Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Downgrade of Firmware
We started using seagate hdd in our equipment. We are using Barracuda 7200.10 80Gbytes. Our equipment cannot use a hdd with firmware 4.AAB but works perfectly well with firmware 3.AAD. How can I downgrade several new hdd too 3.AAD? Rgds
  • 171 Answers
Firmware updates and downgrades may only be obtained by contacting Seagate Support Directly.
If you have been referred to Seagate by a different vendor who has told you that you need a firmware update, please contact Seagate Support for more information and confirmation.
http://www.seagate.com/www/en-us/about/contact_us
Posted on Sep 17, 2008
Seagate pipeline hdd 500 gb. can I remove it from a lorex dvr, and put it in my pc?
Any drive will work - but you have to make sure that its physical configuration matches your pc and that you reformat the drive since the format used for dvr use is not compatible .
Sep 21, 2017 | Seagate Barracuda 7200.10 ST3250310AS SATA...
I had four broken DVRs of same type, I want to use their HDD in raid strip in PC, but they are DVR HDDs (Seagate Pipeline HD.2, ST3250312CS) and they are not initiable in PC. Is there any way to use them? ...
The SATA RAID interface needs to be compatible with SATA revision V2.0. Check the drives with the Seagate diagnostic tool (download it from Seagate) for correct operation. This will also check / test the SATA interface. Connect the drives directly to a PC with SATA interface to do this. If proven OK then use the RAID board.
Possibly there's a way to downgrade to SATA-1 using a Seagate tool.
Jul 05, 2011 | Seagate Barracuda 7200.10 ST3250310AS SATA...
I need to upgrade my firmware for my seagrate hard disk drive 7200.8
Hi i have just looked into need to upgrade your firmware please read this
Seagate products are run by firmware. Having the latest firmware can improve performance and or reliability of your product. Seagate recommends applying new firmware to enhance the performance and or reliability of your drive.
Like any software, firmware is improved over time and problems are also fixed. Every drive family has a couple of firmware releases during the life of the product. Please check in regularly to determine if new firmware is available for your drive.
As new firmware becomes available for other products we will make note of it here. At this time, we have firmware available for Barracuda 7200.12, DiamondMax 23, Barracuda LP, Barracuda 7200.11, Barracuda ES.2 (SATA) and DiamondMax 22 drive families.
If newer firmware is available for your drive, it will reflect the improvements we have engineered for the latest manufacturing. Firmware for legacy products will be the final release from manufacturing. Please note that Seagate does not offer details about specific firmware.
Until recently, firmware updates for typical desktop and laptop computers were difficult and somewhat risky. This situation, in part, was based on a lack of friendly firmware download tools and operating system limitations. This situation has improved and Seagate now offers firmware updates as a routine matter for the general support of your Seagate drive.
note.gif If you are troubleshooting a system or OS problem, you should not consider firmware updates until after exploring more typical troubleshooting steps like file system error checking and anti-virus scanning.
Please use the following links and instructions below to determine if firmware is available for your product. If firmware is available, we recommend that you make a back up before running the actual update and that you read and follow all instructions, cautions and warnings that may be displayed.
Follow these steps to determine if a firmware update is available for your drive:
1. Click here for instructions on how to determine your model and serial number.
Nov 14, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Brand new Seagate barracuda 500GB SATA hdd not detected
http://www.seagate.com/staticfiles/support/downloads/firmware/ http://atulchitnis.net/files/seagate.pdf
Jun 20, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
Twin drives in an external HDD, and it quit, but I can hear them working. The fan also quit too.
http://atulchitnis.net/files/seagate.pdf http://www.seagate.com/staticfiles/support/downloads/firmware
May 20, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate st3500320as firmware sd15 not recognize by bios
You need to access the drive controller and reset it using an RS232 to CMOS convertor and hyperterminal. The problem is caused by the firmware on the controller software going into an infinite loop.
If bios is not seeing it then none of the software tools available will allow access.
Once the hard drive is reset, the disk is fully useable again. A firmware upgrade is possible at this point, but usually we just image the disk and load it onto a more reliable replacement as most customers do not want to experience that sort of fright again.
I have fixed a few of these and have the equipment to do it, but it is not really a task for the amateur.
Apr 14, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate satat error
the firmware is damaged,sir,nothing can do.you should go to the dr company to repair your hdd first by using HD Doctor or other tools,it is a typical bug for 7200.11,seagate's big bug
Mar 02, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
Seagate Barracuda 7200.10 250mb HDD - Spins up then spins down
http://atulchitnis.net/files/seagate.pdf http://www.seagate.com/staticfiles/support/downloads/firmware/
Dec 25, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
3,734 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
