Question about Vacuums
Dyson upright not turning brush belt not broke
  • wokez Nov 25, 2008
    I have the same product and exactly the same problem !
  • 120 Answers
That belt is hooked into a clutch, the clutch often fails and the only thing to do is replace it. i would take it to vacuum repair shop because it is not an easy fix
Posted on Sep 18, 2008
The brushes on my dyson dc33 won't turn. I know the belt hasn't broke. Thanks SIMON
brushes on my dyson dc33 won't turn Simon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.dyson.co.uk/support/dc07/dc07-clic/my-machine-is-not-working/my-dyson-will-not-stand-upright/my-dyson-will-not-stand-upright/no1/yes1/brushbar-not-turning-clutch-check
How to repair Dyson DC07 DC14 DC33
Dyson Burning Smell Beater Bar Brush Stuck DC14 Not Working Easy Fix
Aug 02, 2016 | Dyson Vacuums
I ran over a shoe lace and the brush on my dyson quit rotating how do i get it going again?
Turn it off and turn it back on again and it should reset.If that dosent work you probably broke the belt.It's easy enough to replace by just removing the bottom plate and the brush and installing the new belt. www.sewvac.com
Jan 29, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
The brush on the bottom of the vacuum won't turn when in position to vacuum. I have cleaned the brush, there is nothing tangled around it.
Sounds like the belt is broke, when you remove the brush, be sure that all teeth are still on the belt and that it is not streched. Typically every major retailer will sell these belts usually 2 to a pack and under $10
Jun 24, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brush not turning
The belt doesn't have to be broken to be non-functioning. If the belt is intact but stretched it won't turn the brush. You can get belts here:
Dyson DC14 Belts
Feb 14, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
The beater bar is not turning and the belt is still on it and not broke. it turns easy when i do it but will not work when i turn it on
The problem is that the belt is stretched. The belt may not be broken but if it is stretched or worn then it wont be able to turn the brush against the resistance of the carpet. Here is a link to the belt you need and to a manual you can view:
Dyson DC07 Belts and Manual
Nov 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson vacuum brush bar will not rotate and the belt is not broke. The hand tool works fine. What is wrong?
I took the plate off and cleaned up the vacuum brush bar. Since the belt was not broke I knew that was not the problem. I know when the setting is bare floor, the brush bar will not rotate. That was not the problem. I just keep turning the knob from bare floor to carpet, several times. The setting must have been "off" just a bit because after several times turning it, it must have reset in the proper setting. The brush bar did start rotating just like normal.
Nov 21, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Beater brush does not work. Brush is clean and belt is not broke. Dyson 07 animal vaccum
Even though the belt may not be broken it might be stretched and if that is the case it will not turn the brush. You can get replacement belts here:
Dyson DC07 Replacement Belts
Nov 16, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka Boss - Belt is not broke but brush will not turn. I have already turned it over - checked belt - and pushed the reset button.
The belt may look fine but they can still be stretched or worn and it won' turn the brush. Try changing the belt and see what it does. You can get Eureka belts here:
Eureka Replacement Vacuum Belts
Nov 07, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
The brush on my Dyson DC17 Animal does not turn
Remove the plate over the brushbar. Gently clean out debris. Put plate back on,plug in and turn on vac and press brush bar button to reset.
Mar 18, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson 17 Brush Belt Broken
When I had a problem with my DC17, I received a quick response from their service department at 866-693-9766. They recommended a local authorized repair shop.
Jun 22, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuums Logo
285 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
