Has anyone ever pulled or pushed the tray in roughly?
Sep 30, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
