Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Warm fridge frosty freezer
It's just that the seals are fine, it's a top freezer, is it the automatic defroster?
  • 1 more comment
  • steverdude Sep 24, 2008
    I have a Kenmore top freezer/bottom refrigerator but the refrigeratoe is warm while the freezer is cold. Any ideas?
  • Anonymous Sep 25, 2008
    warm bottom, cold top
  • rarington41 Oct 16, 2008
    My refrigerator is warm, freezer is cold, and water dripping at the top of the refrigrator. Any suggestions? It is Kenmore Model# 253.60754400 Do you know where I can get the manual? I pulled the fridge out unplugged it, cleaned the coils very good. Let it sit for the day plugged it back in, saw that the fan does work. Could something be clogged?
  • 943 Answers
Hi. thanks for the question . check the freezer fan motor, is it running . is there frost build up in freezer, check that. pull fridge away from wall. remove back panel .clean all lint . thanks the appliance doc
Posted on Oct 03, 2008
My freezer on top of the fridge makes a lot of ice on bottom of freezer floor,(under the plastic tray) and after defrosting it reoccurs a month or two later. which component needs changing?
this could be a faulty thermister. this tells the defrost cycle that ice has built up and needs to be melted. A ohm meter can test this component when the ice builds up the resistance of the thermister should change in value . Google how to test a thermister in a freezer.
Mar 28, 2016 | Refrigerators
My frigidaire automatic defrost upright freezer gets ice build-up at the top right at the front any suuggestions
This is just a general answer but it may mean that the door seal is leaking. Try running a dollar bill under the seal to see if that area is looser than the rest of the door seal.
Look inside the freezer for model number.
How to Check Freezer Door Seal DoItYourself com
Aug 01, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Westinghouse freestyle fridge &freezer work but warm after being turned off fo 90 days
What happens in that 72 hours is the evaporator coil get's so much frost built up on it that the fan in the evap. freezer fan has no where to circulate the cold air (where the cold is produced). Basically you have a restriction between freez/fridg. sections you have defrost problem> It is one of three things d heater,d t stat, or your d timer.I need the model # to tell you what my sugestions would be and where to start.
Nov 15, 2013 | Refrigerators
Amana fridge freezer AS2628HEKB fridge warm & freezer frosty inside
The board should be replaced before the unit will operate properly. Be sure to check out all circuits to make sure there is not some kind of short. If there is, it may burn out the new board also.
Jan 21, 2013 | Refrigerators
The problem is with my magic chef top/bottom fridge/freezer. the freezer is working fine, but the refrigerator is freezing its contents.
Either defrost problem or clogged drain... Is there snowy frosty ice on back wall in fridge? If so, hire a professional. If not - you can take back wall off in the freezer and defrost the drain.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - Refrigerator repair Houston, Katy, Spring and Woodlands, TX!
Aug 29, 2011 | Magic Chef CTB1521 Top Freezer...
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
I got LG fridge freezer my freezer has ice building and the temp is warm WHAT COULD BE THE PROBLEM.
your defrost system isnt working and you cant blow cold air thru a solid block of ice,remove the rear panel inside the freezer and check the evaporator coil for this type of ice buildup,they should only have a light frosty coating on them when the units cooling and not defrosting,then either the heating element below the coil is bad,the defrost thermostat on top of the coil is bad or the defrost system isn't getting power to operate
Nov 14, 2010 | LG Refrigerators
The freezer side is not keeping food frozen. Every three minutes I hear something turn on and it runs for about xx seconds. The model number is ASD2626HES. The refrigerator side seems fine.
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level
Hope this solved the problem, Take care....
Sep 19, 2010 | Amana ASD2626HE Stainless Steel Side by...
Refrigerator not cold, freezer barely cold and has ice on back wall
You have a defrost problem if the ice is on the back lower wall of the freezer section.... This is where the evaporator is located just under a fan.(aluminum coils looks like a radiator) There are three parts to the automatic defrost system- the heating element(found at the bottom of the evaporator) a bi-metal thermostat(found at the top of the evaporator) and a defrost control board(usually in the top of the refrigerator section,but this varies)
If you take off the back freezer panel and melt the ice build- up with a hair dryer or letting it open overnight, without poking any holes in evaporator and losing freon(out a fridge) your fridge will run fine for about 3 weeks. This is humidity from air collecting, automatic defrost system usually works about every 8 hours when working normally. Your sealed system and compressor are fine, you have a defrost problem. Good luck.
Mar 14, 2010 | Maytag MZD2766GES Side by Side...
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
142 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
