Related Tags:
This problem should be removed because:
Problem with Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
The smartmix was not working, so I pulled it out and then cleaned it; however, the parts do not stay together when reassembled. I cleaned with warm water only
Suggested Solution (2)
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fsd5
The cap and insert at the bottom of the bottle may need to be replaced, or you could have a problem with the smart mix asm. You would have to remove the top cover to get to it. Does the smart mix knob stop where it is supposed to or does it go all of the way around, if it does, then the stop on the knob is broken.
Source: Smartmix bottle
Water is not dispensing to clean carpet. Water
Water is not dispersing to clean carpet. Water does dispense through tool. Pump belt seems fine and is turning. When I take off Flow...
can not get smartmix knob and plunger to line up
can not get smartmix knob and plunger to line up to put back together
Can not get the Smartmix rotary switch to line up
I dis-assembled the floor unit housing on my Bissell 7901 steam cleaner in order to replace a part and on reassembly I can not get the...
My bissel proheat is not
My bissel proheat is not releasing the soap when the trigger is pulled
i have a proheat carpet
i have a proheat carpet cleaner model 3 7901. the problem is the brush on the bottom of the machine plus the two end parts and the belt came...
Tips for Helping ednjudi With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
need manual and scamatics for oreck carpet...
need manual and scamatics for oreck carpet shampooerWhat's your problem?
hand attachment does not spray
The water does not seem to spray.
Bissel proheat 7901 rear wheel broke off. How do...
The rear wheel cracked and eventually broke off after a recent move. Axle is still in place.
Manual, anyone?
Does anyone have a manual for a Bissell SC Carpet Extractor 1632?
See all Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Problems
Fix-O-Meter
37
37 people viewed this problem
- 0 people are following this problem. Be the first!
Top Bissell Vacuum Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
